Old 08-03-2014, 02:34 AM   #169
steve99
Originally Posted by Td-d View Post
ZA1JD00C, latest USDM MT Rom definition is up: http://www.romraider.com/forum/viewt...p?f=34&t=10860
looking forward to the D00G rom defs
If you get a chance can you dropbox the D roms you have and I'll add them to the first post for guys to update their ROM's
Old 08-05-2014, 08:37 AM   #170
steve99
New Stock ROMs for Japanese BRZ/86 attached to Original post
ZA1JA02A
ZA1JA02B
Europe/Australia/South Africa
ZA1JD00G
USA/Canada
ZA1JD00C
d1ck (08-05-2014)
Old 08-07-2014, 10:18 PM   #171
tech86
Drives: 86 GTS
Do we have defs for these yet? Just wondering what has changed. My 86 is due for its 2nd service so I assume they'll update the ROM anyway?
tech86 is offline   Reply With Quote
Old 08-07-2014, 10:36 PM   #172
steve99
They didn't do mine a couple of weeks ago, they reckon they did not know about any new firmware as I winged about rough idle with A/C on trying to get a copy of new rom . Maybe they don't have a TSB to do it. But A02G and D00G were out in newer cars
Doubt they will update it for you, defs should be out soon hopefully Td-d is pretty snowed under.
Old 08-08-2014, 09:44 AM   #173
ML
ML's Avatar
Drives: 13 White MT FR-S
Has anyone messed with turning off DTC codes in RR? My rear speed sensor is giving me issues, which it putting the car in limp mode. Can I turn off the DTC code and it will go back to normal?
Old 08-08-2014, 04:18 PM   #174
steve99
Assume your talking about rear O2 sensor ??
If its just throwing the cat efficency code P0420 from memory then yes you can just disable it .
But if the rear O2 is actually crook you will have to fix/replace it, as for some reason it will disable cruise control and possibly put you in limp home mode as the sensor is actually used for some functions.
What codes are comming up.
Old 08-08-2014, 04:34 PM   #175
ML
ML's Avatar
Sorry I messed up typing on my phone. The rear abs speed sensor got messed up and throwing the car into limp with a cell. I did disable it and it stopped the limp mode, but the traction and abs is still shot which sulks cause I have to drive 6 hours to the 86 expo tonight.
Old 08-08-2014, 04:48 PM   #176
steve99
Yes disabling the code just "masks" the problem, won't solve it, new sensor will be required unfortunately, and I would imagine ABS EBD VSC Traction Brake force distribution ie all the nanny safety feature would be disabled car might be a handfull if you have to do emergency stop., should be plenty of "spare" ones at the 86 expo :-)
ML (08-08-2014)
Old 08-08-2014, 05:22 PM   #177
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
It's Xmas folks
ZA1JD00G defined: http://www.romraider.com/forum/viewt...p?f=34&t=10884
Td-d is offline   Reply With Quote
The Following User Says Thank You to Td-d For This Useful Post:
steve99 (08-08-2014)
Old 08-08-2014, 05:24 PM   #178
Td-d
As requested by Steve, dump of the ZA1JD00G ram addresses
Code:
E_AF_Correction_1_2byteExtExt_E82                      FFF89E3C
E_AF_Correction_1_4byteExt_E81                         FFF8A894
E_AF_Learning_1_2byteExtExt_E83                        FFF89E40
E_AF_Learning_1_4byteExt_E48                           FFF8AA18
E_AF_Sensor_1_2byteExtExt_E92                          FFF89E2C
E_AF_Sensor_1_4byteExt_E91                             FFF89610
E_CLOL_FuelingExt_E33                                  FFF8D756
E_Closed_Loop_Fueling_Target_2byteExt_E122             FFF89E3E
E_Closed_Loop_Fueling_Target_4byteExt_E121             FFF8A978
E_Engine_Load_1byteExtExt_E86                          FFF89E4F
E_Engine_Load_4ByteExt_E32                             FFF8942C
E_Engine_Speed_Delta_E157                              FFF896E8
E_Feedback_Knock_Correction_1byteExtExt_E94            FFF89E57
E_Feedback_Knock_Correction_4byteExt_E39               FFF8B2F0
E_Final_Fueling_Base_2byteExt_E124                     FFF89E38
E_Final_Fueling_Base_4byteExt_E123                     FFF8A2C8
E_Fine_Learning_Knock_Correction_1byteExtExt_E95       FFF89E5A
