#183 |
Drives: frs
does anyone with A01C v1.33beta tried to rev the engine? for some reason the engine couldn't pass 6k rpm and it was shaking strong.
#184 |
The Mechanic
Drives: Civic Turbo,FR-S
shiv is there any purpose to the vented cover thing near the snorkel that mounts to the bumper beam???
#185 |
Drives: '13 DGM BRZ Limited
#186 | |
Drives: BRZ Limited
You may have been engaging the launch control feature if you were wot with the clutch depressed. EDIT: Oops, I was a little late. Thanks cnk! |
#188 |
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
You're good jeebus - Shiv is correct. Other than that one table scaling, there was no discernable difference between A00C and A01C. If you've uploaded one of the OTS maps and it's based off A01C, the scaling will be correct (i.e. the -50 offset). I would assume that Vishnu would have standardised the OTS roms off one CAL id.
If you're using OFT to open up stock roms, not provided by Vishnu (e.g. Ecuflash extracted), and the scaling has been changed to -50 for all the A0*C roms, A00C would be incorrectly displayed - unless a separate XDF file has been created specifically for A00C. I haven't checked out the latest OFT maps, so Shiv would have to answer that one. |
#189 | |
Drives: 2015 Mustang GT (on order)
#190 |
Go-Kart Enthusiast
Drives: Toyota Scion FRS
So,.. I flashed the latest beta and drove to and from work. Thus far I can say that I am really not happy and would prefer to flash back to the prior beta. The prior beta pulled like a train, was snappy and the tq dip disappeared sooner as I rev'd the car.
It is a strong possibility that perhaps my car has not had time to read the ecu but I drove about 20 miles total.. to and from work. I tried to open her up a few times just so the car could experience it and learn. I dont know what is going on between 1k to 2k but it is not a smooth rev and almost bucks slightly. If the newest beta tune 1.33 is safer than the prior then I will accept that.. did they reduce the timing or something? if its not safer at all and the prior beta is just as safe then I may flash back. thoughts? ill give it another commute to work.
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels |
#191 | |
#192 |
I do have a question about the Knock Detection RPM range table. Should this go up to 7650 since our redline has been raised?
#193 | |
Drives: DGM
#194 | |
Drives: WRB Limited BRZ
#195 |
Every time I reflash, it takes a few drives (50 miles?) to get back to normal.
#196 |
Drives: FRS(sold), AP2, R35, FJC, ED9
Give it a few miles. Right after I reflashed to 1.33b the car was sluggish and the vvt didn't come on till what felt like 4.5krpm. After I got to my destination and was going home the car felt like it should.
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 06:35 PM |
| Quick Review-OpenFlash (Dyno Test) - Stock vs. Vishnu Stage 1.0 vs. Vishnu Stage 1.1 | FRSTEVE | Software Tuning | 105 | 08-04-2017 04:48 AM |
| anyone trying to use the openflash tablet with forced induction? | FRSTEVE | Software Tuning | 69 | 12-07-2014 04:07 PM |
| Is Openflash tablet detectable? | Boofneenee | Software Tuning | 25 | 05-02-2014 10:03 PM |
| OpenFlash Tablet Stage 1 v1.2 maps available for download | Shiv@Openflash | Software Tuning | 31 | 10-31-2013 08:45 PM |
