#169 |
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
Yeah... I would toss in a couple dollars for an accurate camber curve.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion 2017 Bluenose Autosport Club Overall Rallycross Champion Powered by Great North Performance, Jani-King Canada, and OK Tire. |
#170 |
Frosty Carrot
Drives: The Atomic Carrot
Found a cool bit of code that might be useful for this crowd.
It's a MATLAB code that simulates shock dyno graphs. Here's a cheat guide for our front suspension: cwlbs = 618; srppi = 131; spmr = .92; shmr = .92; lsd = .65; knee = 3; hsd = .1; And the rear suspension: cwlbs = 539; srppi = 211; spmr = .83; shmr = .83; lsd = .65; knee = 3; hsd = .1; TL;DR - calculate wheel rate, calculate the critical damping force, build a set of low speed damping forces, build a set of high speed damping forces, graph everything. function y=critdamp(cwlbs,srppi,spmr,shmr,lsd,knee,hsd) %cwlbs=corner weight, lbs minus unsprung for more accuracy %srppi=spring rate, lbs per inch %spmr=spring motion ratio %shmr=shock motion ratio %lsd=low speed damping, percentage of critical %hsd=high speed damping, percentage of critical %knee=location of knee, in inch per second lbf2n=4.448; % 1 lbf = 4.448 newtons m2i=39.37; % 1 meter = 39.37 inch p2kg=0.4536; % 1 lb=0.453 kg if (spmr>1)+(shmr>1) disp('Motion ratios must be less than 1, but I''ll convert it for you') spmr=1/spmr;shmr=1/shmr; end wheelratestandard=srppi*spmr^2 wheelratemetric=wheelratestandard*lbf2n*m2i cd=2*sqrt(wheelratemetric*cwlbs*p2kg)/lbf2n/m2i/shmr^2 vel=(0:0.1:20); damp=lsd*cd*(0:0.1:knee); hispeed=damp(end)+(0:0.1:20-knee)*cd*hsd; damp=[damp hispeed(2:end)]; plot(vel,damp,'r','linewidth',2,'displayname',['LS:' num2str(lsd*100) '% Knee:' num2str(knee) ' ips HS:' num2str(hsd*100) '%']) legend('off');legend('show','location','east')
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX Wall of Shame - aFe Takeda, Wilwood, FA20Club Last edited by Shankenstein; 01-20-2015 at 02:07 PM. |
#171 | |
Drives: Fr-s
| The Following User Says Thank You to redlined600 For This Useful Post: | fika84 (01-20-2015) |
#172 |
Frosty Carrot
Just as a quick exercise, I wanted to see what spring rates would yield different natural frequencies.
Ks = 4*pi^2*f_natural^2*m_sprung*motion_ratio^2 note: OptimumG uses motion ratio of wheel/spring (>1) Here's what I found (fronts and rears in kg/mm). 1.5 Hz = 3.000 / 3.213 1.6 Hz = 3.413 / 3.656 1.7 Hz = 3.853 / 4.127 1.8 Hz = 4.319 / 4.627 1.9 Hz = 4.813 / 5.156 2.0 Hz = 5.332 / 5.713 2.1 Hz = 5.879 / 6.298 2.2 Hz = 6.452 / 6.912 2.3 Hz = 7.052 / 7.555 2.4 Hz = 7.679 / 8.226 2.5 Hz = 8.332 / 8.926 2.6 Hz = 9.012 / 9.655 2.7 Hz = 9.718 / 10.412 2.8 Hz = 10.452 / 11.197 2.9 Hz = 11.211 / 12.011 3.0 Hz = 11.998 / 12.854 That covers most of the coilover rates out there. Far North Racing suggests: Street car: 0.8 Hz Occasional autocrosser: 1.0 - 1.5 Hz Full-bore autocrosser: 2.2 - 2.5 Hz Most people don't recommend a completely flat ride. For a street car, you might use 1.5 Hz front and 1.7 Hz rear. That puts us at 3K/4K. Most of the lowering spring kits are in that ballpark or slightly stiffer. For a track car, 2.3 Hz in the front and 2.5 Hz. That puts us at 7K/9K. KW, Ground Control, and RSR coilovers have similar ratios, but slightly softer. Interesting to see how many coilovers are super-stiff in the front. That probably leads to a better feel and less actual grip.
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX Wall of Shame - aFe Takeda, Wilwood, FA20Club |
#173 |
Drives: S60R/Corvette
Cool thread. I'll see what I can contribute after this weekend.
Ryan M.
