Old 10-31-2011, 02:31 PM   #183
Allch Chcar
Drives: N/A
Have the leaked scans been verified that they aren't a photochop or not?
One thing to note is that the RX-8 power figures are for the US. JDM RX-8 get 250PS and they even have a taller 3rd gear because of it. They used the USDM version. I didn't see any others besides that one.
They compared it to the CR-Z instead of the Civic Si. They could have compared it with the Gencoupe or a BMW 1 Series if they need something close!
The Mid range price has been estimated around $25k USD for a long time. The only question is which will Scion offer or how much for a Subaru Base.
You guys managed to argue about Fuel Economy estimates for an entire page.
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 10-31-2011, 02:32 PM   #184
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
Originally Posted by Nardi330 View Post
Scans from a training manual.
Power/weight:
HP: 147kw (200ps) / 200hp @7000rpm
Torque: 205nm (151 lb/ft) @ 6600rpm
Weight:
  • 2662 ponds (1210kg) for base manual (~ 2580 lbs dry weight)
  • 2706 pounds for higher trim manual
Columns:
First 2 column are for "small FR sport", column 1 is a higher spec model, column 2 is a lower spec model. 3rd column is Mx5/Miata, 4th is RX8 and last is CRZ. It's a comparison chart.
Top Section:
The top section is the dimension in mm, length width height wheelbase, ground clearance then number of seats. Next is weight.
Top spec manual is 1230kg, auto is 1250kg.
Low spec manual is 1210kg, auto is 1230kg.
Then its turning radius.
High spec rides on 17" wheels and low spec on 16.
Second Section:
This section is engine. Boxer 4 DOHC, 1998cc. Output as listed on 1st post above. Drinks unleaded and 50L fuel tank.
Fuel consumption base model:
13 km/l
30.58 mpg
49.21 kmg
Fuel consumption top model:
12.4 km/l
29.17 mpg
46.94 kmg
Third Section:
This section is front engine/rear drive, transmission type, suspension type, brake then tyre size.
High spec brakes: ventilated discs front and rear.
Low spec brakes: ventilated front, non ventilated rear.
Last Section:
Last section is equipment which is not that easy to understand. First thing I notice is top spec has LSD for manual and auto while low spec only has LSD on manual. I'll post more if I can read more.
More update:
Both spec have VSC, front passenger and front and rear curtain bags. Top spec has front LED, leather steering wheel, 6 speakers audio (low spec has 2 speakers), white rev counter with shift light and sport pedals. Top spec also has "smart entry and start".
Things of note:
Strut front, double wishbone rear suspension
Base halogens, optional HIDs on base trim, standard HIDs on high trim
LSD on all MT cars
Stability control standard
Only 2 speaker audio on base car
High Spec:
Has "high-quality fabric" (上級ファブリック).
Option for leather heated seats with Alcantara inserts.
Steel door sill insert
Interior metallic door handle inserts
Carbon fiber center console trim
Door courtesy light
?Knee pad?
The "Customize Grade" at the bottom is interesting:
- Unpainted bumper
- 16 steelies (says ornament-included, guessing it includes the logo)
- plastic steering wheel
- NO A/C (only a heater)
- Power door locks
- Sunvisor (no vanity mirror)
- No speakers
Here are translated charts (by our members Spaceywilly and dimension6!!)
Training manual images:
Sorry for showing up to the party late but damn this is awesome info, the best so far!! Full specs!! :happy0180::happy0180:
Originally Posted by WingsofWar View Post
So the lowest of the 3 (or 4 if a R type surfaces soon) available models. Is the Bare Bones/(Custom) model?
Comes with a different front bumper and rear bumper / No front or rear bumper
6MT, cloth seats, no audio, 16in steelies, analog dash, no accessories.
+ If this model also got rid of the rear seats & no AC, and no EPS and came in at 16-19k. Hardcore Tuners, your track God has arrived.
With our luck, the US will only get the bottom spec. Fine for the tach, but I wouldn't mind some of the other top spec brakes (primarily the brakes).
+1!
I think this might be how Scion is going to set it up too! Offer the Low Spec as a blank canvas and then offer an array of accessories for both interior and exterior. I want the low spec, perfect for the track!