E_Fine_Learning_Knock_Correction_4byteExt_E41          FFF8B38C
E_Fuel_Injector_1_Latency_4byteExt_E50                 FFF8A308
E_Fuel_Injector_1_Pulse_Width_2byteExtExt_E99          FFF89E34
E_Fuel_Injector_1_Pulse_Width_4byteExt_E60             FFF88A3C
E_Gear_CalculatedExt_E59                               FFF898CB
E_IAM_1byteExtExt_E96                                  FFF89E59
E_IAM_4byteExt_E31                                     FFF810AC
E_Idle_Speed_Map_SelectionExt_E49                      FFF8B974
E_Ignition_Base_TimingExt_E53                          FFF8B0B4
E_Knock_Correction_Advance_4byteExt_E43                FFF8B2EC
E_Knock_Correction_Advance_Max_PrimaryExt_E118         FFF8B358
E_Manifold_Relative_Pressure_4byteExt_E113             FFF89258
E_Manifold_Relative_Sea_Level_Pressure_2byteExtExt_E89 FFF89E24
E_Manifold_Relative_Sea_Level_Pressure_4byteExt_E52    FFF89254
E_Primary_Open_Loop_Map_Enrichment_2byteExtExt_E85     FFF89E44
E_Primary_Open_Loop_Map_Enrichment_4byteExt_E84        FFF8ABE4
E_Requested_TorqueExt_E56                              FFF8B6D0
E_Target_Throttle_Plate_PositionExt_E57                FFF8B7B8
E_Throttle_Plate_Opening_Angle_2byteExtExt_E93         FFF89E26
E_Throttle_Plate_Opening_Angle_4byteExt_E38            FFF89310
E_Tipin_ThrottleExt_E54                                FFF89318
RAM_EngineSpeed FFF896D8
Ram_AFR_Sensor_Heating_Limit_Result             FFF886EC
Ram_AF_Correction_3_32bit_ECU                   FFF8ABA4
Ram_AF_Sensor_1_Current                         FFF8960C
Ram_AF_Sensor_1_Resistance                      FFF89624
Ram_Accelerator_Pedal_Angle                     FFF89510
Ram_Accelerator_Pedal_Angle_0                   FFF8D744
Ram_Accelerator_Pedal_E                         FFF8D73C
Ram_Alternator_Duty                             FFF88718
Ram_Ambient_Air_Temp_0                          FFF898F4
Ram_Ambient_Air_Temperature                     FFF8D730
Ram_Atmospheric_Pressure                        FFF8D704
Ram_Atmospheric_Pressure_1                      FFF89E78
Ram_Base_Pulse_Width_times_100_0.84             FFF89FF0
Ram_Battery_Voltage                             FFF88000
Ram_Battery_Voltage_0                           FFF8D710
Ram_Brake_Switch                                FFF89673
Ram_CFP_Delta                                   FFF89328
Ram_CPC_Valve_Duty_Ratio                        FFF8A000
Ram_Calculated_Base_Pulse_Width_                FFF8A304
Ram_Catalyst_Temperature_Bank_1_Sensor_1        FFF8D70C
Ram_Commanded_Secondary_Air_Status              FFF8D759
Ram_CoolantTemperature                          FFF89384
Ram_Defogger_Switch                             FFF8967F
Ram_Direct_Injection_Quantity_Minimum           FFF8A374
Ram_Distance_Traveled_since_DTCs_cleared        FFF812D6
Ram_Distance_Traveled_with_MIL_On               FFF812D4
Ram_EVAP_Commanded_Purge                        FFF8D6FC
Ram_Engine_Load_Absolute                        FFF8D714
Ram_Engine_Load_Calculated                      FFF8D6BC
Ram_Engine_Oil_Temperature                      FFF8D750
Ram_Engine_Oil_Temperature_0                    FFF88008
Ram_Engine_Speed                                FFF89850
Ram_Exhaust_VVT_Retard_Angle_Left_?             FFF8C31C
Ram_Exhaust_VVT_Retard_Angle_Right_             FFF8C318
Ram_Fuel_Air_Commanded                          FFF8D720
Ram_Fuel_Injector_1_Pulse_Width_4byteExt_E60??? FFF88A64
Ram_Fuel_Level                                  FFF8D700
Ram_Fuel_Pressure_MPa                           FFF89658
Ram_Fuel_Pump_Duty                              FFF8B3E0
Ram_Fuel_Pump_Duty_0                            FFF8BF64
Ram_Fuel_Rail_Pressure_direct_inject            FFF8D6F0
Ram_Fuel_Trim_1_Long_Term                       FFF8D6C8
Ram_Fuel_Trim_1_Short_Term                      FFF8D6C4
Ram_Fuel_Type                                   FFF8D75A
Ram_Gear                                        FFF89675
Ram_High_Low_Load_0_L_1_H                       FFF8A3A4
