Old 08-22-2013, 06:00 PM   #169
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Ah thanks! You're right. When I opened it up I knew I needed more than one, so when I ordered them from the dealership and was quoted less than a buck each I excitedly ordered a few just in case. I went off my erroneous memory after I installed the screws needed. I appreciate the correction!
Old 08-22-2013, 08:14 PM   #170
AG3NT_5CARFAC3
86 Owners of New England
AG3NT_5CARFAC3's Avatar
Drives: Toyota GT86
where is the cheapest place to buy the Speaker Grills and the Rings? Nigel is $130.
Any help would be great.
I have the speaker panels already
Thank you
AG3NT_5CARFAC3 is offline   Reply With Quote
Old 08-22-2013, 09:15 PM   #171
djdnz
1337
Drives: 2013 BRZ WRB S/C
Thank you
I ordered mine from www.japanparts.com, they shipped very quickly and price was good. Not sure if it's better or worse than Nigel, just another option for you.
djdnz is offline   Reply With Quote
Old 08-22-2013, 10:32 PM   #172
AG3NT_5CARFAC3
Drives: Toyota GT86
Do you have the part numbers for the Speaker Grill and the Grill Rings? Will need them for both sides :happy0180:
Old 08-23-2013, 07:00 AM   #173
Admiral Ballsy
Shorter of breath
Admiral Ballsy's Avatar
Drives: a soft bargain
The japanparts site has the part numbers; there's a 'kit' under Subaru interior (other) that has all three pieces, and lists the part numbers for each.
Admiral Ballsy is offline   Reply With Quote
Old 08-23-2013, 08:35 AM   #174
that_guy
Dances with Cones
that_guy's Avatar
Drives: 2013 Scion FR-S Raven
I just ordered these from Toyota. Much easier since they are standard on the 2014's now.
2013 Scion FR-S - Raven
2011 Scion tC - Cement - SOLD
that_guy is offline   Reply With Quote
Old 08-23-2013, 08:50 AM   #175
nalc
Drives: 13 BRZ Limited 6MT GBS
Originally Posted by Kimsey47 View Post
Is this going to be as easy in a BRZ with push start? I'm in the same boat where my tray will just NOT release. I was thinking that if i took my console apart that it could help???
Take off the long, narrow trim piece between the passsenger side inboard knee pad and the footwell (It's 3" tall, maybe 12" long, goes from the center console forward, right below the molded "kneepad" piece)
Reach behind the start button trim piece, and pop out the USB/Aux ports. It's a single rectangular assembly, and it pops out if you push it from behind. Once it pops out, pull it forward an inch or two, there's enough slack on the cable.
Now, stick your finger in the hole for the USB/Aux port, and just pull the whole trim piece out.
It took me 45 minutes of frustration following the DIY guides to figure it out, but once you know that trick, it's a piece of cake. I can have it apart in 10 seconds now.
nalc is offline   Reply With Quote
Old 08-23-2013, 08:53 AM   #176
nalc
Can you provide some info on that? Part numbers? Did you order them from your dealership or a website? Was the price lower than the JDM ones?
I've been thinking that I needed to wait til 2014 deliveries start in November to order the new parts from my dealership or a US parts website.
Old 08-23-2013, 09:31 AM   #177
Kimsey47
Kimsey47's Avatar
Drives: 2016 STI DGM
I'll give this a go this evening! I too have looked at the walk throughs and gave up after nearly 30 minutes scared that I'd eventually break something. Thanks!
Subaru STI :
Old 08-25-2013, 11:36 PM   #178
Kimsey47
Kimsey47's Avatar
Nalc - You DA man! Got them in and they look great... Thanks for the tip on the USB piece. Like you said once you get that you can get things out pretty easily from there. I really appreciate it!!!!:happy0180:
Subaru STI :
Old 08-26-2013, 01:05 AM   #179
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
We should rename this thread to "2014MY conversion"
campy is offline   Reply With Quote
Old 08-26-2013, 06:16 AM   #180
Admiral Ballsy
Shorter of breath
Originally Posted by Trojan_SC View Post
Unscrew the shift knob. (easy enough)
What was the purpose for doing this?
Old 08-28-2013, 11:42 PM   #181
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Does anyone know the part numbers for the door knee pads + grille cover + silver grille rings?
Fizz is offline   Reply With Quote
Old 08-30-2013, 02:21 PM   #182
that_guy
Dances with Cones
that_guy's Avatar
Well I work for corporate, so I just ordered them from work. But they are now in the system here in Canada and can be ordered. In the USA I think they already had them input. Numbers below.
Door Panel Knee Pads:
(LH) SU003-04437
(RH) SU003-04436
Centre Console Knee Pads:
(LH) SU003-01920
(RH) SU003-01919
Speaker Grilles:
(LH) SU003-04433
(RH) SU003-04432
Speaker Grille Trim Rings:
(LH) SU003-03287
(RH) SU003-03286
Speaker Grille Screws (Required for Installation of Pads):
SU003-02917 (x6)
You need all of the above to complete installation...well, that is if you want both the console and the door pads for both sides...
Toyota Japan 86, FRS, Air Bag, Frameless Mirror, Knee Pad, Sun Visor, Door sill, MOR nigel-jdmparts Interior Parts (Incl. Lighting) 89 02-01-2013 04:00 PM
HID Retrofit Kit install Jidonsu NY / NJ / CT / PA 1 08-04-2012 01:24 AM
How do you install the mud guards? Moshpit37 Scion FR-S / Toyota 86 GT86 General Forum 11 07-27-2012 11:13 PM
FS: console knee foam pads 86_ZN6 Interior Parts (Incl. Lighting) 9 07-21-2012 09:46 AM
Spoiler Install CharlieChaos Cosmetic Modification (Interior/Exterior/Lighting) 1 07-07-2012 10:43 AM