Old 10-31-2011, 02:33 PM   #185
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by balance View Post
As for the rear brakes, my guess is that the scion version will have a single setup (vented rear-discs) and you can select the TRD big brake kit if you wish to upgrade.
I have very little interest in big brake kits "upgrades" that just "upgrade" the front. Actually zero interest. The stock brakes will likely be PLENTY with better pads and fluid for the track, and they will certainly be plenty good enough for the street.
I just want the better of the stock brakes.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-31-2011, 02:34 PM   #186
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by WolfpackS2k View Post
I've never heard of someone with an S2000 overheating their rear brakes. However its well known that the OEM pads are not up to the task of track duty. While I wish my S2000 had ventilated rear rotors, it brakes just fine. In fact with Carbotech pads I've had 911 drivers remark to me how impressed they were at my late braking
Same here.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-31-2011, 02:39 PM   #187
cyde01
ft86club resident b-boy
cyde01's Avatar
Drives: Yamaha R3, moonslate 2018 GT Black
btw everything pretty much has been translated. the only things i noticed that weren't translated:
the car in fact does require premium unleaded gas (無鉛プレミアム)
the rear seat is one piece and is foldable (一体可動式)
did anyone mention that the high spec model comes with a digital speedo and tachometer? (デジタルスピードメーター revメーター)
random interior bits included in the high spec model:
stainless door scuff plate? (ステンレス製ドアスカッフプレート)
some kind of mesh carbon interior panels
metal plated inside door handles(メッキインサイドドアハンドル)
door courtesy lamp?(ドアカーテシランプ)
knee pad (ニーパッド)
the "customize grade" bare bones model is 1190 kg
cyde01 is offline   Reply With Quote
Old 10-31-2011, 02:39 PM   #188
balance
Drives: 86 & Picanto
I completely agree with your comments about the stock brakes.
Of course, better set-ups are always better when it comes to the brakes.
If I win free money or something, I would love to get the AP racing calipers;http://www.essexparts.com/shop/compe...-calipers.html
balance is offline   Reply With Quote
Old 10-31-2011, 02:41 PM   #189
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
Originally Posted by iggyhop9 View Post
Ok, so the 400 lb heavier and FWD manual Scion TC does the 0-60 in 6.5 with 20 less HP. Are we looking at 6.0 here for the FT?
I sure hope so! I did not know the tC was that fast!!!
tripjammer is offline   Reply With Quote
Old 10-31-2011, 02:41 PM   #190
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by madfast View Post
ok if you do the math, this thing is making 150 ft lbs at 7000 rpm. incredible. if allowed to rev to 9000 rpm, im guessing this thing can make S2000 power.
also this car is 200 lbs lighter than the RSX-S, 11 ft lbs more at 6600 rpm and 10 ft lbs more at 7000. it makes about the same hp 800 rpm sooner.
i think there is still a LOT left on the table. the tq is holding flat close to redline. for fuel econ and reliability reasons, they probably set the redline at 7400...
It doesn't work that way. Torque and power will be DROPPING after their peak, you rev it to 9k and assumng the valvetrain can handle that it'll probably produce 100ft lbs and 150hp or so up there.
While the torque hasn't dropped much by 7000 (400 rpm later) it obviously starts dropping nicely after that point. For it to even make close to the peak torque at 7400 it would be producing 213hp @ 7400. If we assume it just drops 1 HP at 7400 the torque is already down to 141ftlbs at 7400. Most likely it drops a decent amount more than that, let's just say 5hp, and you are already down to 138ftlbs 400RPM after peak HP and only 800RPM past peak torque.
You rev that stock motor with stock cams and valvetrain to 9000 (again assuming you don't get valve float and piston to valve contact) and you won't be making any sort of usable power.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-31-2011, 02:41 PM   #191
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Well, if you had big enough cams it would.
old greg is offline   Reply With Quote
Old 10-31-2011, 02:41 PM   #192
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by fred_boosted View Post
I never did a turbo build on a non turbo car.
People telling me if I want to do that I have to make it less than 10:1...
Which means I have to do an engine build, and this is the only one thing I don't want to...
