Old 10-27-2019, 02:43 PM   #169
Trist0n
Trist0n's Avatar
Drives: FRS 10 Series
So I’ve just read through the entire thread, and it all looks like something I definitely want to do. Sorry if it was obvious and I missed it, I’m just a little confused on what exactly I need to make it happen; obviously I need to source a BRZ or GT86 gauge cluster with the LCD, but what’s the difference between the two? I’ve got a push button start FRS, so I know that the gauge itself will be plug and play; but what do I need to do to get the mileage altered to be accurate? Are those joystick chips still for sale? I think I’d like to run it where the turn key would go. Thanks!
Trist0n is offline   Reply With Quote
Old 10-27-2019, 02:51 PM   #170
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
You need only to reflash the ICS93c66 with your corresponding mileage. De-solder the chip on stock cluster,read it and save the image. De-solder same IC on new cluster and write it with saved image of old. Easy. EZP2010 flasher runs very well. You can buy a new IC S93c66 and write directly with image and solder it to new ' 17 display cluster too.
Inviato dal mio SM-G973F utilizzando Tapatalk
Trap63 is offline   Reply With Quote
Old 10-27-2019, 03:34 PM   #171
Trist0n
Trist0n's Avatar
Sounded pretty complex at first but I’ve done enough electrical work I think I can manage. Never heard of the process before, swapping the images sounds easy enough, though I’m a little concerned about damage to the original. So that’ll correct the mileage; what else needs to/can be changed (UI? GT86 vs BRZ cluster?)
Old 10-31-2019, 12:23 AM   #172
geraldjust
Drives: MR2, Sliver BRZ
so for the milage is stored in a eeprom. you need to find the set of bytes you need to change with a eeprom programmer. make sure you dont mess with other bytes becuase it can corrupt the data. Also, there is a "checksum" check to make sure the mileage is correct. if its not then the mileage wont increment. i do offer it as a service too though if you need to to be able to correct it. That is just for milage.
For the UI thats stored in a different chip. to turn a BRZ cluster to a gt86 one with the UI it needs to be flashed. but a gt86 can be easily switched to a brz one though a simpler way. Oh and the GT86 and BRZ the RPM needle are slightly off. haha well the brz one the line on the very top is a bit off center lol.
Always looking to tinker with something..
geraldjust is offline   Reply With Quote
Old 11-06-2019, 12:09 PM   #173
misterfly
Drives: Toyota 86 2017
Hi Gerald, how much do you charge if i send you the chip to rewrite the eeprom
misterfly is offline   Reply With Quote
Old 02-18-2020, 02:16 PM   #174
Trap63
Trap63's Avatar
Wink
here it is!
from this
to this
Old 04-03-2020, 01:37 AM   #175
Xmod
Drives: Toyota 86 GT manual
Originally Posted by DustinS View Post
If there is anything I can do to help let me know. Might be fun to take a look at it see what I can come up with.
Video has been posted, depending on your browser you may need to un-block it.
Center Traction Control Button
Hi Dustin, has the video been removed? cant seem to find it?
Xmod is offline   Reply With Quote
Old 04-30-2020, 09:54 PM   #176
Xmod
Bump Hoping someone could help find this mystery video haha
Old 04-30-2020, 10:04 PM   #177
Xmod
Did some more digging found it.!
Old 05-05-2020, 06:56 AM   #178
tweedbean
tweedbean's Avatar
Drives: White GT86
Hi all, can anyone confirm if there is a simple way to cancel the TPMS light on a 2107 BRZ cluster fitted to a 2013 car without TPMS?
Is there a permanent solution to stop it appearing or do I need to strip down the cluster and tape over the TPMS light?
tweedbean is offline   Reply With Quote
Old 05-05-2020, 04:32 PM   #179
gpvecchi
gpvecchi's Avatar
No way to remove it. You need a cluster from US versions.
gpvecchi is offline   Reply With Quote
Old 05-05-2020, 10:33 PM   #180
churchx
churchx's Avatar
Drives: 2014 GT86
Well, didn't beastronix nanny86 offer also TPMS disabling? Way overkill solution just for that though. (trac-box too though)
Old 05-06-2020, 05:56 AM   #181
tweedbean
tweedbean's Avatar
Drives: White GT86
Ok thanks so looks like taping over the light will sort it for now, just need to work out where the TPMS light is on a BRZ cluster.
Old 06-05-2020, 04:06 PM   #182
Bach415
Bach415's Avatar
Drives: Whiteout FRS
@geraldjust If you don't mind, what are the resistances needed for the directional pad/back button?
Bach415 is offline   Reply With Quote
2017 Limited Gauge Cluster halleffect Electronics | Audio | NAV | Infotainment 26 10-22-2020 07:32 PM
2017 GR edition cluster mod vagthomas Cosmetic Modification (Interior/Exterior/Lighting) 63 06-29-2020 04:41 PM
Help! Is there anyway to change the 2017 cluster start up image? slashlee DIY (Do-It-Yourself) Guides 2 11-17-2018 05:36 PM
2017 Limited Gauge Cluster halleffect Cosmetic Modification (Interior/Exterior/Lighting) 0 01-16-2017 03:55 AM
2017 gauge cluster Drakiv Cosmetic Modification (Interior/Exterior/Lighting) 2 11-14-2016 11:32 PM
