Old 06-21-2011, 05:01 PM   #183
serialk11r
Drives: '06 AM V8V Coupe
Oh woops okay you're right about that. I still don't think turbulence is an issue as there are cars that channel air into the side, and like I said wheels already have some drag when they spin because most cars come with wheels that don't have covers these days. Sucking air from a perpendicular stream isn't an issue either, because the other side of the fan is also air moving by, the static pressure is approximately equal.
I don't think you can compare directly to a helicopter because a helicopter rotor needs to balance the drag of the main rotors which is a considerable force. Since the second rotor is much smaller it needs to spin fast to generate sufficient force. Here we just want to enhance airflow a little, that is giving the spokes a little bit of angle so they push a small amount of air through the brake rotors. How much this helps, I don't know, but it's definitely better than some of the stuff I've seen. I looked up "active brake cooling" yesterday and I saw some kits for sale that were small tubes with little tiny fans hooked up, good luck with that lol.
Oh and I think heatsinking the calipers is probably a good way to prevent the fluid from boiling?
Oh another random idea, I APOLOGIZE, has anyone ever tried making something that sprays water onto the rotors when they get hot?
Old 06-21-2011, 05:47 PM   #184
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
yikes...super cooling heated metal at intervals during braking makes me sqeezy..i see cracked rotors in the future with that method.
I think just air proper ducting is pretty efficient with cooling brakes..and its simple and cost-effective..i don't think we need to find other methods. I just look at what F1 does with their cars, and I don't think they haven't done a whole lot more than air ducting and using carbon rotors and pads.
WingsofWar is offline   Reply With Quote
Old 06-21-2011, 06:04 PM   #185
Want.FR-S
Want.FR-S's Avatar
Drives: 4 Wheels Auto
Originally Posted by Maxim View Post
In the case of a lack of ducting, holes in the bodywork can be cut. From there, cutting a hole in the back structure behind the bodywork, and welding in a couple flat pieces of thin steel can direct airflow out towards the brakes.
It's just that you then have to cleverly disguise said holes in bodywork, not to mention get somebody to actually do this custom job, regardless of how simple in execution it really is. It's a simple solution to a simple problem.....which means it SHOULD be provided at the freaking factory.
We don't know yet that there aren't panels directing some airflow from the gaping maw on the car....it's perfectly possible that they're there. However, if they're not, that is indicative of Toyota/Subaru putting style before substance on the car, going for a sleek look rather than functional bodywork. That suggests there may be other areas of the car where the same reasoning was used.
Just something to think about. No way to tell if it's correct or not at this point.
The problem I see with punching holes in the wheel well is that the water may get in the way to rust the components. Currently when I look at production cars, the wheel well do not have air duct holes. If by doing this custom drilling and directing air, the water could potentially spilled over the duct and rust the things. That would not be nice.
Speaking of F1, it seems that the designers direct the air from hub into the rotor for cooling. That is pretty much about it. I wonder if the same can be done for production cars like FT-86.
Want.FR-S is offline   Reply With Quote
Old 06-21-2011, 06:42 PM   #186
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
im sad my thread has no rating
Old 06-21-2011, 07:09 PM   #187
dalli
dalli's Avatar
Drives: Toyota
you are welcome
imagine this is production........ DROOOOOOOOOOLLLLLLLLLL*******
dalli is offline   Reply With Quote
Old 06-22-2011, 01:19 AM   #188
Dimman
Kuruma Otaku
Dimman's Avatar
No, if you swap a wheel/tire to the opposite side of the car, the rim will be flipped backwards. It can be somewhat difficult to mentally rotate that in your head, but if you have a small fan handy you can get an easier, physical example of it. Take a fan and set it facing you, then note the direction the blades are traveling on the upper 180 degrees. Now, turn the fan so it's facing away from you. The air will be blown away from you, but the upper 180 degrees of the blade rotation will be opposite what it was before. With a car, since both left and right tires are rotating in the same direction (unlike the fan example), that means that the airflow would be reversed.
And you are right, it's about 1000rpm, depending on wheel diameter. But a fan rotating at that speed will not produce the same airflow if it has to suck air that is already traveling at high speed in a perpendicular direction. A large proportion of the possible thrust would instead be consumed in turbulance. Helicopters, with their rear tail rotars, have to counter this by increasing the tail rotational speed at between a 3:1 and 6:1 ratio with the main drive-shaft. In an automotive equivalent, this means that the rim rotation would have to increase at a multiplicative rate to the speed of the drive-shaft in order to maintain the same helical thrust on the surrounding air. Because rims are several orders of magnitude larger in diameter than the driveshaft, and connected via a reduction gear, they are always spinning at a fraction of the speed, meaning that the faster the car goes, the less effective the rims would become at producing a suction - the exact opposite of the desired effect. And the turbulance would greatly increase aerodynamic drag as well.