Not true, you just have to know what you are doing and be reasonable about it.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-31-2011, 02:45 PM   #193
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
No, but since Toyota has been leaking stuff everyday now... :shrug:
They probably wanted to use other Asian cars.. They seemed to focus on lightweight cars so I'm guessing that's why they used the CR-Z.. not sure. Any hybrid used as a comparison seems silly lol
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-31-2011, 02:47 PM   #194
ryridesmotox
Drives: 2010 Chevy Cobalt SS, 59 Ford F100
Not necessarily...
Example: the new 5.0 coyote mustang motor has 11.0:1 compression... not exactly what you want for boosting an engine but C'est la vie... there are plenty of boosted coyote motors running around at 6-7psi on 91 octane up to 8 psi on 93, and if you want to run ethanol (like I would do) I believe they are getting up to 10psi. thats on a stock engine.
One of the limitations is the fuel and the density of the air charge. Ethanol is EXTREMELY knock resistant as most people on here know. You also run it alot richer than 91 or 93 (about 15-20% richer generally). Another limiting factor is the lower end... I'm thinking they are going to go forged internals... it just makes sense if they want the motor to spin up to 7500 or 8000rpm... this is good news for boosting the motor. If the compression ratio is over 11.0:1 it would almost be not worth it to boost the motor, to get real power it would need a rebuild and lower compression.
In my car (Cobalt SS with the LNF) the engine is built from the factory to take murderous amounts of boosted power. stock boost is 15+/- psi. I am running 24/25psi on my ethanol tune... that said the compression ratio is like 9.2:1. There are plenty of guys getting almost 500whp on a daily driver Cobalt SS (turbo swaps). But this is just an example of a more ideal motor for boost.
Treadstone Performance Stage 3 kit: CAI, Charge Pipes, TR8 intercooler, Maf Relocate, 52MM Turbosmart BOV, 3 inch catless downpipe, 3 inch catback, borla XR1 muffler, Exedy Hypersingle, TWM short throw shifter, 24PSI HPtuned by Terminator2 on E85/91
ryridesmotox is offline   Reply With Quote
Old 10-31-2011, 02:48 PM   #195
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
You need to maintain balance though otherwise big brake kits on the front only can actually decrease your braking performance.
I'm good with brake upgrades on all four corners but it takes a pretty piss poor brake design to actually need it, or a shitload more power on track, then you need bigger heatsinks (aka rotors) all around to handle the additional heat from braking at higher speeds.
Either way, for me, I'm sure the OEM brakes will suffice. I'll have to import the JDM ones if we don't get them though just to have them :P
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-31-2011, 02:50 PM   #196
Abflug
Abflug's Avatar
Drives: MR2
Great! Thank you, Sirs!
Abflug is offline   Reply With Quote
brz forum, brz forums, brz specs, brz sti forum, fr-s review, fr-s specs, frs review, frs reviews, ft-86 review, ft-86 specs, ft86 forum, ft86 forums, ft86 specs, scion fr-s, scion fr-s forum, scion fr-s horsepower, scion fr-s hp, scion fr-s review, scion fr-s reviews, scion fr-s specs, scion fr-s weigh, scion fr-s weight, scion frs, scion frs forum, scion frs review, scion frs specs, subaru brz, subaru brz forum, subaru brz forums, subaru brz horsepower, subaru brz hp, subaru brz specs, subaru brz sti, subaru brz sti forum, toyota ft-86, toyota ft-86 forum, toyota ft-86 horsepower, toyota ft-86 hp, toyota ft-86 review, toyota ft-86 specs
AutoBild gives specs of the Subaru BRZ Ice_Man BRZ First-Gen (2012+) — General Topics 43 10-30-2011 06:43 PM
Guessing Scion FR-S specs?? dClutch Scion FR-S / Toyota 86 GT86 General Forum 58 04-28-2011 11:07 PM
If there is no Toyota will you go with Scion or Subaru tranzformer Scion FR-S / Toyota 86 GT86 General Forum 91 04-25-2011 11:53 PM
200hp / 2700lbs - Really? Rickster Scion FR-S / Toyota 86 GT86 General Forum 385 04-18-2011 02:47 PM
TRD options and Badging? BanningFT Scion FR-S / Toyota 86 GT86 General Forum 43 11-08-2009 03:53 AM
