Old 03-21-2016, 08:02 PM   #183
S84kam
S84kam's Avatar
Drives: FBRZS
Damnit. The rear struts. I put the springs upside down. (The tightly coiled part on the bottom). Totally missed that part. Anyone know for it's ok to leave as is?
S84kam is offline   Reply With Quote
Old 03-22-2016, 05:03 PM   #184
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
I would re-do it
The Following User Says Thank You to zc06_kisstherain For This Useful Post:
S84kam (03-22-2016)
Old 03-22-2016, 06:59 PM   #185
S84kam
S84kam's Avatar
Drives: FBRZS
Originally Posted by zc06_kisstherain View Post
I would re-do it
Just re-did it. Wow what an improvement. The ride isn't so jarring. Very happy that I spend the extra hour to re do my mistake!
Old 06-11-2016, 02:44 PM   #186
Hi_Psi
GotBoost?
Drives: 2013 Raven Pearl (D4S) GT86
Bout to install the trd 1 1/8 lowering springs, wish me luck!!!!
Hi_Psi is offline   Reply With Quote
Old 06-14-2016, 03:07 AM   #187
Hi_Psi
GotBoost?
Took me about 2hrs to do it all thanks buddy
Old 06-29-2016, 09:08 PM   #188
marusteri
Drives: 2013 BRZ Limited AT
more about those damn clips
Thanks for the DIY, it helped when I replaced front suspension yesterday. The two clips for the speed sensor were a pain so I took some pictures trying to provide more details.
The top clip has 4 hooks (one of each side) and all 4 need to be pushed in while you pull the clip out using your fifth hand The picture shows the top and bottom hooks with green arrows and one of the side hooks (the other is on the invisible side) with a blue arrow. The side hooks (blue) may be a bit ahead of the top and down hooks (green) so you may try to squeeze the side hooks first, pull the clip enough so that you get past the side hooks and then squeeze the top and down hooks and finally pull the clip all the way out. I don't remember how I did it exactly, I just remember cursing.
I replaced the whole struts so I needed the clip out. But if you just replace the springs you may (and you should 'cos it's muuuch easier) leave the clip in the strut and just remove the wire from the clip. To do this, slide the screwdriver between the two tabs (marked with red and yellow dots in the picture) and push the red tab to the left. It will move easily and pop out so you can remove the wire with the rubber bushing out of the clip.
For the bottom clip it's easier, it just has 2 tabs on top and bottom (green arrows)
Florin
marusteri is offline   Reply With Quote
The Following User Says Thank You to marusteri For This Useful Post:
zc06_kisstherain (08-05-2016)
Old 10-25-2016, 09:45 PM   #189
dylanxsanchez
dylanxsanchez's Avatar
Drives: Scion FR-S
Thank you!
Just finished installing the Eibach Sportlines and this guide was essential. Thank you!
dylanxsanchez is offline   Reply With Quote
Old 11-02-2016, 03:57 AM   #190
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Originally Posted by rick s View Post
Who is correct?
Rear shock mount orientation
Devoris "Red tab faces front of car "
or Fizz
"Sorry for the old post revival guys, but I just wanted to inform anyone attempting this DIY that the tab (for rear shock) faces the rear...not the front of the car. I've double checked this on another stock 86 just to be sure.
You can easily check this prior to removing your rear shocks by looking closely through the hole where you'd insert the socket to remove top nut.
So which one is correct? I've removed my rear struts have been swapped out 3 times and no longer have a stock point of reference nor recall if I stayed consistent with the orientation every time.
I'm guessing this the tab sticking up toward the top back right of the picture is what we're all referring to:
Old 11-05-2016, 01:22 AM   #191
Norinradd
Drives: 2013 frs
Installed some trd coils today.
Everything went smoothly accept the rear bumpstops confused me, When sliding it on, and i installed as per directions. Small hole up. It slid quite easily over the collar on the shock rod. And just is sitting on the bottom of shock rod ontop of the strut cylinder. The fronts were snug on collar but could still be pushed down past collar quite easily. I tried to bring the bumpstop up over the collar. Tried to wedge it up with a flathead. I couldnt get it back up over the collar. On either shocks (yes happend on both:/) Ended up installing them with bumpstops on bottom of shock rod. As it started raining and im working outside , in a sketchy neighborhood with vehicle on jackstands.
Now i figured if the strut were to essentially bottom out, Or come close. The bumpstop will go back up into collar.
Right or wrong? Please and thanks
2013 silver frs, injen intake, agency power header, hks exhaust, no kitties, ecutek tune
Norinradd is offline   Reply With Quote
Old 11-05-2016, 01:26 AM   #192
Norinradd
Drives: 2013 frs
I should add the instructions state, "Install the new TRD bumper onto rear shock shaft" ..doesnt say snug to collar.
Anybody know if i should take them out again and really try to snug the bumpstops around collar. Lube it up. Haha
Old 03-08-2017, 05:49 PM   #193
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
Huge thanks for this DIY thread!
I just installed my STI springs. I feel so damn good about it too haha
I was going to have a shop do it, but once I got the price quote...I told myself no way...I'm going to do this!
Feel so accomplished....guys, you can do it too! Save your money and just get another set of helping hands
2018 Subaru WRX STI ~ The Weekend Car ~
2015 Toyota 86 ~ The Sold Car ~ Build Journal
OFT Stage 1 Tune Review
Mr.Impreza is offline   Reply With Quote
Old 04-25-2017, 11:00 PM   #194
Markk
Drives: 2015 Scion frs
[QUOTE=switchlanez;2787864]So which one is correct? I've removed my rear struts have been swapped out 3 times and no longer have a stock point of reference nor recall if I stayed consistent with the orientation every time.
[/QUOTE
Sorry to revive this post too, but I'd like to know the rationale for this tabs position and if it matters? I tried to look around but I couldnt find an answer.
Markk is offline   Reply With Quote
Old 04-26-2017, 02:34 PM   #195
strat61caster
strat61caster's Avatar
As far as I can tell the part is symmetrical and the tab is irrelevant to owners.
Things like that may be used for manufacturing purposes like locating the rubber during assembly as it's pressed into the metal part. I'm sure there's a 'correct' way to put it in, but I don't think it matters, I long forgot as I've taken mine apart and put it back together dozens of times.
ineedyourdiddly
Pat (11-05-2017)
Old 04-26-2017, 05:15 PM   #196
switchlanez
[quote=Markk;2898987]
[/QUOTE
According to this, the OEM put red markings on front and rear strut tops for reference to orient them toward the front of the vehicle.
[ame="https://www.youtube.com/watch?v=Fam1rJSGcx8"]Scion FR-S KW Suspension Step-by-Step Installation - YouTube[/ame]
The Following 2 Users Say Thank You to switchlanez For This Useful Post:
Pat (11-05-2017), strat61caster (04-26-2017)
Replacing the Scion FR-S seats bloomy116 Scion FR-S / Toyota 86 GT86 General Forum 36 11-09-2012 01:41 PM
Installing TRD Parts / Locating a good shop Re~Mix Engine, Exhaust, Transmission 9 06-12-2012 01:05 PM
T1R Coil-over suspension AJ PwR Brakes, Suspension, Chassis 33 05-29-2012 11:07 PM
Handling: Camber Attainable with Struts. Your Experiences? skeeler Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 11-09-2011 05:07 PM
