Old 07-10-2013, 03:25 AM   #183
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by swift996 View Post
Why is @sw20kosh 's meth gauge moving?
I had it on but I was running the base tune. I currently don't have a switch to turn it on/off. To turn it off requires going in the engine bay and either disconnect a wire or clamp a boost hose. I was lazy.
We did a run on the dyno with the base tune and the meth on... no difference. To get the benefits of the meth you have to tune the timing advance and the AFR.
Old 07-10-2013, 08:16 AM   #184
swift996
swift996's Avatar
Ahh I got you, I just thought the video comparison was trying to make apples to apples.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 07-10-2013, 08:16 AM   #185
regal
Originally Posted by Dezoris View Post
It is also non-intercooled, and thats a big question mark, namely without testing or logs being supplied.
The logs and data will eventually tell the story but I almost see non-intercooled as a plus for the DD. I owned an '84 turbo Buick that had a factory turbo setup that blew 15psi of nasty hot air into its V6 without an intercooler. Those engines lasted forever. Also think of all the blown 350 chevy's without intercoolers.
This being a very efficient small twin screw means that unless you are an open track racer an intercooler may just get in the way.
May find that the psi drop across the intercooler hurts more than can be over come with a smaller pulley on pump gas (pushes the blower out of its efficient zone.) Most factory boosted engines have at least double the Innovate.
I'm just trying to say that at low boost with a positive displacement blower an intercooler isn't always "right." The Innovate is such a clean install without the intercooler.
E85 isn't an option for a daily drivers in most places but is probably the smartest solution for racing.
For DD ownership, , most folk's goal with these cars is to own a budget Cayman-R. Now that is a <14" quarter mile car. The FA20 really just needs more midrange torque and about +40 top end HP to push this car into that ballpark, right ?
I hope we see some success stories soon, your post in the other thread where you logged knock with the stock setup and none with the Vortech + tune is a big deal (should add that to the video series.) That factoid me itching to say screw Toyota and make this engine sing!
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 07-12-2013, 02:24 AM   #186
wrxgoose
WUB WUB
Drives: 2013 Firestorm
alright! mine should be arriving tomorrow, and I will attempt to post logs (still haven't been able to log with my car now, since I had the tune done on john's computer), but i'll try to figure it out. I'm also going to be doing a dyno day, and dragstrip meet in august, so hopefully I'll have gotten remote tuning done by @FA20Club.com, so we'll see what it's capable of with supporting breathing mods.
wrxgoose is offline   Reply With Quote
Old 07-12-2013, 03:04 AM   #187
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Mine has been sitting on my workbench for the past week as I continue to wait for my Rev Works headers to arrive! Grrrr...
The Following User Says Thank You to DarrenDriven For This Useful Post:
ftc~brz (07-12-2013)
Old 07-12-2013, 03:16 AM   #188
xxscaxx
Drives: 2013 SWP BRZ
Installed 99% of it tonight. Quick question for those who have already installed it.
The kit comes with a brake booster line, but it specifically states it fors RHD only. Yet I see in @moto-mike 's install he used it. Was going to bolt down the charger and the stock line is in the way, so i'm assuming I need to use the brake booster line. Mistake in the labeling maybe?
Other than that, I just need to bolt down the charger and put the belt on/boost tube. Super simple install.
xxscaxx is offline   Reply With Quote
Old 07-12-2013, 03:17 AM   #189
DarrenDriven
NW Region Moderator
How long did it take for the 99%?
Old 07-12-2013, 03:23 AM   #190
xxscaxx
I started around 9:30 and came in the house around 1:45, but i was screwing around with that stock brake booster line for about 30 minutes or so because I couldnt get the supercharger to sit flat. So that consisted of me taking it out like 4 times lol.
Old 07-12-2013, 03:28 AM   #191
xxscaxx
Just noticed @sw20kosh installed that brake booster line as well. Least I know to swap it out quick tomorrow
Old 07-12-2013, 04:06 AM   #192
sw20kosh
Yep. Ya gotta install it!
Old 07-12-2013, 07:57 AM   #193
nix
nix's Avatar
Drives: AVO BRZ
I'm not an owner so I'm breaking the rules by posting but you might have seen my car on an avo turbo kit. Well, the sprintex installation is finished on my bro's car now and it's getting tuned next week on 98 ron!
We will swap cars as much as possible and post some feedback!
nix is offline   Reply With Quote
The Following 3 Users Say Thank You to nix For This Useful Post:
Benn0r (07-12-2013), DarrenDriven (07-12-2013), DriftZen (07-13-2013)
Old 07-12-2013, 01:20 PM   #194
ftc~brz
Done
Drives: WRB BRZ
my install is happening right now! (I'm at work so no fun for me)
ftc~brz is offline   Reply With Quote
The Following 2 Users Say Thank You to ftc~brz For This Useful Post:
Dezoris (07-12-2013), whataboutbob (07-13-2013)
Old 07-12-2013, 01:43 PM   #195
PRE-Erich
Drives: 1981 Toyota Corolla TE72
If you run an air-to-water intercooler setup the pressure drop is usually less than 0.3psi on most cores.
PRE-Erich is offline   Reply With Quote
Old 07-12-2013, 02:48 PM   #196
Brian@Vortech
Brian@Vortech's Avatar
Drives: Vortech Supercharged M6 FR-S UM
Think about what you are comparing! The compression ratios between those engines are light years apart, and factory boosted engines are generally built with different parts than N/A engines (materials, clearances, heat tolerances, etc.).
'84 non-intercooled Turbo Buick stock compression ratio - 8.0:1
2013 FA20 engine in FT86 stock compression ratio - 12.5:1
That Buick's final compression ratio @ 8psi is 12.4:1 - still less than the FT86 from the factory before the supercharger.
The FT86's final compression ratio @ 8psi is 19.4:1 - even N/A Diesel engines don't run that high...and they need heat for their compression cycle.
Those 2 engines do not make for such a great comparison, as they are far too different.
Brian@Vortech is offline   Reply With Quote
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
