Old 09-12-2017, 07:52 PM   #183
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
Aren't they taking bids from the tire companies on who gets to be the spec tire? My assumption was since this is all through Tire Rack they're going to accept offers on which company supplies the spec tire so they can profit while keeping costs lower than elsewhere to incentivize people purchasing through TR.
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
The Following User Says Thank You to Locust For This Useful Post:
strat61caster (09-12-2017)
Old 09-12-2017, 11:27 PM   #184
bslate3
Drives: 2015 CWP BRZ
How do they say you can race a spec twin in STX too when the spec twin is allowed to have rear lower control arms AND rear toe arms too?
bslate3 is offline   Reply With Quote
Old 09-13-2017, 12:09 AM   #185
14stu
14stu's Avatar
Drives: 2014 Subaru BRZ
There is precedence with Spec Miata in DSP, basically they recognize that the non-class legal upgrades are less helpful than the mods they aren't allowed to use.
The real question is if they can use a non-spec tire when running in STX, like the Spec Miatas can run any DSP legal tires.
The other option is to allow rear toe arms in STX, since those are the only parts from SSC that aren't STX legal in the first place. Really, the either or rule is silly (same with some of the issues with allowing things like LCA's but then outlawing the most common types).
They should open things like oil coolers to all classes so SSC (and others) can track an autocross car more reliably, SCCA wants to try to expand participation but they hyper manage classing and disciplines so much that crossover is nearly impossible.
14stu is offline   Reply With Quote
Old 09-13-2017, 01:30 AM   #186
strat61caster
strat61caster's Avatar
I believe the SPC toe arm is legal in conjunction with any legal LCA in Street Touring, just ordered a pair today to help with my alignments. If the bushing measures out as legal per the metal/non-metal rule I'll use them. Ball joint on the outboard side is same as OE from what I can tell. And it looks like there's a Whiteline option that looks legal if you want something prettier, but that won't be legal in SSC.
I think we've just been reading the rule wrong. It's not a huge benefit, just nice for diyers.
http://www.ft86club.com/forums/showp...postcount=2867
ineedyourdiddly
Old 09-13-2017, 03:07 AM   #187
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
I assume there will be clarification on tire usage for STX in the future. As for illegal STX parts (just for clarification), I believe the LCA is the only illegal part due to the bushing.
G_Ride is offline   Reply With Quote
The Following 2 Users Say Thank You to G_Ride For This Useful Post:
Shark_Bait88 (09-13-2017), strat61caster (09-13-2017)
Old 09-13-2017, 02:00 PM   #188
Ragin Gti
Drives: '15 Subaru BRZ
I have the Strano front bar and stock sway bar links, no clunking or noise.
Ragin Gti is offline   Reply With Quote
The Following User Says Thank You to Ragin Gti For This Useful Post:
ApexEight (09-13-2017)
Old 09-13-2017, 08:38 PM   #189
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
I didn't see it spelled out anywhere, but can we still use spacers/extended studs to get to the 40mm offset with the wheels we choose?
Twinz is offline   Reply With Quote
Old 09-13-2017, 08:40 PM   #190
Locust
Custom User Title
Locust's Avatar
At this point I'm proceeding with the assumption that cat-back, brake pads, and drop-in filter are all being run under the street class rules. Has anyone heard otherwise?
LOCUST
Instagram:
LocustAutoX
Sponsors:
Old 09-13-2017, 10:00 PM   #191
JakeRogue
JakeRogue's Avatar
Drives: 2014 Monogram FR-S
I inferred the same thing from the press release.
JakeRogue is offline   Reply With Quote
Old 09-13-2017, 10:06 PM   #192
Biggins
Drives: Yes
Will local regions follow suit and offer SSC as an actual class? I know the regions have flexibility in classing at the local level, but I wonder if some regions determine the SSC cars have to run in STX or SP or only on PAX or something?
Biggins is offline   Reply With Quote
Old 09-13-2017, 10:42 PM   #193
Twinz
Twinz's Avatar
My local gets their class list from the SCCA every year, but there is another group I run with that uses none of the SCCA classes directly.
I would expect clubs that use SCCA classing to include SSC next year.
Oh, and nice meeting you at Nationals!
The Following User Says Thank You to Twinz For This Useful Post:
Biggins (09-13-2017)
Old 09-13-2017, 11:23 PM   #194
k3v
Drives: 2013 Series 10
Same here.
Well, I did have a clunk after my second autox event. I torqued the endlinks and haven't had a clunk since.
k3v is offline   Reply With Quote
The Following User Says Thank You to k3v For This Useful Post:
ApexEight (09-15-2017)
Old 09-14-2017, 11:01 PM   #195
Open Loop
2013 FR-S Whiteout / SSC
I also am using the stock sway bar links with my Strano front bar and I have no clunks. I HAD clunks and it took me a while to chase it down but it turned out to be a lose sway bar end link nut. Simply put, I had to spend time and energy controlling the rear end when auto crossing, and would occasionally spin, before installing the Strano bar. Now it's just "point and shoot."
Open Loop is offline   Reply With Quote
The Following User Says Thank You to Open Loop For This Useful Post:
Old 09-15-2017, 01:46 AM   #196
ApexEight
Drives: 2014 Subaru BRZ Limited 6MT SSM
This is great. I have a hard time with the rear end on my stock BRZ as well. In just about any corner I attack, unless it's cambered, it feels like rear end is standing on its hind legs or like its tippy toes instead of hunching down and gripping, even if I'm managing the balance of the car (i.e., not lifting mid corner). I hope my Strano bar also helps with this
ApexEight is offline   Reply With Quote
Upgrading brakes on the lower spec GT86 (the standard spec outside of US market) OnionTou Suspension | Chassis | Brakes -- Sponsored by 949 Racing 55 07-01-2016 02:36 AM
what's the difference between twin screw, centrifugal, single turbo and twin turbo? warplane95 Forced Induction 86 04-17-2014 03:36 PM
my twin RWDGUY Mid-Atlantic 2 04-08-2013 10:23 PM
JDM Spec-C V9 Twin Scroll VF36 complete Nico TURBO Engine, Exhaust, Bolt-Ons 0 12-05-2012 12:20 PM
