Old 09-03-2013, 03:20 PM   #183
Originally Posted by iLuveKetchup View Post
You see big sway bars because of classing rules. For example, B-Stock where you cannot change the spring rate. Therefore make up for it with a big front bar.
I've seen quite a bit of it carry over into STR/STX...
OT: Were you at nationals this weekend? Nick got a double win... imagine if he had decided to taken a seat with Nissan.
Old 09-03-2013, 05:13 PM   #184
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
Do you consider our Tein SRCs a "National Championship level competition race shocks and pretty irrelevant to anything remotely 'street'"?
Short answer: No.
Disambiguation: I'm just trying to get my head around re-learning everything I've ever learned about suspension. I've always assumed that harder sprung cars would have more issues in terms of maintaining traction and control on less than ideal surfaces - 'skipping over' irregularities instead of swallowing them up.
A detailed grasp of the mechanics governing various types of damping vs. spring rates and unsprung mass is a bit of a black area to me though.
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 09-03-2013, 07:53 PM   #185
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
^ there are other things in play, the most important tires.
iLuveKetchup is offline   Reply With Quote
The Following 3 Users Say Thank You to iLuveKetchup For This Useful Post:
CSG Mike (09-03-2013), solidONE (09-03-2013), whataboutbob (09-04-2013)
Old 09-03-2013, 11:41 PM   #186
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by ultra View Post
Before anybody says it yes - I'm aware of Penskes, Motons, Nitrons, Proflex etc. All National Championship level competition race shocks and pretty irrelevant to anything remotely 'street', IMHO.
What's wrong with running high end dampers on the street? I run Penske 8987 3-way shock on my bike and it is fantastic for the street. The high speed damping really mutes potholes and expansion joints on freeway rides. I expect similar result on a a car.
The Following User Says Thank You to solidONE For This Useful Post:
Old 09-03-2013, 11:54 PM   #187
Short answer: No.
You have to remember that net spring rate is the static spring rate of the spring itself, and the dynamic spring rate of the damper. On a very simplistic level, having no suspension (like a kart) would result in tires that lift off the ground on bumps, and a suspension with springs only without dampers would absorb the bumps, but keep the chassis oscillating up and down. The damper's job is to eliminate that oscillation.
While higher spring rates take you closer to the infinite spring rate of having no suspension at all, the rates you're looking at for the high end dampers are nowhere near enough to cause wheel lift. These setups are designed to maximize traction, and their designed purpose would be defeated if you actually lifted a wheel and resulted in a loss of cornering grip (there ARE cases where lifting a wheel has no net effect on grip...).
ultra (09-04-2013)
Old 04-29-2014, 01:31 PM   #188
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
Hopefully this is the right place to post this, but I'm looking for help on finding the correct damping setting on my coilovers. I currently have Speed By Designs kit, which I believe is 6k spring rate front and rear. 24 settings for damping.
Right now I'm sitting at 10 clicks from max hard. The ride feels comfortable but I just want to make sure I'm getting the most I can get out of these.
What should I be looking for when trying to find the ideal damping setting for daily driving?
I'd like to keep my car feeling fun to drive without sacrificing ride quality too much. I feel like I can go stiffer, but after reading the first post about people frequently mistaking "stiffer" for "better" I'm second guessing myself on going stiffer. The car definitely does feel more fun on the stiffer settings, but if that's not ideal for performance then I'd rather not adjust to that.
So again, what should I be looking for when trying to find the ideal damper setting?
@CSG Mike , you seem to be an expert on this!
ericmpena is offline   Reply With Quote
Old 04-29-2014, 10:56 PM   #189
Well, you only have one adjustment with those dampers, so keep increasing damping until it starts to get harsh. When it gets harsh is when you have too much damping. Back off 1-5 clicks from there; you'll find a "best balance" in that range.
ericmpena (04-29-2014)
Old 04-30-2014, 12:23 AM   #190
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
mike what did you think of bc coils? they ride like crap to me, i switched to a 5k 6k swift setup on them and it rode a tad softer but felt so much more planted. ive now ordered the gen 5 fortune autos 500s hoping they are a better quality.. your thoughts on them?
IG-Joey_Soul
Old 04-30-2014, 03:48 AM   #191
PM'd
Old 04-30-2014, 08:31 AM   #192
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
PM'd
Heh, Mike is too smart to post about the quality of BCs in public. Every time I do it anywhere, I get flamed hard. Especially locally, as I live 5 miles from BC North America.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
The Following User Says Thank You to Kido1986 For This Useful Post:
Propaganda (05-01-2014)
Old 04-30-2014, 08:48 AM   #193
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
PM'd
Could you pm me your insight on this too? I have BC's and went 7k/6k and felt the same. Car feels a lot planted now with the swifts compared to the BC springs which were too stiff and any adjustment I did still felt underdamped.
Tye300 is offline   Reply With Quote
Old 04-30-2014, 02:31 PM   #194
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
I'd also love to hear Mike's honest thoughts/experiences on them.
fooddude is offline   Reply With Quote
Old 04-30-2014, 02:36 PM   #195
CBR600RR
Drives: Raven Black
@CSG Mike what's your opinion on the ST Suspension Coilovers for street use?
Old 04-30-2014, 03:26 PM   #196
They're comparable to other coilovers at the price point.
Mike's CS FR-S build mikef Member's Car Journals 6 04-25-2013 10:11 AM
Some observations Nardi330 AUSTRALIA 20 02-07-2013 07:18 AM
90 Day Anniversary ..some Observations Scooby South BRZ First-Gen (2012+) — General Topics 6 09-03-2012 12:17 PM
Mike's track videos. CSG Mike Tracking / Autocross / HPDE / Drifting 2 08-16-2012 05:00 AM
First Payment sent, Observations after 6 weeks. Scooby South BRZ First-Gen (2012+) — General Topics 27 08-01-2012 03:02 PM
