Old 07-16-2015, 10:55 PM   #169
akyp
Drives: 2012 86
Originally Posted by solidONE View Post
I thought they were 6K/6K?
My bad. Edited the post above with the correct rates.
Also How they perform if you bump up the spring rates without a revalve. Thanks!
Would like to know the same too as I'm interested in a higher rear rate e.g. 6k/7k.
akyp is offline   Reply With Quote
Old 07-16-2015, 11:05 PM   #170
dp1
driving smoother faster
Drives: Sold
When I swapped springs to 380lb f/425lb rear, Ohlins said that change in spring rates over 20-30% requires revalving
dp1 is offline   Reply With Quote
Old 07-17-2015, 12:26 AM   #171
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Low speed/load ride quality before and after the revalve?
Old 07-17-2015, 08:52 AM   #172
dp1
Drives: Sold
I would say "before and after spring change", because I had them rebuilt so they checked everything - not sure how much valving adjustment was needed - pretty similar to stock 343lb springs on the street, slightly stiffer over bumps at low speed but smoother than before at 60-125mph. I run them on a pretty soft setting on the street (-18 clicks from full hard) and -11 on ax/track. The change helped with car rotation in slower corners on ax and track, easier to get slip but not loose. -3f/-2.5r camber.
Old 07-17-2015, 10:58 AM   #173
Racecomp Engineering
Also I'd like to as the owners of these dampers about the damping quality at low speeds (20~45MPH). How is the ride quality over small bumps and undulating road surfaces? Also How they perform if you bump up the spring rates without a revalve. Thanks! @mav1178 @Dezoris @Racecomp Engineering
Very good high piston speed valving...these ride well. Our change in springs put them at the edge of the standard valving but it was still very good.
- Andrew
Old 07-17-2015, 12:28 PM   #174
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
The Ohlins feel fine at low speeds, I would caution you to not read too much into small bumps/broken road surface feel because a lot of that is dictated by the tires you run.
Case in point:
Ohlins + Falken RT615K = feels like shit due to stiff sidewall
Ohlins + Toyo T1 Sport = very smooth, heavy touring-car like feel
Ohlins + Hankook RS3 = soft sidewall, not as soft as T1 Sport but definite change from Azenis
Ohlins + Falken FK453 = very smooth
YMMV.
-alex
Old 07-18-2015, 12:11 AM   #175
solidONE
solidONE's Avatar
Awesome! Thanks guys. @dp1 @Racecomp Engineering @mav1178
Old 07-19-2015, 02:10 AM   #176
Yeah I ran mine at 450/450 and was running Pirelli Trofeo R's in 235/40-18. This is a MASSIVE sidewall and I immediately went up 3 clicks stiffer front and rear. At that point I will say it felt VERY GOOD. More like a Ohlins TTX to be honest, but that was primarily the extra sidewall that made low speed compression feel "beautiful". I called it "instant" low speed damper adjustment ! ( "just add water" 3 ways ) lol
Myles
Old 07-19-2015, 02:52 AM   #177
Ro_Ja
Drives: TOYOTA
Originally Posted by akyp View Post
Call me crazy but would it be possible to remove the front Ohlins camber plates then re-use the front OEM top hats? Where I live pillow ball mounts would not pass inspection. I know I'd lose camber adjustment and have to live with however much negative camber I can get with camber bolts.
I see you're in Hong Kong and not the US, but if you're interested:
http://www.evasivemotorsports.com/mm...R_S-SUSPENSION
Ro_Ja is offline   Reply With Quote
Old 07-19-2015, 03:23 AM   #178
akyp
Drives: 2012 86
Thanks. So that answers my question. I'll need to talk to the local distributor.
Old 07-30-2015, 02:46 PM   #179
1Cor10:23
1Cor10:23's Avatar
Hey y'all, have had 4 track days this season already so I decided to get my car up on the hoist and check the compression and rebound on the coilovers to make sure that they still respond well to adjustments.
Fronts seem to be fine but I found that my rear driver side seemed slightly easier to compress than passenger side (Granted, I left everything installed on the rear and just pushed the tire upward and gauged the movement as well as effort required - I know the spring and endlink provide resistance but it should be balanced?).
Anyway, was curious as they have only been installed for 4 track days about about 4K miles. Could the seals already be wearing?
Thanks!
Edit: pinging the heavy-hitters... @CSG David @CSG Mike @Racecomp Engineering
Old 07-30-2015, 02:55 PM   #180
solidONE
solidONE's Avatar
Thanks!
I seriously wonder if they even check the dampers for uniformity on a dyno after assembly on these "lower end" shocks. I'm thinking they just assemble with the specified shim-stack then box them up without checking.
Intent > Content
Old 07-30-2015, 02:57 PM   #181
1Cor10:23
1Cor10:23's Avatar
@solidONE I would hope so but you might be right haha. If that's the case, how will you ever know when it's time for rebuild? Only if it leaks?
Old 07-30-2015, 05:14 PM   #182
solidONE
solidONE's Avatar
I know the "higher-end" stuff many racers will have a rebuild interval once every season or maybe every other season depending on their situation. Maybe shoot them an email. 4K is not a lot of miles on these. Plus I recall they advertise a 1 or 2 year warranty, so maybe this is "warranty-able" I hear Ohlins has very good service.
Intent > Content
ohlins road and track shock absorbers CyberFormula Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 11-11-2014 05:00 AM
>> OHLINS Road & Track Coilovers - First Shipment IN - FT86 Special - FREE Shipping! Circuit Motorsports Brakes, Suspension, Chassis 90 08-16-2013 12:39 PM
Ohlins Road & Track Coilovers - IN STOCK!!! RallySport Direct Brakes, Suspension, Chassis 7 05-28-2013 04:11 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
Ohlins Road & Track Subaru BRZ and Scion FR-S HP Autowerks Brakes, Suspension, Chassis 0 04-24-2013 03:27 PM
