Electronics | Audio | NAV | Infotainment Anything related to in-car electronics, navigation, and infotainment. |
02-24-2022, 12:26 PM | #183 | |
Drives: White 2013 BRZ Limited 6MT
The Following User Says Thank You to omegared19 For This Useful Post: | Nails (02-24-2022) |
02-25-2022, 08:54 AM | #184 | ||
Drives: 2016 Toyota 86
I ask because after having the AVH-ZL5150 for some time now, I realize how annoying it is to not have wireless CarPlay. I was hoping to find some way to run something like this USB/aux adapter to the cigarette lighter in the glove box and connect a wireless CarPlay adapter. I would like to retain functionality of the OEM aux port and still be able to use the OEM USB plug for power, but I am not sure if this is possible. |
02-25-2022, 10:33 AM | #185 | |
Drives: 2016 FR-S (Halo MT)
https://www.ft86club.com/forums/show...6&postcount=10 Since the AVH-ZL5150 only has one USB connector at the back of the head unit, it didn't make sense to me to retain OEM location since it no longer functioned. Now, if you got a new head unit with two USB ports, you could do exactly what you want by having it go to both the stock location and the glovebox. I think I did some research on splitting one USB connection to two locations, but came to the conclusion that it was a bad idea. For your situation, if you move the USB connection to the glovebox, you could add a USB charging adapter to the center armrest so that you could still charge your phone. |
The Following User Says Thank You to Nails For This Useful Post: | omegared19 (02-25-2022) |
02-25-2022, 11:37 AM | #186 |
This is the blank part from toyota that supposedly fits the usb/aux spot.
https://parts.toyota.com/p/Toyota__/...3952060B0.html I have not tried but plan to when/if the head unit I want ever comes back in stock. - Andrew |
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post: |
02-25-2022, 12:12 PM | #187 |
So in searching for the AVH-ZL5150BT, there's nothing for sale on places like Amazon/EBay, or anywhere domestically. I've found it in Australia and Malaysia. Does any one have any leads on where to buy? Or is there an updated model that'll have the same functionality?
02-26-2022, 11:49 AM | #188 | |
Master Collaborator
Here: https://www.pioneerelectronics.com/PUSA/Car Personally, I would stay away from Pioneer head units right now since they were bought out by a Chinese company a few years ago. Fortunately, the one I purchased last year was manufactured prior to the buy out and was still made in Japan. It may be a better idea to see what Sony, Kenwood Ecxelon or Alpine may have to offer until we hear about the quality of the new geration of Pioneer units. |
The Following 2 Users Say Thank You to FR-S2GT86 For This Useful Post: | omegared19 (02-26-2022), sato (08-05-2022) |
02-26-2022, 06:59 PM | #189 | |
The reason people want this head unit is the 200mm form factor. There are very limited options in this size. I don't think Sony or Alpine offer anything in 200mm. Kenwood has a few units, but they are designed for RHD markets and the buttons are on the wrong side. |
08-04-2022, 04:10 PM | #190 |
Good Job Subaru!
Drives: '17 BRZ, '24 CX-50
2022 bump! Still have the head unit in my car, still love it.
I updated the OP as AHH (AutoHarnessHouse) has updated the website to include a 2016-2017 Canadian BRZ specific harness on their direct-wire harness product page to alleviate the possibility of ordering an incorrect harness. This is because Canadian cars kept the original FujitsuTen Nav until 2017, whereas American BRZs got the newer Starlink unit from 2016 onwards.
The Following 2 Users Say Thank You to JBezugs For This Useful Post: | LimitedSlip (08-04-2022), Nails (08-05-2022) |
04-13-2023, 10:38 PM | #191 | |
Drives: 2017 Subaru BRZ Limited with PP
Edit: I did some more hunting and found what I needed, so I can hopefully fix this tomorrow: Pin 21 - SW1 = Tip of 3.5 mm plug Pin 22 - SW2 = Ring of 3.5 mm plug Pin 23 - SW Ground = Sleeve of 3.5 mm plug Edit 2: Nope, no go. When I first power up the receiver after installing and re-connecting the battery, I see the Steering Wheel Controls menu item and can go into it, but none of the buttons will learn. After that, it's grayed out. I've tried soldering the cable a couple of times. It tones out just fine on my multi-meter, so assuming the above is the correct wiring, I'm stumped why it doesn't work. Last edited by jredders; 04-17-2023 at 10:21 PM. |
04-17-2023, 10:29 PM | #192 |
I also picked up a CD-MC20 AutoEQ mic off eBay. After running the auto-eq, is it normal for the rear speakers to be set to -21/22 dB while the fronts are -1/-2? This is with the Front Left setting enabled. It basically kills what little base is available (I have no Subwoofer) by only using the front speakers. Also, going much over 18-19 on the volume sounds like it's clipping the AMP to the front speakers. Android Auto is so nice, but I'm starting to question the whole purchase otherwise.
04-19-2023, 02:37 PM | #193 | |
Master Collaborator
Okay, we need to back up and get a little more information from you. Do you have a build thread of your system? If you do, can you post the link to the thread and I'll go over it with you to see if we can figure this out. I'm suspecting that you just need to adjust the gains on your amp(s). |
04-20-2023, 09:40 AM | #194 | |
Good Job Subaru!
Similar Threads | ||||
Looking for suggestions on what carplay compatible head unit to get. | wparsons | Electronics | Audio | NAV | Infotainment | 8 | 03-02-2018 08:09 AM |
Android head unit | drz400dude | Electronics | Audio | NAV | Infotainment | 6 | 12-20-2016 12:47 AM |
200mm android head unit with android lollipop | rsingh | Electronics | Audio | NAV | Infotainment | 3 | 05-23-2016 08:48 PM |
New 200mm head unit from Pioneer AVIC-F7302 | Clot | Electronics | Audio | NAV | Infotainment | 8 | 09-16-2014 11:39 AM |
Android head unit | drei | Electronics | Audio | NAV | Infotainment | 21 | 07-16-2012 02:42 AM |
