Old 12-01-2013, 01:46 AM   #18831
asher187
Drives: 2013 FR-S, 1995 Civic Coupe
Originally Posted by ChandlerSwyng View Post
Don't know much about turbos... How much is a full kit for our cars?
$3500-6700+ and more more more
asher187 is offline   Reply With Quote
Old 12-01-2013, 01:35 PM   #18832
nelsmar
This.
Depends on the power you want, quality you want, who tunes it, if you dyno it, if you do a clutch... lots of things to consider.
Making lower power you can use a full OEM setup, if you want e85 youll need to upgrade injectors & pump... that adds 300-500$ right there. But once you pass a point the clutch wont hold thats 450-1000 depending on your desires.
My flickr - Canibeat
Local magazine scout
Old 12-01-2013, 01:41 PM   #18833
ChandlerSwyng
ChandlerSwyng's Avatar
Drives: 2013 Red Subaru Brz
Originally Posted by nelsmar View Post
This.
I'm thinking of staying with lower power but something that will give it some unf. Maybe a 250-270 hp kind of range
Old 12-01-2013, 02:00 PM   #18834
jack43
jack43's Avatar
Drives: Sterling Silver BRZ Limited MT
Just my experience (read or delete as you like) is that the results of a 'stage 1' basic
FI were kinda disappointing. This was when I just had the Vortech on low boost and pump gas at 250whp or thereabouts.
There is a straightaway on Mt Lemmon at a 7% grade, and when I matted the throttle down not that much happened. "How much did I spend for this?" crossed my mind.
Then with more boost, there were a lot of supporting mods -- e85 flexfire, pump and injectors, clutch, radiator, oil cooler, engine mounts, plus some suspension and brake upgrades. I never had a powerful car before but that same straightaway feels like it's going to rip off my face! This was when all the time and money, plus sacrificing the warranty, all made sense.
If I could do it again, I might wait for someone dumping their fully modded car, maybe selling my (stock) car to get it.
I lost count at over a dozen fully-tits turbo and SC projects that have been dumped in the classifieds at a huge loss, for about what they would get without any mods.
jack43 is offline   Reply With Quote
Old 12-01-2013, 02:32 PM   #18835
nelsmar
JDL is local, they make a turbo kit (without a tune) with quality hand made parts. And top shelf turbos... no cheap shit. One of their kits with say a GTX2867 and OEM fuel system would get you what you want at 4,500-5,500 after dyno tuning. There are some cheaper alternatives as well. I personally prefer to support local.
Old 12-01-2013, 08:45 PM   #18836
captain_jack
captain_jack's Avatar
I did not realize they made a kit actually. I may look into that....is anyone running their twin scroll kit?
sent from your mom
Old 12-01-2013, 09:02 PM   #18837
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
They make several kits, including a twin scroll.
^GT5 Replay Photo Mode^
Old 12-01-2013, 09:28 PM   #18838
nelsmar
sent from your mom
They got crazy busy with their headers that they haven't produced many turbo kits for the car yet. Their shop car had their twin scroll kit in. Aaron @ FAT is using their UEL single scroll setup on his build. Looks like 3-4 of us might have their kit running in the next 2-3 months.
Old 12-01-2013, 10:03 PM   #18839
SirBrass
SirBrass's Avatar
I'm curious as to what they can do for builds which aren't "big power" builds. That is, I'm not interested in running e85 and 16psi for my FI build. e85 might be nice to be able to use (a la flexfuel sensor and mod), but I'm not interested in running more than 7psi of boost with e85 on stock compression pistons, or 5 psi if it's on ACN91 pump gas.
What are the benefits on our cars if we run twin scroll as compared to single scroll, btw? And just to make sure I'm clear on what I'm asking, twin scroll is basically two turbine wheels on one compressor wheel (that is, one side of the engine drives one turbine wheel and the other side drives the other turbine wheel). How is that beneficial over a single scroll turbo? Downsides?
