#169 | |
I wanna go fast
Drives: 2013 FR-S 6MT
Can this be achieved with the +35's, or +45 w/small spacer? |
#170 | |
#171 | ||
The Angry Brit
Drives: 1991 E30 318iS
At full right lock I get a touch of rub every now and then, not every time, I'll notice it pulling into a parking spot. But for regular driving. Absolutely no rub what so ever. It's not tire rub though. I've pulled the wheel to see exactly what it is but with no luck, I can't find any chaffing marks. I'm not sure my camber settings right now as I just re-adjusted the coilovers recently and need to get it realigned. If I had to guess its at about -2 in the rear and almost neutral up front. And again, no rub. Quote:
I havent began auto crossing yet, once I get my rear sway in I will be getting into the swing of things. I'm getting the car booked for an alignment next week. Probably going to run -2.5 up front and -2.0 in the rear. With the current 0 up front it understears like a fail wheel drive on hard cornering |
| The Following User Says Thank You to VacantSky For This Useful Post: | 2much (08-13-2014) |
#172 | |
#173 |
The Angry Brit
I like the turning radius with the +45's, and the fact that it's less stress on the suspension. I'll be doing a mild brake upgrade for pedal feel with subaru 4 pots and I'll need a small spacer for those, 3-5mm. I'm very happy with the +45's. The +35's made less sense to me personally, my top hats are adjustable for camber so for long journeys I can adjust those to minimize inner tire wear and the wheel wont poke when/if I do. It's a DD first, track rat second.
I'll post up pics with my alignment info when I get it done so people can see how the wheels sit |
#174 | |
As for poke, -1.3 will be flush with +35, doubt that is bad for dd.
#175 | |
The Angry Brit
Sheesh. Not to be a ****, but isn't the purpose of this particular thread so people can discuss the +45 9 inch wide rpf1. I dont need a spacer to not rub, and a 3mm one for brake clearance is nothing. If budget permits I will run the wilwoods and not even have to run a spacer. I didn't buy these wheels for this car. I had them on the SAAB orginally. Which even with these wheels and rolled fenders I was pushing the functional limits on the stock "wrx" wagon bodys capabilities without pulled fenders and herrafrush for wide wheels. Then I sold the SAAB, and put them on this car because they worked, they looked good, and are very functional for the purposes of my car. Do you go into the 17x8 and 17x7 rpf1 threads pushing the 17x9 +35's on people, telling them they bought the wrong wheel in your opinion too? Perhaps you should take pride in the fact that you bought the *correct* wheel if you have the +35's and that everyone else is inferior, rather than down talk what some one else is doing to their car |
#176 | |
#177 |
3 x lemons chump
Drives: 14 FR-S; 94 Sentra; 91 Miata
What coilovers are folks running with these wheels?
I tried the wheels on last night and the clearances with the stock spring perch are too tight for me to feel comfortable. I'm lowered on the Eibach Pro-Kit (knew I'd be getting coilovers eventually). It's a few mm from rubbing against the perch. I'm looking for a track setup and to stay within SCCA STX rules, so probably going to get a set of KW Variant 3s unless there's another suggestion. |
#178 |
Drives: FR-S [Hot Lava]
It IS close. But it will not rub there. I've done 5+ track days with that setup and no rubbing except when turning a full lock to the right. The perch is not going to rub though.
#179 |
Drives: 2013 fr-s
I'm on Eibach R2's...no rubbing
#180 |
Drives: 2013 Whiteout FRS
Anybody figure out what the wheel is rubbing on at full lock yet? I'm wondering if that can be remedied with careful camber adjustment. Also to the people who are rubbing, are you running any spacers at all? I'm interested to know if something like a 3mm spacer up front fixes the problem.
#181 |
Drives: 2013 Scion FRS firestorm
Completely stock suspension. Tight fit for sure, only about the car key gap between tire and spring perch in the front.
#182 | |
Drives: Brz
any idea if a +35 17x9 will hit the tie rod at full lock? I'm looking at getting those on my eibach pro springs. thanks |
| The Following User Says Thank You to Vicsweet For This Useful Post: | s2d4 (09-30-2014) |
| Wheel Directory: Enkei RPF1 17x9.0 +35 | D1cker | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 801 | 06-18-2024 07:31 AM |
| Wheel Directory: Enkei RPF1 18x9.5 +38 | FRS8SIX | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 297 | 02-15-2018 04:50 PM |
| Wheel Directory: Enkei Kojin 17x9.0 +45 | Clipdat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 42 | 08-02-2016 05:18 PM |
