Old 11-02-2013, 11:44 AM   #183
endrswrd
Drives: 2013 LTD BRZ
Originally Posted by utekineir View Post
is this viable for the unwashed masses yet?
tactrix cable waiting,
very computer literate, but 100% programming retarded.
thanks,
Wouldnt say its viable to the masses as they are some little things getting ironed out but it is usable. If you have never have used ECUflash I would wait for things to get ironed out with the checksums / padding so that your not taking the risk of flashing a bad rom. Its very close though.
endrswrd is offline   Reply With Quote
Old 11-02-2013, 12:27 PM   #184
ft_sjo
Drives: GT86
Originally Posted by Td-d View Post
I assume so - my understanding is that Colby is also coding a new kernel based reflash alongside the logging capability.
So if you flash without the correct padding you will brick the ECU?
Old 11-02-2013, 02:15 PM   #185
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
No, I wouldn't think so - Ecuflash can read the unpadded bins no problem - but you won't be able to edit using Romraider - since it expects a contiguous set of data, and the CAL id to be at 0x8000.
Td-d is offline   Reply With Quote
Old 11-02-2013, 02:17 PM   #186
Td-d
That's why it's only been released on request for now, and mostly to devs. I expect the next release will have kernel based flashing and data logging enabled.
Old 11-03-2013, 05:57 AM   #187
Td-d
I have started on the Ecuflash definition, it's a work in progress and requires an updated 32bitbase.xml - check out the original definition thread for the new links.
I've completed updating the 32bitbase - this should provide a full Ecuflash definition for 00C. I'll put up 001C asap.
Old 11-03-2013, 10:00 AM   #188
brn12345
brn12345's Avatar
Crossing fingers for 01J definition
brn12345 is offline   Reply With Quote
Old 11-03-2013, 11:11 AM   #189
vgi
Drives: frs
does flashing have the same effect as disconnecting battery? another words does the ecu need some driving time to adjust to the new tune?
vgi is offline   Reply With Quote
Old 11-03-2013, 12:45 PM   #190
Td-d
With most ecus, yes, it will reset the AF learning and other values.
Old 11-03-2013, 12:47 PM   #191
vgi
Drives: frs
ah, thank you!
Old 11-03-2013, 12:48 PM   #192
Td-d
001C is up, working on A01G next, I've actually got A01J mostly disassembled already (since it was the first BRZ rom uploaded, before the beta was even mentioned).
Old 11-03-2013, 12:48 PM   #193
Td-d
ah, thank you!
Check my response on the RR forums - you've downloaded the wrong A01c def - it's a bare bones one that I initially uploaded to test the beta. There is a fully defined one now.
Old 11-05-2013, 09:28 AM   #194
nelsmar
Originally Posted by Ralph Spoilsport View Post
Along those lines... the only thing I absolutely detest about my BRZ... is the location of the OBDII port. It's like they designed it to put the OP2 in harm's way.
Get an extension cable with a right angle on it. Now it wont be anywhere near you. I had to do this for logging with EcuTek, leg would hit the damn cable. -.-
My flickr - Canibeat
Local magazine scout
Old 11-06-2013, 03:53 PM   #195
Td-d
ZA1JA01G, RR and Ecuflash definition is up on the RR forum.
Old 11-07-2013, 11:27 AM   #196
Td-d
ZA1JA01J, RR and Ecuflash definition is up on the RR forum.
Close iJason Member's Car Journals 1 08-04-2013 08:26 PM
Close pche Engine, Exhaust, Bolt-Ons 3 08-04-2013 02:04 AM
Sorry. please close. finch1750 Scion FR-S / Toyota 86 GT86 General Forum 1 07-31-2013 01:00 AM
please close abutterman Wheels and Tires 0 07-05-2013 09:40 AM
