, dpfarr
Old 11-21-2016, 11:47 PM   #1863
GT86Asia
Drives: 2016 BRZ
Originally Posted by taiguy View Post
just curious, what sort of mpg are you getting with the DT?
the BEST I have gotten, driving like a grandma, shifting even BEFORE the "suggested" shifpoints that the car flashes, is 17.7mpg
when I don't care, which is most of the time, it's 16.6mpg,
Oh, and I havent added a single drop of normal gas since May, so every mile since then has been with e85, I can only get 210-220 miles from one full gas tank of e85.
GT86Asia is offline   Reply With Quote
The Following User Says Thank You to GT86Asia For This Useful Post:
CSG Mike (11-22-2016)
Old 11-21-2016, 11:58 PM   #1864
Silverfox
Silverfox's Avatar
Drives: 2013 Subaru BRZ, Edelbrock SC, E-85
I knew mpg was bad with E-85, but damn.... 😳
Silverfox is offline   Reply With Quote
Old 11-22-2016, 12:53 AM   #1865
menikmati
Drives: 2015 BRZ, 2005 STI
As far as MPG, I've gone 280 miles without the low fuel light so I'm guessing I'm near my original 30 MPG I was NA on 91 octane.
My average MPG when running full E85 NA was around 24-25 and driving like a grandma.
I just received my Delicious tune from Zach today and will be doing some datalogging to get the tune refined. I immediately found it easier to start from a stop on the Delicious tune. For some reason with the Edelbrock CARB tune, the RPMs would dip severely when letting the clutch out, resulting in more gas added and clutch slipping to get a smooth start.
menikmati is offline   Reply With Quote
The Following 2 Users Say Thank You to menikmati For This Useful Post:
CSG Mike (11-22-2016), Silverfox (11-22-2016)
Old 11-22-2016, 01:58 AM   #1866
Silverfox
Silverfox's Avatar
Not too bad. I need to datalog as well. This is my first time having a car professionally tuned so I'm learning as I go. Finally got ecupro setup on my laptop so I can begin. Still feels like the matrix to me haha.
The Following 2 Users Say Thank You to Silverfox For This Useful Post:
CSG Mike (11-22-2016), sato (11-22-2016)
Old 11-22-2016, 10:25 AM   #1867
GT86Asia
Drives: 2016 BRZ
And you have the larger gas pump and larger injectors?
Where do you usually get your e85, propel or G&M?
Old 11-22-2016, 12:46 PM   #1868
menikmati
I am running 91 octane only with the Edelbrock kit, no Flex Fuel at this time. Stock fuel pump and injectors.
I was getting my E85 from Chevron stations (G&M) and my ethanol content was usually around 80%.
Old 11-22-2016, 07:44 PM   #1869
taiguy
Drives: 2013 Black BRZ Limited
OK. I'm averaging 19-20 mpg and that's on 91 octane gas with the edelbrock CARB tune.
taiguy is offline   Reply With Quote
Old 11-23-2016, 02:53 AM   #1870
menikmati
First fill-up after going FI and I got 27.2 MPG.
Rock solid idle at 900 RPM with the Delicious tune, no 500-1.1k RPM idle hunting.
The Following User Says Thank You to menikmati For This Useful Post:
CSG Mike (11-23-2016)
Old 11-23-2016, 03:03 AM   #1871
Silverfox
Silverfox's Avatar
See you at sub 25 mpg soon haha
The Following User Says Thank You to Silverfox For This Useful Post:
Old 11-23-2016, 03:20 AM   #1872
menikmati
I'll join the sub-20 club once I go Flex Fuel.
For now, driving like a grandma with the occasional on-ramp pull.
Silverstar (11-27-2016)
Old 11-24-2016, 01:59 PM   #1873
GT86Asia
Drives: 2016 BRZ
Ah, no wonder you were on the 20's for gas milage, haha.
how r you checking your ethanol content?
i try not to use G&M because their mix advertised range is much lower than Propel. They advertise 50%-70%Max, while propel guarantees Min 70% and Max 85%.
however G&M is cheaper by 10-20 cents pergallon as compared to Propel.
Cheers,
Old 11-24-2016, 02:56 PM   #1874
menikmati
Cheers,
I have the Delicious Flex Fuel kit and I use their Android app for ethanol content.
Old 11-24-2016, 06:18 PM   #1875
VeganGirl
Drives: Scion FR-S 2013
Does anyone run this kit with borla headers? Is it compatible?
VeganGirl is offline   Reply With Quote
Old 11-24-2016, 07:02 PM   #1876
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Compatible with any header, as long as you have the appropriate tune ie won't work if you use the supplied CARB tune but an e-tune like a Delicious tune or a local tuner will work.
The Following User Says Thank You to BigFatFlip For This Useful Post:
CSG Mike (11-25-2016)
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