Old 12-01-2013, 10:52 PM   #18840
nelsmar
It is designed to smooth out the pulses from the engine. Honeywell has some studies on it I would have to find them. In the tuner world it is seen as debatable for lower power vehicles, and still sometimes debatable in high power applications. There are a number of people showing no gain, and a number of them showing a wonderful spool time gain & top end gain with larger compressors. This may however have to do with short runners not allowing the pulses to be smoothed. The tuner world doesn't always do reputable methods of testing though :P
Personally I was interested in doing UEL as it can give a high pressure "burst" right off the bat giving the ability to start the spool process quicker at low loads, but typically doesn't do as well at high end when equally distanced pulses help keeping the turbine spooling. Basically you get a big BURST of pressure to spin the compressor and it is "winding down" until the next burst come in. Runner length, order, and twin scroll are methods of altering how the pulse affects the turbine.
And it is actually 1 turbine wheel. But in a twin scroll you have two exhaust housings basically stacked upon each other, one small designed to give "high pressure" and one larger to give lower pressure, higher flow. This is designed to "balance out" low and high power kind of like running two AR compressor housing at the same time.
To do this properly you need to A) use two waste gates and a manifold that splits the exhaust gases, or B) an internal waste gate that will split it for you. This is why twin scroll is seen as more expensive. For low power it is a decent spike in cost, looking at 500-1,500 increase in cost typically to go to a twin scroll.
I have multiple friends that build turbo kits for a living and some say its a waste of money, others say its wonderful. I personally lean on the side of it is beneficial for allowing you to run a larger compressor and have the spool time of a smaller one (as in it helps). I can't find much saying it really is negative except a few tests done a few years ago. Originally I planned on doing a GTX2867R twin scroll but i decided I just don't care to spend the money and would rather go EUL to spike the boost and if the top end falls off a few HP it is worth it for the cash I save.
Old 12-01-2013, 11:06 PM   #18841
SirBrass
SirBrass's Avatar
I wouldn't be against making big power if this motor wasn't already running such high CR pistons. As it is, with the high CR, I'm very leery of high boost on this motor considering how absolutely abysmal our gas is here, and how irregular the E85 availability is.
Only reason I'm still considering a turbo setup is that while I like the easier setup of SC, it's still "lose power to make power", and I like the idea of extracting more power from gasses in the combustion cycle that weren't used (exhaust gas) to make that power.
Old 12-01-2013, 11:09 PM   #18842
nelsmar
ignore the lose power to make power bullshit, its not that much. Look up my dyno vs turbo dynos and you'll see i was very, very close to others using the same tuner. The twin screws lose more power... but still. Thats a whole different topic all together. Our fuel is garbage yes. And high compression + high octane quality fuel doesn't matter. E85 is plentiful in the valley and when E85 is being used the compression is almost completely non-important. Compression makes a massive difference with the knock wall on low octane pump fuels. But if your not comfortable with E85 just keep the boost low, depending on the kit, exhaust, and tune, 7-12psi would work.
The only reason Im not putting a stock block back in my car and doing it again (because i was DAMNED happy with my blower setup) was I know ill get the itch eventually... and want more. So I may as well spend a few dollars more and just build the block up.
Old 12-01-2013, 11:41 PM   #18843
BugeyedWagon
Suby Specialist
BugeyedWagon's Avatar
Guys,
Quick question for the group....
I'm looking to trade my leather/alcantara BRZ limited seats (front/rear) for FRS or BRZ Premium (front/rear) seats + $650.
To be clear, I would get your seats and $650 and you would get my limited seats. I am extremely picky and will only trade for an interior as flawless as mine.
I am also looking to trade for someone's frs dash panels for my silver ones.
PM me if you're interested. Thanks.
Old 12-01-2013, 11:51 PM   #18844
BugeyedWagon
Suby Specialist
Volk GT-C 18x7.5 +43 5x100 (Set Of 4 Wheels) Frs Brz Wrx
Someone from the local community please come buy my Volks. They can be ridiculously nice/rare show wheels with a little TLC.
$400 FIRM
As has been said before, the set is rashed up on all four corners, but there are no bends.
