#1863 |
Drives: 2016 BRZ
the BEST I have gotten, driving like a grandma, shifting even BEFORE the "suggested" shifpoints that the car flashes, is 17.7mpg
when I don't care, which is most of the time, it's 16.6mpg, ![]() Oh, and I havent added a single drop of normal gas since May, so every mile since then has been with e85, I can only get 210-220 miles from one full gas tank of e85. |
| The Following User Says Thank You to GT86Asia For This Useful Post: | CSG Mike (11-22-2016) |
#1864 | |
Drives: 2013 Subaru BRZ, Edelbrock SC, E-85
I knew mpg was bad with E-85, but damn.... 😳 Sent from my iPhone using Tapatalk |
#1865 |
Drives: 2015 BRZ, 2005 STI, 2024 Type R
As far as MPG, I've gone 280 miles without the low fuel light so I'm guessing I'm near my original 30 MPG I was NA on 91 octane.
My average MPG when running full E85 NA was around 24-25 and driving like a grandma. I just received my Delicious tune from Zach today and will be doing some datalogging to get the tune refined. I immediately found it easier to start from a stop on the Delicious tune. For some reason with the Edelbrock CARB tune, the RPMs would dip severely when letting the clutch out, resulting in more gas added and clutch slipping to get a smooth start. |
#1866 | |
Not too bad. I need to datalog as well. This is my first time having a car professionally tuned so I'm learning as I go. Finally got ecupro setup on my laptop so I can begin. Still feels like the matrix to me haha. Sent from my iPhone using Tapatalk |
#1867 | |
Drives: 2016 BRZ
Where do you usually get your e85, propel or G&M? |
#1868 | |
I was getting my E85 from Chevron stations (G&M) and my ethanol content was usually around 80%. |
#1869 | |
Drives: 2013 Black BRZ Limited
#1870 |
First fill-up after going FI and I got 27.2 MPG.
Rock solid idle at 900 RPM with the Delicious tune, no 500-1.1k RPM idle hunting. |
| The Following User Says Thank You to menikmati For This Useful Post: | CSG Mike (11-23-2016) |
#1872 |
| The Following User Says Thank You to menikmati For This Useful Post: | Silverstar (11-27-2016) |
#1873 | |
Drives: 2016 BRZ
how r you checking your ethanol content? i try not to use G&M because their mix advertised range is much lower than Propel. They advertise 50%-70%Max, while propel guarantees Min 70% and Max 85%. however G&M is cheaper by 10-20 cents pergallon as compared to Propel. Cheers,
#1874 | |
#1875 |
Drives: Scion FR-S 2013
Does anyone run this kit with borla headers? Is it compatible?
#1876 |
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
| The Following User Says Thank You to BigFatFlip For This Useful Post: | CSG Mike (11-25-2016) |
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 10:09 PM |
