Old 03-23-2012, 08:32 PM   #169
Dragonitti
Originally Posted by dsgerbc View Post
Don't be surprised when the insurance denies your medical claim, cause you compromised OEM SRS system.
Cool story.
Originally Posted by tranzformer View Post
Hmm really? Have you heard/read of situations that this has happened. Makes sense that they would try to get out of paying out if they can.
No it doesn't. Airbag sensors are generally stored under the headlights for collisions. Nothing to do with your seat. I've been driving for 18yrs. In that 18yrs, I've had one incident where I rear ended someone. If I get into an accident to need medical attention, it wouldn't be my insurance that would be covering me. It would be the person at faults insurance.
Side note: Progressive allows $5k extra for coverage for modifications to my Scion tC. Why allow a policy like that only to try and deny coverage?
Old 03-23-2012, 08:36 PM   #170
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
Oh yes it does.
tranzformer is offline   Reply With Quote
Old 03-23-2012, 08:40 PM   #171
dsgerbc
Drives: BRZ(sold), STI
RTFM. There's an airbag in the seat. If you remove it and don't disclose it - it's fraud.
dsgerbc is offline   Reply With Quote
Old 03-23-2012, 08:42 PM   #172
Dragonitti
Oh yes it does.
Question....are you going to put lowering springs or coilovers on your car, as this will drop the height of the vehicle, and position it lower than where the airbag sensors were designed to be position in the event of an accident.
So...lets all drive stock cars
Old 03-23-2012, 08:43 PM   #173
tranzformer
Drives: Zoom Zoom
Nope not going to put lowering springs on it. Neither coilovers.
Yes I will drive a stock car. "Hellastock BRZerHOOD"
Go ahead and remove your safety equipment on a DD car. I sure won't. Good luck when your auto insurance companies denies your claim as a result of that.
Old 03-23-2012, 08:44 PM   #174
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Originally Posted by Scion FR-S View Post
That would actually be a disadvantage for the Mustang - with deceleration weight shifts forward, so if you already have 65% of the weight over the front wheels and then brake hard that number moves considerably higher, meaning the front contact patches are doing much more of the braking work than the back patches. Consequently the back wheels are far more likely to lock up at the same braking force levels (all else being equal) than if there is a 50/50 weight distribution under braking. This tendency results in longer stopping distances - 2 patches are in a sense trying to do the work of 4. Thus you find that Porsches with their rear weight bias can typically outbrake other car makes in road race series.
actually, it isnt a disadvantage, the front brakes do 80% of the braking and the back does 20% respectively , with more weight on the front of the car under hard braking the weight is thus transferred to the front, when that happens more weight is applied on the front tires compressing them to the ground and giving the tires a larger contact area, or patch, with the ground
how fast you can stop also relies on what rubber you are using, if your tires arent wide enough or sticky enough, the weight transfer can hurt braking distances when the load put on the tires surpasses its capabilities to stop
and i do fully understand that Porsches stop faster than most cars, with the engine in the back, lower pitch rates(suspension movement from front to back when stopping), lower CoG,and also wider tires than most cars
when a porsche stops, since the engine is in the back, the weight isnt transferred to the fron, but also the chassis doesnt allow the car to pitch like the mustang, all four tires are thus planted better so the brake distribution is about 40% in the back and 60% in the front
that is the reason you see bigger brakes on the front and tiny brakes in the back of mustangs, challengers, and cameros
on porsches you see about the same size brakes on both front and back because of how the vehicle handles its braking dynamics
a mustang would stop slower with a 40/60 braking ration as would a porsche stop slower with a 20/80 braking ratio
the amount of braking force in the back and front depends solely on where the weight is when you brake
how fast you can brake relies on the rubber thats on the car, most porsches are equipped with better stock rubber than mustangs as well and inside line only uses stock rubber in their tests
EDIT: i give the BRZ and A+ attempt at braking on those shitty....shitty... excuses for tires... also the lateral g's when it corners is impressive on those shit tires, slalom was also a good run aswell, i see it braking into the 70's with better rubber
heres an example of better results on the same car with a few suspension bits and much better rubber
Hotchkis tuned 2000 Celica GTS (NA):
- 1.03G skidpad (stock 0.82g)
- 76.9 mph slalom (stock 70.1)
- 97 ft, 60-0 (stock 107 ft) (That's 1.23 g's!!)
EDIT EDIT: ohh yeah and the celica also came on some pretty shitty eco tires aswell it weighs 2500 lbs and handles decently aswell compared to the BRZ
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Old 03-23-2012, 08:49 PM   #175
dsgerbc
Lol, is that your defense?
