| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#19153 |
ProCrastinationConsultant
in some ways, it's sorta funny considering the origins of australia...
#19154 |
Drives: SWP BRZ
brought home this baby today.
![]() 911 next time lol |
#19155 |
Drives: Crapcan
Went to the track today. Ran a set of SX2's back to back against a set of RT660's. The 660's where 2sec/min quicker on a track I had only driven for the second time in 3 years. Very good feel, sidewalls seem decently stiff even when I took the car out on it's warm up laps with 30psi cold pressure. They seem to be happy at 35-37 psi hot. Got a little greasy at the end of 20 min but they didn't drop off hard as they got hot. Ambient today was in the high 80's.
I also tested running my GTC200 with the factory spoiler with a Perrin gurney flap. Then removed the gurney flap, then the stock spoiler. Definitely made a difference but I say the drag penalty from running those other parts isn't worth what you gain. Car felt a bit looser but I preferred it that way as it was easier to rotate in the fast corners. I removed the risers from this GTC200 so it sits 3.25 inches lower then out of the box. Much happier with this setup.
#19156 |
Drives: Subaru BRZ
#19157 |
Howdy
Drives: 2020 BRZ PP
Happy Father’s Day to all the Dads out there. Hopefully you get some new cologne:
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
#19158 |
Drives: Subaru BRZ
#19159 |
Drives: Crapcan
Also forgot to mention was my first time running E85 on track. Holy hell what a difference. I am actually quite happy with the power the car makes now. Downside is I noticed I need to upgrade my radiator. I was hitting close to 240F and having to cool the car down or just pull off the rest of the session. I started noticing last couple years I could hit 230F on water temps and though it was an issue with my cooling stack. Nope, still not better. Koyo Rad on the way.
#19160 |
Drives: 2020 BRZ Limited
Vanity plates finally arrived and gave it a much needed wash after back-to-back weekend road trips.
#19161 | |
Drives: 18 Brz (Sold) / 22 BRZ / 13 BRZ
#19162 |
Drives: 2022 MT Neptune GR86 Prem.
#19163 | |
Drives: Crapcan
My car is also splitter, diffuser, and medium wing.
#19164 |
I have the flapper and at Cressen through Horseshoe, Boot Hill, Tombstone(all one big left around 270 deg) it will starve coming out if below 3/4 tank.
#19165 | |
Drives: 2019 BRZ Sport-Tech RS
-Dry-clean: Use a shop-vac on reverse (or a blower attachment from an air compressor) to blow away loose dust from entire engine bay. -Protect: Cover alternator and engine block with garbage bag. -Degrease: Spray degreaser on surfaces in the engine bay and on the underside of the hood that I want cleaned - avoiding any electrical wiring. Agitate the degreaser with a soft brush to loosen the grease/dirt. -Rinse: Use a garden hose on the MIST setting to gently rinse away the degreaser. Don't use a high pressure stream or a pressure washer. -Dry: Using the shop-vac on reverse again, blow away the a water from the areas you rinsed. -Detail: Remove the plastic bag. Now with a rag and degreaser, use some elbow grease to gently clean any area that was covered by the plastic bag and anything you may have missed. -Dress up: Using your favourite plastic/rubber protector spray and a clean rag, apply some to any dull plastic cover and rubber hoses to restore their shine. Not really required for newer cars, but might be a good idea for cars that have seen a lot of mileage. -Reconnect battery. -Admire your OCD. Last edited by N_Raged; 06-22-2021 at 06:25 PM. |
#19166 |
Drives: Crapcan
I am thinking I will be okay, the big constant radius turn I take a shallow entry and double apex it. I guess I will find out for sure on the 17th. I would like to have that sorted before the SCCA TT even at that track at the end of July.
| Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
| Got my new FR-S today. | Boosted2.0 | Scion FR-S / Toyota 86 GT86 General Forum | 51 | 06-03-2012 10:35 PM |
| Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
| Got my VIN today... | Enemies | BRZ First-Gen (2012+) — General Topics | 63 | 04-12-2012 10:19 PM |
| sat in a BRZ today | NESW20 | BRZ First-Gen (2012+) — General Topics | 8 | 03-31-2012 08:53 AM |
