#183 |
Drives: Ultramarine 2013 Fr-s
To remove the center vent is only 2 screws..
#184 |
Drives: '22 BRZ
The dash vent isn't the issue, the whole dash needs to come out to replace it. The car's under warranty, I don't see the point in messing around with stuff like this myself.
#185 |
Drives: 2018 BMW M2
Bump
Mine is getting worse. It's only 70 degrees today and the dash is lifting up more and the dash is feeling softer like it's going to melt. For those who used adhesives to fix the dash, how is it holding up? |
#186 | |
http://www.ft86club.com/forums/showt...60#post1836860 combine it with a heat shield, should be golden
#187 |
Drives: 2014 Subaru BRZ
Summer time soon. Will be seeing a lot of posts on this thread.
#188 |
Drives: red
Soy nuevo aqui
#189 |
Drives: red
El dash mio ya esta despegado
#190 |
Drives: 2013 Scion FRS Whiteout
shit man mine is doing this as well I noticed a rattle in my dash and pressed down where you're having an issue and noticed it's coming up too! God damnit
#191 |
Drives: 2014 BRZ Limited
Getting mine done in 2 weeks. 18,000 miles and bad bulges. hope the dealer does a good job
#192 |
Drives: Firestorm 2013 FR-S
Why anyone who cares about their car would NOT use a sunshade when parked in the sun is beyond me. Not just the damage to the dash but the amount of film deposition on the inside of the windshield.
Also, it makes SO much difference in the temp inside the car when you get into it too. I hate getting into a car that is 120 inside. I put one in the side window on whichever side is facing the sun too.
1995 BMW M3, 1973 DeTomaso Pantera, 1972 Dino 246GT, 1964 Fiat-Abarth 1000TC vintage racer
#193 |
Drives: GTS 86 auto
Consider a BLACK dash-mat with D.I.Y. aluminium foil on the underside. Between the foil and dash have fabric to ensure no direct contact between foil and dash and create an air space.
A) it reduces reflection in the glass B) the foil insulates sun heat from radiating into the dash rubber c) it reduces the polymer fallout to the glass The oe dash on my previous car was 100% after 17 years of Australian sun with this mod. (You may need to experiment with a hole in the foil if it shields your satnav sensor)
GTS86 Auto (Australia)
#194 |
Same issue. 2013 model FR-S with under 20,000 miles. Dash is coming unglued. I have till the May of next year to replace it. Holding off till this summer heat goes by. Toyota looked at it and immediately approved it.
#195 |
Drives: 2018 BMW M2
#196 |
Where did you buy this? @sprintertrueno86
| 86 rubber floormats | denverizzles | Scion FR-S / Toyota 86 GT86 General Forum | 30 | 05-06-2013 05:10 PM |
| Does anyone have a rattle coming from the center dash? | Liquidsnake | Scion FR-S / Toyota 86 GT86 General Forum | 29 | 09-30-2012 10:09 AM |
| Anyone else smell rubber? | pinoyplaya | BRZ First-Gen (2012+) — General Topics | 15 | 09-24-2012 03:40 AM |
| Both: EZ DIY Rubber Trunk Mat (FR-S Only) | Calidrifter | DIY (Do-It-Yourself) Guides | 15 | 08-29-2012 12:59 PM |
| Trade my black dash plastic for your silver dash plastic thread. | F3dzo | Southeast | 0 | 07-17-2012 10:06 PM |
