Old 06-19-2015, 02:40 AM   #155
Kostamojen
Anyone experiencing that on their twin and found a way to fix it?
Probably need to replace the rear tophat with something better.
Old 06-19-2015, 04:05 AM   #156
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by Guillaume View Post
I've had the Öhlins on for less than 10k km and I am starting to have some serious rattling coming from the rear left. I thought something wasn't tightened back properly when the shocks were mounted...
If you have a rattling noise and it's related to coilover install, usually it's one of two things (assuming all other things are tightened properly):
1) strut nut not torqued down properly
2) pillowball is defective
-alex
Old 06-19-2015, 07:54 AM   #157
enivid
enivid's Avatar
Drives: WRB JR BRZED
-alex
It happened to mine. Have to take the coil off and tighten the nut.
enivid is offline   Reply With Quote
Old 06-20-2015, 02:06 AM   #158
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Thanks everyone for your input. I'll have everything tighten ASAP, hopefully that will be enough.
Guillaume is offline   Reply With Quote
Old 07-14-2015, 12:11 PM   #159
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
@mav1178 hey Alex, wondering if you have experienced any spring bind issues? I'm hearing a bit of spring bind at full lock on the left; can tell that the top 2 spring "circles" are rubbing against each other only at full lock. Also using RaceSeng top hat with their custom perch (which already includes a thrust bearing).
Wondering if you've experienced anything similar.
Thanks!
1Cor10:23 is offline   Reply With Quote
Old 07-14-2015, 01:19 PM   #160
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Did that fix your problem?
I've started noticing a single "click" noise from both rears when starting from stop (and once in a while during shifting), but nothing else during driving ie over bumps, etc. Over last week, it started to turn into a jingling noise (like loose change). Looked around to re-torque everything and noticed that I've lost one pair of the locking allen screws (for height adjustment) in the passenger front coilover. Gave Ohlins a call to order another set and just cranked down on the other allen lock for now and re-torqued everything else. After getting back on the road Monday morning, clicking still persists...
TLDR started hearing clicking in the rears, turns out front height adjustment lock was loose/gone, torqued everything down, clicking still there
Old 07-15-2015, 11:55 AM   #161
mav1178
mav1178's Avatar
So far only time I've had any "bind" is when I go full lock, and attempt to drive up into my driveway which has a fairly large incline. But it only happened twice and I have yet to replicate the issue since.
-alex
1Cor10:23 (07-15-2015)
Old 07-15-2015, 12:32 PM   #162
1Cor10:23
1Cor10:23's Avatar
@mav1178 hrm okay so it's not super uncommon, similar conditions for me but a bit more often, only at lock.
Sent from my SGH-I317M using Tapatalk
Old 07-15-2015, 12:49 PM   #163
mav1178
mav1178's Avatar
Yes, but I should note that I have had it twice and only when I attempt to go up my driveway with a full steering lock.
Has never happened anywhere else, on track nor on any of my roadtrips in the past 18 months.
I do check the suspension about once a month (esp before/after track events), have to say these are probably the most maintenance-free coilovers I have had (and I've owned a lot).
-alex
Old 07-16-2015, 02:43 AM   #164
akyp
Drives: 2012 86
Call me crazy but would it be possible to remove the front Ohlins camber plates then re-use the front OEM top hats? Where I live pillow ball mounts would not pass inspection. I know I'd lose camber adjustment and have to live with however much negative camber I can get with camber bolts.
akyp is offline   Reply With Quote
Old 07-16-2015, 04:32 AM   #165
ajc209
Drives: GT86 Cosworth
Ohlins actually sell the R&T kit without the top mounts here in europe. You might need to special order it in the US though.
ajc209 is offline   Reply With Quote
Old 07-16-2015, 12:16 PM   #166
mav1178
mav1178's Avatar
Suggest you talk to your Ohlins importer locally, what they sell in Asia is different than what we have here.
US vehicle "safety" inspections are a joke.
-alex
Old 07-16-2015, 08:06 PM   #167
akyp
Drives: 2012 86
As far as I know, only Japan has its own version of Ohlins R&T with 9k/7k spring rates. The rest of the world gets the same 6k/6k with the same top mounts.
Old 07-16-2015, 10:39 PM   #168
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
As far as I know, only Japan has its own version of Ohlins R&T with 8k/7k spring rates. The rest of the world gets the same 7k/7k with the same top mounts.
I thought they were 6K/6K?
Also I'd like to as the owners of these dampers about the damping quality at low speeds (20~45MPH). How is the ride quality over small bumps and undulating road surfaces? Also How they perform if you bump up the spring rates without a revalve. Thanks! @mav1178 @Dezoris @Racecomp Engineering
ohlins road and track shock absorbers CyberFormula Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 11-11-2014 05:00 AM
>> OHLINS Road & Track Coilovers - First Shipment IN - FT86 Special - FREE Shipping! Circuit Motorsports Brakes, Suspension, Chassis 90 08-16-2013 12:39 PM
Ohlins Road & Track Coilovers - IN STOCK!!! RallySport Direct Brakes, Suspension, Chassis 7 05-28-2013 04:11 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
Ohlins Road & Track Subaru BRZ and Scion FR-S HP Autowerks Brakes, Suspension, Chassis 0 04-24-2013 03:27 PM
