Old 06-20-2014, 04:24 PM   #1849
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by mike the snake View Post
Does the BOV spring pressure need to be changed when running higher boost?
Or is it more about how much vacum you have at idle?
The vacuum is what opens the BOV up. It doesn't care how much boost you are running as that just means it is further from vacuum.
Old 06-20-2014, 04:28 PM   #1850
mike the snake
Thanks. I Juuust was watching some BOV vids and figured out how they work.
Old 06-20-2014, 10:39 PM   #1851
69Marshall69
69Marshall69's Avatar
Drives: 2013 Subaru BRZ-S
I would say the correct spring is an 11 or 12 psi spring. I ended up most happy with an 11 psi spring and a couple aluminum washers I got from McMaster Carr. This will vary slightly depending on how much vaccum your car pulls at idle and where/how you are getting the vacuum/boost reference that you are running to the BOV.
Thanks King Tut for the quick reply, I have recently reconfigured my vacuum lines to create a safer boost environment by tapping the turbo housing and running that directly to the wastegate so there's less of a danger of boost increase going engine kabooom. The vacuum lines are seperate from that, running from the brake vacuum line as directed by FBM's kit install instructions. My boost gauge shows a max negative vacuum of -19 to -21, at idle its still very close to this negative pressure. So i was wondering if maybe it were impossible to have the BOV work off that vacuum area properly? if there is a possibility of running a different vacuum that has a greater pressure difference from boost release and idle?
ps- it is proper to have the BOV shut at idle and open at full vacuum?
cheers
69Marshall69 is offline   Reply With Quote
Old 06-20-2014, 10:40 PM   #1852
pleong
Drives: 2013 Whiteout FR-S
Just got the car back a few hours ago and the fans died already...
TEAM NEMESIS | NEM 86 | IG: @NEM_86
PTE5858 Turbo | Integrated Engineering Fuel Surge Tank | 1300cc Injectors | Exedy Twin Disc | RAYS Volk ZE40 | 295/30/18 | 522whp @ 6,600 Dyno Dynamics
The NEM86 Build Thread
pleong is offline   Reply With Quote
Old 06-20-2014, 10:42 PM   #1853
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
yeah mine died too in the parkinglot after rolling it off the dyno. I managed to stuff my stock fans in there until I figure out what I want ro do next.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Old 06-20-2014, 10:43 PM   #1854
pleong
I'm installing the new rad and rad shroud tomorrow..
Old 06-23-2014, 08:43 AM   #1855
Dipstik-sportech
Dipstik-sportech's Avatar
So I finally got away from the snow and went south to BIR this weekend.
Ran over a dozen passes on Kato and drove him home 6hrs without a problem.
I'm car 10148, had some wheelhop issues in first gear and on occasion he would spin second so bad I would drift lol. All said he ran decent and I'm a set of slicks and a 3.73 diff away from 10's I think.
The Frozen North
Old 06-23-2014, 09:49 AM   #1856
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Attachment 82959
The Frozen North
Good Job Cale
FullBlown is offline   Reply With Quote
Old 06-23-2014, 09:53 AM   #1857
King Tut
NASA SpecE30 Racer
King Tut's Avatar
cheers
Idle should be very close to full vacuum. The only time you get into a larger vacuum situation is when off throttle and engine braking. Ideally you will want the BOV shut in both conditions or you can get into a situation where the car could stutter and possibly stall in those engine braking situations when you quickly stick the clutch in.
Old 06-23-2014, 09:55 AM   #1858
King Tut
NASA SpecE30 Racer
King Tut's Avatar
The Frozen North
Plenty of MPH, drop that 60 foot and you are in the 10's no problem. Dat maple syrup is doing work.
Old 06-23-2014, 10:38 AM   #1859
Dipstik-sportech
Yeah I'm going to ditch the radials and go to a full slick next time with a 3.73 diff so I don't have to shift to 5th
The Frozen North
Old 06-23-2014, 10:46 AM   #1860
Reaper
Reaper's Avatar
Drives: violent
im glad we are about to have a proven recipe for 10's on this platform.
Old 06-23-2014, 12:11 PM   #1861
Dipstik-sportech
Oh there's no doubt in my mind it is a 10sec capable platform in the configuration I have. And considering I drove it there and back getting 33mpg I think that's pretty cool. I put quite a few full drag cars to shame as well.
The Frozen North
Old 06-23-2014, 12:19 PM   #1862
Reaper
Reaper's Avatar
Drives: violent
so im running my BOV, MBC and wastegate off my intake manifold with a brown spring in the BOV and it doesn't open under partial boost and I get a little bit of turbo flutter (5-8 psi is when its pretty audible). Only WOT full boost do I get a clean fully open BOV sound. Should I try a different vacuum configuration(ie tapping the compressor housing for the MBC and wastgate) or try a new spring first? car pulls 19inHg of vacuum sometimes a little more. I cant find any springs locally so id have to wait and I hate that.
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