Ram_Idle_Switch                                 FFF8B7F2
Ram_Ignition_Total_Timing                       FFF8B038
Ram_Intake_Air_Temperature                      FFF8D6DC
Ram_Intake_Air_Temperature_0                    FFF87FF8
Ram_Intake_Manifold_Pressure                    FFF8D6CC
Ram_Intake_OCV_Current_Left                     FFF89498
Ram_Intake_OCV_Current_Right                    FFF8948C
Ram_Intake_OCV_Duty_Left                        FFF8C3E0
Ram_Intake_OCV_Duty_Right                       FFF8C3EC
Ram_Intake_Temp                                 FFF89398
Ram_Intake_VVT_Advance_Angle_Left               FFF8C2D4
Ram_Intake_VVT_Advance_Angle_Right              FFF8C2D0
Ram_Mass_Airflow                                FFF893F8
Ram_Mass_Airflow_0                              FFF8D6E0
Ram_Minimum_Port_Injection_Quantity             FFF8A370
Ram_Number_of_warm_ups_since_DTCs_cleared       FFF828CA
Ram_Rear_O2_Sensor                              FFF8D6E8
Ram_Roughness_Monitor_Cylinder_1                FFF8D07C
Ram_Roughness_Monitor_Cylinder_2                FFF8D07D
Ram_Roughness_Monitor_Cylinder_3                FFF8D07E
Ram_Roughness_Monitor_Cylinder_4                FFF8D07F
Ram_Run_Time_Since_Engine_Start                 FFF850F4
Ram_SI_Drive_Mode_I3_S1_SSharp2_                FFF88C0D
Ram_Throttle_Opening_Commanded                  FFF8D740
Ram_Throttle_Position                           FFF8D6E4
Ram_Throttle_Position_B                         FFF8D734
Ram_Throttle_Position_D                         FFF8D738
Ram_Throttle_Position_relative                  FFF8D728
Ram_Time_Run_since_DTCs_Cleared                 FFF812DA
Ram_Time_Run_with_MIL_On                        FFF812D8
Ram_Timing_Advance                              FFF8D6D8
Ram_Transient_Threshold_Testunk                 FFF89520
Ram_Vehicle_Speed                               FFF8D6D4
Ram_Vehicle_Speed_0                             FFF896B0
The Following 2 Users Say Thank You to Td-d For This Useful Post:
sav (02-25-2015), steve99 (08-08-2014)
Old 08-09-2014, 09:07 AM   #179
Td-d
And... ZA1JA02A is up: http://www.romraider.com/forum/viewt...p?f=34&t=10888
Old 08-14-2014, 03:24 PM   #180
Dantical
Drives: Mr2 3S-GTE GEN 3 - GT86 MT
hey guys,.. iam having a Problem,.. my tuner did a "first small" tune and i want to add the Launch control and Flat foot shifting from ecu-mods.com
so i Need to save my .srf in to hex... but when i try to do it,.. ecuflash says:
„THIS rom image contains selections of invalid data which must be zero padded to make a contiguous file.
It is possible ipon subsequent loading of this file that you might flash over valid areas with these zeroed areas.
Do you wish to continue?“
Anyone in here who can help me ?
it is the ZA1JD00G
- sorry for the N00B question
Dantical is offline   Reply With Quote
Old 08-14-2014, 06:47 PM   #181
steve99
it is the ZA1JD00G
SRF is structured rom format, it contains extra info about the rom not contained in the .hex or .bin format.
I am not familiar with the ecu mods changes but saving rom in .bin or hex will be fine the resulting file should be 1280k bytes , you need to save roms in .bin or .hex to be able to use romraider to edit roms as ecuflash is the only software that supports srf format.
Old 08-14-2014, 06:54 PM   #182
Dantical
he is using ecuflash ,..
iam just wondering about that error message..
i already contacted xswrex about any help....
iam wondering that i can´t even save the original file into hex without getting this message.
is there a ready Definition for the ZA1JA00G?
ecuflash, tactrix, taxtrix, tuning
ECUFlash - Getting close! xjohnx Software Tuning 698 03-22-2015 12:10 PM
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 10:55 AM
Tactrix Openport jamesm Engine, Exhaust, Bolt-Ons 1 01-28-2014 08:27 PM
Visconti Tuning - Latest BRZ Flash Info Visconti Software Tuning 6530 12-24-2013 10:18 PM
Overboost Protection With OFT/EcuFlash? FrX Software Tuning 9 10-23-2013 07:27 AM
