Old 10-13-2014, 07:08 PM   #169
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
Originally Posted by dradernh View Post
At 2935#, a very conservative 57.10 makes me think you're running somewhere around 400 RWHP - is that in the ballpark?
Yeah at Lime Rock I was running 392 whp (NARRA TT2 Trim) which proved a little too much for the transmission.
Element Tuning is offline   Reply With Quote
Old 10-13-2014, 09:02 PM   #170
rever5e
@Element Tuning - do you have any video of the run at Road Atlanta? In NA form i'm struggling to get past 1:49:xx. Would love to see what you're doing to achieve such stellar times!
rever5e is offline   Reply With Quote
Old 10-13-2014, 11:26 PM   #171
Element Tuning
Hopefully this works for you as I'm a little limited getting YouTube link with a mobile.
[ame]http://m.youtube.com/watch?v=QlEX2a6jf-M[/ame]
In a nutshell, big balls. LOL! Ask Austin Cabbot but I was flat out in 12 and he just about totalled his car trying that so be careful! I feel like I was really fast through one but on day two dropped a couple seconds hanging it out in 2-3. I took a ride in the grass there at least once so I was definitely pushing it.
Take a look at the video and let me know if you need any advice but RA is tough to master and I don't feel like I have yet but am getting close.
Old 10-14-2014, 05:41 PM   #172
rever5e
Impressive. Thanks for sharing!
Here's a video of one of my 1:49:xx runs.
Best lap starts at 3 minutes 48 seconds. Lots of room for improvement needed especially in 1, 5, 10a/b, etc.
Were you running a square setup with the Hankook RS3 275/35-18? Also do you have any idea of what your WHP was? I feel like i'm miles behind you!
Old 10-15-2014, 02:56 PM   #173
Element Tuning
I was +15 hp over baseline. I was running 275-18 square but don't get any ideas as that's a much slower setup for an NA FRS/BRZ. Less rolling diameter for better gearing and less weight is actually quicker than what I was running.
Just remember you don't have a whole lot to gain by crashing your car so just drive within the car's and your limits.
From what I see you're just not using enough of the track. When you have such a low amount of power it's really important to not pinch off your turns so take it in wider, turn in, and then let the car drift out and or open that wheel up to use all the track.
There is so much track out available for T1 run wider in and through (don't take the high power car line like you currently are). So slow down less and go wide so you don't scrub speed and you'll keep more momentum up that hill.
For T5 you can go a lot faster if you imagine the line using the run off. LOL! There a whole lot more track out there to keep the throttle hammered and accelerating down that short straight.
I don't think you're losing a ton of time in 10a-b but you could use more curbing than you are and then track out more going up the hill. Given how slow the FRS/BRZ is up there you should stay more left under the bridge (as you are way right now). This will allow for a more shallow angle as you enter 12 which will allow for more speed.
Have fun!
Old 10-15-2014, 05:14 PM   #174
ja1217
Drives: 2004 Toyota RAV-4 5M
Here's another good video for Road Atlanta from NASA East Coast Nationals. Driver came in 3rd in TTD with a 1:43.5
[ame]http://youtu.be/jcOaj_KiDd4[/ame]
ja1217 is offline   Reply With Quote
Old 10-26-2014, 08:27 AM   #175
rever5e
Have fun!
Awesome advice. Thank you!
Old 10-28-2014, 10:19 PM   #176
Apex_BRZ
Drives: 2013 Subaru BRZ Limited (WRB)
Track: Mid America Motorplex
Time: 1:52.416
Driver: Matt Van Horn
Date: October 17, 2014
Notes: RE-11A Tires (215/17's), Enkei RPF1 17x8, Speigel Steel Brake Lines, Motul RBF600, Carbotech XP10/XP8, -1.4* Camber front
No video, but here is the information on one of the sessions with the lap time.
Also a video on one of the laps above chasing my friend, for kicks. Could be the fast lap, don't know for sure.
