#169 | |
Drives: CBR600F4I, CBR1000RR, Prius
That brings up an interesting point. I wonder why car companies advertise horsepower at the engine rather than at the wheels? It is confusing to people since it isn't actually power to the ground. It seems like power at the wheels would be a more meaningful number. |
#170 | |
Drives: First SWP BRZ-L
HP Sells cars. it's all marketing. |
#171 | |
Site Moderator
Drives: ichi 86 Project
#172 | |
i'm sorry, what?
Drives: Canada
engine power is measured in controlled environments that few street dyno shops have, and most don't even care about. wheel dynos are affected by gear ratios and load ratings. When i was testing my stock VW Golf, they couldn't do the run in 4th gear because the car couldn't load the dyno properly, so i did a run in 3rd gear. I made 104HP in 3rd gear, and another car made 170hp in 4th gear, do you think it's fair to compare the two? while HP sells cars, the reason HP sells cars is because of consumers, not the manufacturers. They just tell you a factually proven number, and YOU go gaga over it. So the fault is not with them. Personally, i think the best indicator of a car's performance is lap-times at your local proving grounds. 200HP or 500, if you can beat that Lotus Elise by 1 second then you know where you stand
#173 | |
Hot Dog
Drives: quicker than arghx7
SAE J1349 power ratings are done under a very strict scientific standard. It's a voluntary rating, however it basically forces all manufacturers to abide by it or risk being raked over the coals for false advertising [if a non-compliant manufacturer decides to advertise power too high, like the class-action lawsuit against Ford for the 1999 Mustang Cobra being underpowered versus its advertised rating]. SAE J1349 is repeatable and consistent. On the flipside, most "tuner shops" that have various chassis dynos are rarely if ever calibrated to any standard. Allowing the customer to "certify" their car with uncalibrated equipment is absurd. Furthermore, the OEM cannot be held responsible for a vehicle once it's been released to the wild. Who knows what sabotage [intentional or ignorant] the customer took on his car to obtain lower-than-expected peak power figures. Using the wrong oil, poor break-in, keeping the hand-brake on, improper airflow, sand in the gearbox, etc., are all things outside the control of a proper scientific test in a laboratory. Chassis dynos are used by OEM's, but not to obtain certified power data.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products. |
#174 | |
No problem Chess. Even if it was a basic question, its still a far cry from the "no push-start, dual climate control...etc", whining that's been going around on the forum.
Everyone who complains about the power....generally are not the ones who have experienced being able to push a slow car faster than a slow guy pushing a faster car slower. Much MUCH more fun to go fast in a slow car, than it is to go slower in a faster car. |
#175 | |
MODERATOR-SAMA
Drives: Swagtron Scooter
but still comparing too a more accurately matched EJ204 vs FA20 based on our assumptions. EJ204 (AVCS) 200hp @ 6500rpm / Redline @ 7000rpm FA20 (DAVCS & D4S) 200hp @ 6250rpm / Redline @ 7500rpm .......what the hell.....im so confused
#176 | |
Site Moderator
Most of that EJ204 juice was coming from ECU setup. I think Subie did awesome job on that... but at the same time, it's totally a bitch to reflash. Unless you wanna do Stand Alone, it's a waste reflashing that ECU (of course, I stand to be corrected). vs FA20 ECU isn't highly tuned like EJ204 ECU... ZN6/ZC6 ECU are there for standard/basic... All other aftermarket company can reflash it to make more HP & fix few drops in the graph, so there's a hope for that top end drop. |
#177 | ||||
Pro Subie Engine Nerd
Drives: BRZ has a reserved space
The lesson is don't cheap out and bulletproof it and you won't have internally caused (relative to engine) issues...unless you are 'that' point. Then expect scheduled rebuilds depending on usage. Quote:
![]() ^^true story about a middle aged man in his C6...then he punched it on the interstate and I started laughing. Quote:
With that being said, I'm still hunting 125 hp/L on pump without a lopey idle. |
#178 | |
Drives: 2006 Subaru LGT
![]() It was two friggin' years before the refresh on the bugeye WRX to go to 2.5L. I can only assume the same for the jump to FI.
#179 | |
MODERATOR-SAMA
lol mad libs time!
#180 |
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
Lol!!!
#181 |
#182 |
| Any publication strap this car on a dyno yet? | mspeed6 | Engine, Exhaust, Transmission | 67 | 02-02-2012 04:48 PM |
| Autoguide gushes on Scion FR-S (w/ track drift video). Says destined to become icon. | ZetaVI | Scion FR-S / Toyota 86 GT86 General Forum | 111 | 12-16-2011 02:47 AM |
| Dyno testing and "drivetrain loss" | serialk11r | Other Vehicles & General Automotive Discussions | 5 | 11-03-2011 08:55 AM |
| Best drift ever | Matador | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 05-11-2010 01:48 PM |
| ft-86 drift | trueno | Scion FR-S / Toyota 86 GT86 General Forum | 46 | 01-21-2010 04:39 AM |