Strange Engineering Director of Suspension Development |
#174 | ||
Drives: '23 BRZ
For the FR-S/BRZ, motion ratios are ~0.95 front and ~0.75 rear, from what I've gathered... So in the equation above you would use (1/0.95) and (1/0.75) for "motion ratio". Important to use the right units of course, kg for mass and N/m for spring rate is easiest. N/m is kg/mm * 9.81 * 1000 Quote:
Assuming 2950 lb. car (with driver), 54/46 weight distribution and subtracting 50 lb. from total weight at a corner to get sprung weight, I came up with 338kg sprung mass for a front corner and 286kg sprung mass for a rear corner. Looking at 2Hz for an FR-S/BRZ, I get: front Ks = 4pi^2 * 2Hz^2 * 338kg * (1/.95)^2 = 59,141 N/m = 6.0 kg/mm rear Ks = 4pi^2 * 2Hz^2 * 286kg * (1/.75)^2 = 80,290 N/m = 8.2 kg/mm Running your 5.332 and 5.713 kg/mm spring rate numbers, or 52,307 N/m and 56,045 N/m, I get f = (1/2pi) * sqrt(k*motionratio^2/m) f front = (1/2pi) * sqrt (52,307*0.95^2 / 338kg) = 1.88 Hz f rear = (1/2pi) * sqrt(56,045*0.75^2 / 286kg) = 1.67 Hz 2 Hz is generally a pretty good street/track compromise. That is, too stiff for the street and too soft for the track! The rule *used* to be to have a slightly higher rear natural frequency than front, but that has reversed over the past ~15 years or so. For feel, my impression is that biasing stiffness to the rear improves feel and biasing to the front reduces it, but "feel" is often subjective... Last edited by ZDan; 02-14-2015 at 11:51 AM. |
| The Following User Says Thank You to ZDan For This Useful Post: | timurrrr (07-14-2020) |
#175 |
So here is the front info I can gather. I admittedly have never analyzed a strut suspension in this software before so maybe I input something wrong but the data points are exact.
Front suspension @ stock ride height Roll center height: 3.140" (Drops below the ground plane at only 1" bump) Caster: -5.937 deg Motion ratio: .95 and rising rate with bump. -1.5" bump (or lowered ride height) =.997MR. -2.5" bump = 1.050MR Camber gain: -0.262 deg at 1" bump travel. Parabolic curve bottoms out at only 1.6" of bump travel, camber gain switches to positive ![]() Pure roll scenario from -3 deg (right turn) to +3 deg (left turn) @ stock ride height The black vertical line indicates -1 deg of roll and the data points at -1 deg are in the colored boxes on the right. ![]() This one is particularly nasty. This is a plot of -3 to 3 deg of roll at a ride height of -3 on the far left to +2 on the far right in 0.10" steps. The vertical black line is at -1" ride height which is right around where the roll center goes crazy shooting off to infinity and switching back and forth above and below the ground plane. I wouldn't personally ever set a BRZ to a 1" drop after looking at this without roll center correction. ![]() Unfortunately, I think there is very little I could say about this layout that's positive. I've heard the OEMs have used the rubber bushing deflection to their advantage which I can't do, perhaps that was done with this suspension but installing sphericals, delrin, or polyurethane would eliminate that anyway. If anyone thinks this was worth a little donation for my time, donate something to alz.org. On to the rear...
Ryan M.
Strange Engineering Director of Suspension Development Last edited by RBbugBITme; 02-25-2015 at 02:15 AM. |
| The Following 9 Users Say Thank You to RBbugBITme For This Useful Post: | bju90 (07-14-2017), Briankbot (02-25-2015), Calum (02-25-2015), GSpeed (07-24-2015), Racecomp Engineering (02-25-2015), RedReplicant (05-17-2023), RJasonKlein (09-22-2015), Shankenstein (02-25-2015), Wepeel (02-26-2015) |
#176 | |
Because compromise ®
Drives: Red Herring
) what the consequence of dropping more than 1" inch is?
#177 |
I can't believe I'm condoning this but if this is all correct, you're going to want to drop your car at least 1.5" and probably increase caster a degree. At that point you still have pretty bad but controllable camber gain (about +1deg per deg of roll), you keep your roll center from shooting off to infinity but it is still passing back and forth through the ground plane (not good) and the moment arm to the CG is seriously non-linear. So with that drop I'd get some kind of roll center correction but I haven't analyzed that yet.
-3 to +3 pure roll, no steering, at -1.5" drop
Ryan M.
| The Following 5 Users Say Thank You to RBbugBITme For This Useful Post: | Calum (02-25-2015), Racecomp Engineering (02-25-2015), RedReplicant (05-17-2023), Shankenstein (02-25-2015), Wepeel (02-26-2015) |
#178 |
The SquadWhisperer
These graphs are REALLY helping me understand what is going on with our suspension and I'm starting to understand the problems you are outlining.
Thank you for your time, a donation will be made later today. Quote:
| The Following User Says Thank You to Thorpedo For This Useful Post: | RBbugBITme (02-25-2015) |
#179 |
Awesome stuff, thanks Ryan!
What software is that? - Andy |
#180 |
WinGeo
Ryan M.
| The Following User Says Thank You to RBbugBITme For This Useful Post: | Racecomp Engineering (02-25-2015) |
#181 |
That Guy
Drives: 2013 asphalt FRS MT
@RBbugBITme
What ride height, relative to stock, would you say is best? Or is it just a matter of also preforming the roll center correction when lowering? |
#182 |
i'm sorry, what?
Drives: Canada
| New Rumor: Subaru Developing Turbo 4 2.0T for BRZ | Hachiroku | BRZ First-Gen (2012+) — General Topics | 350 | 02-02-2013 02:52 PM |
| Need opinions on two new items we're developing! | yospeed | Cosmetic Modification (Interior/Exterior/Lighting) | 56 | 12-03-2012 03:13 AM |
| Chances of Someone Developing 5x114.3 HUBS (not spacers)? | Entropy | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 08-04-2012 04:35 PM |
| Hi-res pics & list of BRZ JDM model grades from stripped down base model to STI(?) | switchlanez | BRZ First-Gen (2012+) — General Topics | 68 | 02-14-2012 08:16 AM |
