Old 11-20-2016, 01:52 PM   #169
OND
OND's Avatar
Drives: 2023 BRZ
Not bad! 8 sessions between two tracks, and plenty of laps.
Wear is pretty even with the evaluation set of dampers and a last minute eyeballed at the track alignment. Tire temps had less than 12F total delta across each tire AND all 4 tires.
That looks infinitely better than my front tires. Mind sharing your alignment settings? Or at least front camber?
OND is offline   Reply With Quote
Old 11-20-2016, 06:11 PM   #170
I literally eyeballed it at the track. My normal alignment shop would have a heart attack if they knew what I did, but they couldn't squeeze me in. I got the car back Thursday evening, installed an oil cooler, changed all the fluids, and headed out to the track. Ghetto alignment at the track friday (eyeballed), installed pads, flushed brake fluid, then drive 6 hours to another track Saturday for 86CUP...
My guess would be around -3.5 to -4 camber. Toe was eyeballed to 0, as was toe. Friday was used as a shakedown to determine "more or less" with alignment and pressures for Saturday. The picture is from the end of Saturday. This was done with a floor jack, a few wrenches, and a set of allen keys, and a tape measure.
This is just temporary.
I believe this is the most evenly chunked set of stock tires I've seen.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
aegisdrgn (11-20-2016), brzaapi (11-21-2016), OND (11-21-2016)
Old 11-21-2016, 01:58 PM   #171
OND
OND's Avatar
Drives: 2023 BRZ
Any pics of how the car looks with stock wheels and that much camber? I am planning to buy a 2nd set of camber bolts and max out the front camber. Just hoping it doesn't look terribly sunk in.
Old 11-21-2016, 02:05 PM   #172
I gotta dig it out of the phone, but "hellasunk".
I have more camber than can be managed with camber bolts; I have two bolts and a plate on each front.
OND (11-21-2016)
Old 11-21-2016, 03:58 PM   #173
OND
OND's Avatar
Drives: 2023 BRZ
Lol OK thanks, worst case I know it looks "purposeful", best case I convince my wife that it looks horrendous and I need new wheels.
The Following User Says Thank You to OND For This Useful Post:
CSG Mike (11-21-2016)
Old 11-21-2016, 05:58 PM   #174
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Nice, glad to see you finally got one! ha
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-22-2016, 07:18 AM   #175
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
Any insight at all from this weekend?
How'd eyeballing the camber work out for you?
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
Old 11-22-2016, 05:37 PM   #176
I'm not an expert, but it was "close enough" for what I could do on short notice.
with a 6k/6k damper setup, by slightly underdamping the rear, I could throttle steer through corners at will with weight transfer.
Now, granted, I'm on a ceramic coated Ace A/350 header, and E85, so I do have quite a bit more power than a stock car, but as long as I was not in terminal understeer, I could actually balance the car as I saw fit.
This was all with the stock tire; with a stickier/wider tire setup, I would not be able to rotate the car with just the throttle.
brzaapi (11-23-2016), why? (11-23-2016)
Old 11-22-2016, 06:06 PM   #177
strat61caster
strat61caster's Avatar
Sorry if you've posted this before but pedal dance works the same on the '17?
Edit: I'd suggest updating the pedal dance thread with whatever info you have when you're ready.
ineedyourdiddly
Old 11-22-2016, 06:36 PM   #178
johan
Drives: '14 981CS, '99 NB1
Pretty sure there's no good reason to do the pedal dance on a 2017 MT model as simply holding the traction control button for 3 seconds turns off the brake LSD function.
johan is offline   Reply With Quote
The Following User Says Thank You to johan For This Useful Post:
funwheeldrive (11-22-2016)
Old 11-22-2016, 09:07 PM   #179
The pedal dance is still needed.
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
brzaapi (11-23-2016), funwheeldrive (11-23-2016), Lonewolf (11-22-2016), strat61caster (11-23-2016)
Old 11-23-2016, 07:14 AM   #180
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Good to know, i was under the impression that it wasnt needed for the 2017 either. Even with the new "full off" mode, does the emergency brake booster
feature still kick in while under trail braking?
I guess Beastronix will still be needed.
Cornering? So is there any way to set the twins up to have more sensitive rotation, even with proper sticky rubber. So if i lift, or brush the brake, the cars nose will show me that it is listening. I love corner entry on this car, but mid corner I now know (thanks to you btw, ignorance was bliss) that the car is stubborn on rotation.
Daily: Audi TT RS
Old 11-23-2016, 12:02 PM   #181
That part of the setup, I suspect, will be identical to the 13-16. I haven't gotten that far... yet....
Old 11-23-2016, 12:08 PM   #182
johan
Can you articulate why precisely?
Mad Mike's Firestorm Build Mad_Mike Member's Car Journals 90 01-21-2026 09:08 PM
My thoughts on my build (Down South in Africa)! 86 South Africa Member's Car Journals 2 02-02-2016 07:55 AM
Mike&Ikes WRB Build Mike&Ike Member's Car Journals 8 09-18-2015 03:12 AM
Mike Mac's Raven FR-S NYC Build ScionFR-S Member's Car Journals 5 06-07-2014 01:49 PM
Mike's CS FR-S build mikef Member's Car Journals 6 04-25-2013 09:11 AM