Something like it was tried in the 70's and 80's. However, the fan was completely separate from the rims, and it was oriented up and down, not side to side. It also functioned using a multiplicative gear-set (just like a helicopter tail rotor), as opposed to a tire rim, which uses both the transmission and differential as a reduction gear....the exact opposite. It was outlawed because it worked too well.
Sorry for the fluid dynamics and mechanical engineering lesson. I promise I'm done.
I'm aware of the history of the Brabham fan car (they got to keep their win, as they managed to prove that over 50% of the fan's energy was still for providing cooling, but the FIA closed the loophole after) but I was talking specifically about fan-blade rims.
Because titanium.
Old 06-22-2011, 01:23 AM   #189
Dimman
Kuruma Otaku
Dimman's Avatar
Originally Posted by dalli View Post
you are welcome
Double post to stay on topic...
How about with the Subaru-style wing?
Because titanium.
Old 07-11-2011, 05:43 PM   #190
Spencer Strayer
Drifter in Progress
Spencer Strayer's Avatar
Drives: 2013 Ultramarine FR-S, MKV GTi
man i really wish the tail lights would've stayed the same as they were at the geneva convention....
Spencer Strayer is offline   Reply With Quote
Old 07-11-2011, 05:44 PM   #191
Spencer Strayer
Drifter in Progress
you are welcome
dude whats that color called???
Old 07-11-2011, 06:42 PM   #192
Giccin
Giccin's Avatar
Blurple!
I am the Ice Queen.
Logic > Emotion
┬──┬◡ノ(° -°ノ)
TOYOTA FT-86
Old 07-11-2011, 07:11 PM   #193
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
Looks very similar to Yamaha 0564-Deep Purple Blue Metallic
Old 07-12-2011, 04:49 AM   #194
Dragawn
Drives: none
for the air ducts, wouldn't it be possible that they'll divert some of air going in the main vent to the brakes? I mean, we can't look behind that grill, can we?
As for the mule, I think it's a Subaru, just look at that spoiler! So typical for Subaru!
Same for these rims, but ofcourse Toyota could've borrowed them, but this seems unlikely to me.
And I think I've seen these taillights before on a Subaru, might be wrong. But rounder shapes is more Subaru's style than Toyota. Also a sudden change of taillights would be strange, since they said 95% of the concept car's looks gonna stay the same.
I still have hope for the FT-86! Though that unmasked mule doesnt look too bad IMO.
BTW, excellent chopping there.
Dragawn is offline   Reply With Quote
Old 07-12-2011, 05:12 AM   #195
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Sorry but no, Its been confirmed by SoA that the camo cars (a total of 5 thats been spied) are nor Subaru or Toyota...they are test cars, being use by both companies at the same time. The added aero and spoiler is also not belonging to either of the two exclusively.
Old 07-12-2011, 05:16 AM   #196
Kage
Drives: 2000 Celica Gts
Send a message via AIM to Kage
Now that you mention it the headlights (which I've grown to like actually) do look like they are from subaru, kinda has a simmilar overall shape to these
If those really are subaru's and toyota keeps their concept tails and headlights I'll be one hell of a happy camper
Originally Posted by Zaku View Post
I care first and foremost about what my needs are in the car and not to get "Props" from people. I'm not ricing it out for attention, I'm not flushing it to join a culture, I'm not keeping it stock for resale. I'm making this car for me and me only. And if you're my friend and club members that know me they'll respect that and respect is much better than props.
Kage is offline   Reply With Quote
First Spy Pics of Scion FR-S / Toyota FT-86 Production Test Mule! (Updated 5/17) Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 495 08-14-2020 07:15 PM
Subaru FT-86 mule - Autoblog update Sport-Tech BRZ First-Gen (2012+) — General Topics 39 11-01-2010 11:20 PM
FT-86 test mule spotted in germany near "the ring" again zigzagz94 Scion FR-S / Toyota 86 GT86 General Forum 5 10-27-2010 06:02 AM
Video of mule driving around. pe3nut FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 8 02-15-2010 05:06 PM
