Old 10-21-2015, 12:15 PM   #169
stevesnj
stevesnj's Avatar
Heh, it's less than an hour drive for me. Dunno if I want to tackle a spring install myself.. especially without a compressor. But thanks again for the link!
You don't need a spring compressor, I did mine this way. You do need a low profile jack, Jack stands, torque wrench you can get all these from Harbor Freight. The guy in this video is weird but it's effective.
[ame="https://www.youtube.com/watch?v=4C-ZUGi4R-Q"]TRD Lowering springs without spring compressor[/ame]
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
soulreapersteve (10-21-2015)
Old 10-21-2015, 12:47 PM   #170
Agent 86
Drives: 2017 Cayman S
Great video. He does a great job of describing what he is doing.
I installed RCE Yellow springs in my car at the beginning of 2015. My method was similar to the video, but i did not remove the shock cap assembly (the parts held in by the 3 nuts). I used an open ended socket and T handle allen key (sold by Harbor Freight), and removed the shock shaft nut only. I also supported the whole car on jack stands.
On the front, I was able to swing the suspension arm down, then carefully tilt the shock away from the wheel well to install the new spring while leaving the shock on the car.
I had never done any suspension work prior to this. Took me nearly 5 hours as I was very cautious about doing this.
… and loving it! Maxwell Smart
Gone but not forgotten
2014 BRZ Limited - 2013 VW Golf R - 2010 Forester XT - 2006 Mazda 3 GT
Agent 86 is offline   Reply With Quote
The Following 2 Users Say Thank You to Agent 86 For This Useful Post:
soulreapersteve (10-21-2015), stevesnj (10-21-2015)
Old 10-21-2015, 08:00 PM   #171
stevesnj
stevesnj's Avatar
Some LED headlight pics I didn't post...shows the yellow/amber bulb covers, 8000k and 6500k temps
Glass switchable covers 8000k and 3300k
Pic of 3300k and 8000k
Dual 3300k
8000k
6500k
Old 10-21-2015, 08:25 PM   #172
damnitBobby
damnitBobby's Avatar
Drives: 2016 frs 6mt
Thanks for the pictures. I am looking to replace my headlight bulbs with an exact match of the installed LEDs that came with my car. Anyone know which spec bulbs I should buy?
damnitBobby is offline   Reply With Quote
Old 10-22-2015, 10:57 AM   #173
Beastronix
Beastronix's Avatar
wow... been awhile since I've been able to catch up on the build. Lots of new changes!
Beastronix is offline   Reply With Quote
The Following User Says Thank You to Beastronix For This Useful Post:
stevesnj (10-22-2015)
Old 10-22-2015, 10:22 PM   #174
stevesnj
stevesnj's Avatar
Yeh, having fun and going broke.lol But the best is yet to come
Old 10-23-2015, 07:23 PM   #175
stevesnj
stevesnj's Avatar
Got some Phillips LED's for dome and license plate. Just sidemarker, reverse and fog light left.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 10-24-2015, 07:52 PM   #176
stevesnj
stevesnj's Avatar
Was surprised and received my Light Smoke Helix sidemarkers, finally got rid of those ugly amber markers The first pic is the OEM bulb with the marker then with the LED, also the light smoke seems to blend in nicely with blue, and a night shot :] Just backup and fog light left to go and I'm 100% LED
Old 10-25-2015, 10:05 AM   #177
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Installed a set of TRD lowering springs, took me 7 hours by myself, was tough. I also installed my Winmax W2's while the wheels were off. My high temp brake fluid is going in tomorrow. Now time to bedd in the pads. Used a socket and pipe wrench to break the locknut loose then just went with vice grips to remove and reinstall the locknut. I also prayed enamel clear on the springs so they'll be easy to clean.
Was wheel alignment necessary?
Old 10-25-2015, 04:50 PM   #178
stevesnj
stevesnj's Avatar
Yes, in the install instructions has specs for the alignment machine. So I will have to get that done.
Old 10-26-2015, 10:55 AM   #179
Agent 86
How challenging is it to remove and install side markers?
Old 10-26-2015, 01:46 PM   #180
stevesnj
stevesnj's Avatar
Well I just guessed on the 1st try and found out it can be done with just a long flathead. I removed the plastic clips in front of the tire just under the marker that holds the wheel well to the fender. It's a flexible plastic and you can move it out of the way. From below using a ling skinny flathead I just pressed on clip "A" marked on the new sidemarker and twist the screwdriver to slightly pop the top of the marker and once you got a hold of the top I firmly pulled down ant the other two clips let go. Thats all.
The Following 2 Users Say Thank You to stevesnj For This Useful Post:
Agent 86 (10-26-2015), soulreapersteve (10-26-2015)
Old 10-28-2015, 06:35 PM   #181
stevesnj
stevesnj's Avatar
and on a personal note, I threw out some trash today
Old 10-28-2015, 09:08 PM   #182
damnitBobby
Nice man tell that person to go kick rocks!
The Following User Says Thank You to damnitBobby For This Useful Post:
stevesnj (10-28-2015)
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
Jac's BRZ build thread Jac Member's Car Journals 0 04-30-2014 07:09 PM
2016 FR-S vs 2016 MX-5 Coupe NWFRS FR-S / BRZ vs.... 55 11-29-2013 11:17 AM
EOJ (Not much of a Build) Thread jonbatz01 Member's Car Journals 41 07-31-2013 07:34 PM