I bet you can cook up an argument of the same quality to defend removing airbag from the steering wheel too...
Old 03-23-2012, 08:50 PM   #176
Dragonitti
It's illegal to remove your steering wheel and replace it with an Aftermarket one that doesn't have an airbag. Have you ever seen a car with a Vertex Steering wheel? How about an OMP one?
Are you one of those individuals who doesn't get out of bed, for fear that you might step down the wrong way and break your neck and die...cause we can die just getting out of bed.
Seriously though....don't mod your car if you are THAT afraid.
Since when do we need to "defend" what we want to do with "our own cars"? I'm not putting you personally at risk, so what crawled in your corn flakes?
Thank you for the kind words... Perhaps you should save yourself even more pain and just not drive at all. I've never spent a day in my life in a hospital.
I will be buying a GSXR600 while I'm waiting to purchase my FR-S....OMG! I must have a death wish! No one is harping you for staying stock, why would you bring negativity to people who mod? You know I track my car, so don't see the gripe about modding to take my car to the track.
Old 03-23-2012, 08:51 PM   #177
Subaruwrxfan
Subaruwrxfan's Avatar
Drives: 2015 Mustang EcoBoost
I can't believe there's so many complainers/trolls on here. After all the good reviews. Every single last one had glowing praise. And people are crying about stuff still? I guess some people will truly never be happy.
"In a word: sensational. It is a riot to pilot." -Autoweek
"I haven’t had this much driving fun in a long time..." -Road & Track (These are critics that drive cars for a living, and he hadn't had this much fun in a long time!)
"Profound control. Think Lotus Exige/Elise or Porsche 911 GT3...the BRZ encourages full-attack driving on unfamiliar roads well into triple digits...the car is a stunning experience. It is one of the most rewarding cars we've ever driven." -InsideLine
"The BRZ is undeniably superb...For pure, unadulterated driving delight, the BRZ packs a knockout punch." -Motor Trend
You read all this, words spoken from people that drive sports cars for a living, and even THEY can get this excited about a car? But some people here can't. Unbelievable. Reading these articles made my day.
Check out my BRZ videos on my YouTube page: youtube.com/subaruwrxfan
Subaruwrxfan is offline   Reply With Quote
Old 03-23-2012, 08:52 PM   #178
zoomzoomers
zoomzoomers's Avatar
Drives: 2013 Subaru SWP BRZ Limited 6AT
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam.
zoomzoomers is offline   Reply With Quote
Old 03-23-2012, 08:54 PM   #179
engee
Drives: Subaru
The only complaint I have is that I still have to wait until I get mine.
engee is offline   Reply With Quote
Old 03-23-2012, 08:56 PM   #180
tranzformer
Drives: Zoom Zoom
Particularly when you tried to prove us wrong and noted that crash sensors "are generally stored under the headlights for collisions. Nothing to do with your seat." However when I showed you that you were wrong based on the BRZ/FRS, you tried playing it off. Just accept that it is an issue if you care about safety and the design of the car. If you want to disregard that fine. Why do you think people are spending extra $$$ for the limited version? Most of them give their primary reason for going with the limited due to the seats.
Old 03-23-2012, 08:58 PM   #181
Dragonitti
Sorry I don't follow you and how you think clutch drops at 5500rpm represents anything that the average driver would do.
The average driver isn't doing clutch dumps period....so why do you care is my point.
If you are into spirited driving and performance, then you drive the car like it should be driven...."Stolen".
Old 03-23-2012, 09:00 PM   #182
zoomzoomers
[QUOTE=Dragonitti;164295]The average driver isn't doing clutch dumps period....so why do you care is my point.
If you are into spirited driving and performance, then you drive the car like it should be driven...."Stolen".[/QUOTE]
I always do... MUAHAHAHAHA
First Production FT-86 Test Drive/Review on Youtube gaijin0223 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 4 02-13-2012 10:23 PM
Insideline's USDM BRZ test review madfast BRZ First-Gen (2012+) — General Topics 95 12-08-2011 05:52 AM
Jalopnik Test Drive Review of BRZ (oh wait...) Quantum BRZ First-Gen (2012+) — General Topics 8 12-03-2011 03:45 PM
2012 Subaru BRZ Test Drive Review by Autoweek Sport-Tech BRZ First-Gen (2012+) — General Topics 1 12-02-2011 07:34 PM
Edmunds Inside Line talks future Vehicles e10rice Scion FR-S / Toyota 86 GT86 General Forum 7 06-10-2010 02:22 PM