[ame="https://www.youtube.com/watch?v=ppH09dz-3XA&list=UUMsgjMYTbNBA6Og9y5TM4Yg"]https://www.youtube.com/watch?v=ppH09dz-3XA&list=UUMsgjMYTbNBA6Og9y5TM4Yg[/ame]
Apex_BRZ is offline   Reply With Quote
Old 11-10-2014, 03:02 PM   #177
ja1217
NA Summit Point (Main) / 1:25:182 / Josh Adams / Oct. 5, 2014 / Ohlins Road and Track, Delicious Stage 1 93 tune, ACT Prolite Clutch/Flywheel, DSS CF Drive Shaft, Whiteline Pos. Shift Kit & Diff Cradle, Perrin Motor Mounts, Essex AP Racing Sprint BBK, Hawk DTC-60, K&N Drop In Filter, Crawford Performance AOS, Hoosier R6 225/45R17, 70lbs. of ballast
[ame]http://youtu.be/l-KmaoAZkYY[/ame]
Conditions were pretty good for this event with nice, cool November air. Dropped just about a second from my previous best trying to be smoother in the corners and working being slower in and faster out of the corners.
Old 11-10-2014, 06:06 PM   #178
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
Great line. Drivers going for the first time can learn a good deal of what they need to know by watching this video.
dradernh is offline   Reply With Quote
Old 11-11-2014, 08:42 AM   #179
ja1217
I had a later session where I think I took an even better line into the carousel. Here's the clip:
[ame]http://youtu.be/i638doMCCdI[/ame]
Old 02-16-2015, 08:54 AM   #180
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Sebring Int'l Raceway / 2.35.98 (via AIM Solo II) / Scott Bartlett / Jan 24 2015 / RCE T2s, TF Brake Cooling kit, Cobalt XR2 pads, 215 Nitto NT-01 (on cords!) on 17x7 Motegi MR125, RevWorks UEL header, DC catless front pipe, OEM mid-pipe, Nameless muffled track pipe, OpenFlash tablet.
[ame]http://youtu.be/z5ScFqY8JTQ[/ame]
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
Old 02-26-2015, 02:34 AM   #181
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Calabogie Motorsports Park Laps, Ottawa, Ontario Canada
Stock
Calabogie Motorsport Park/2:34.8/Andre Corriveau/Sept.22,2012/Stock everything incl. Michelin Primacys
Date Sept.22, 2012
Time 5pm to 7pm
Calabogie
Weather = Cool
Lap timer data from lap 17
17
1 0'33.5" 33.5 17
2 0'24.5" 24.5 17
3 0'43.8" 43.8 17
4 0'08.8" 8.8 17
5 --'--.-" 44.2 17
6 --'--.-" 154.8 17 2'34.8"
Slick is offline   Reply With Quote
Old 02-26-2015, 03:23 AM   #182
Slick
Slick's Avatar
NA
Calabogie Motorsport Park/2:29.5/Andre Corriveau/Aug.30,2014/OFT w/E85 Stage 2 tune, headers, ProKit springs on stock dampers, Hankook RS3 255/35R18 on 18x9 wheels, HP+ pads
Lap timer data
Sector 1 27.7
Sector 2 23.4
Sector 3 31.3
Sector 4 20.3
Sector 5 46.8
149.5 2'29.5"
Fast lap starts at 2:35 in vid. Was Bimmers and Porsches for dinner that evening.
[ame]http://youtu.be/Lp5Om06NUKc[/ame]
Can too much grip hurt track times? ayau Tracking / Autocross / HPDE / Drifting 53 04-22-2013 10:28 AM
Top Gear (UK) track times GeeTee86 AFRICA 29 02-15-2013 07:04 AM
Before/After Track Times (Sonoma Raceway) CorteXracing Tracking / Autocross / HPDE / Drifting 5 11-26-2012 10:28 PM
POST YOUR FASTEST GT5 NURBURGRING TIMES.... FT-86GOD Other Vehicles & General Automotive Discussions 96 07-15-2012 12:45 PM
GT5 - fastest Suzuka (full track) times NESW20 Other Vehicles & General Automotive Discussions 11 04-03-2011 12:20 AM
