Old 07-18-2014, 05:18 AM   #1793
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by noob001 View Post
Does anyone know what size the banjo bolt washer is? i have a slow leak at the reservoir and can't seem to fix it by tightening down the nut or moving the banjo fitting around.or any ideas on what i can try beside replacing the banjo washer?
I'm guessing you're referring to a copper washer. If so, hang the washer from piece of wire and heat said washer with a propane torch until it's a bright red. With will anneal the copper and allow it to make a better seal. Wait for it to cool down and give it a try.
Old 07-18-2014, 12:43 PM   #1794
Jcl
Drives: 2014 BRZ
@digital_assassin just received my kit!
Jcl is offline   Reply With Quote
The Following User Says Thank You to Jcl For This Useful Post:
Freeman (07-18-2014)
Old 07-20-2014, 11:21 AM   #1795
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Kraftwerks Supercharger Owners Thread
Anyone else in here get the oil cooler kit?
Edit: and anyone running a different spec of oil other than OEM?
Freeman is offline   Reply With Quote
Old 07-20-2014, 11:42 PM   #1796
Jcl
Drives: 2014 BRZ
Is this the correct map sensor guys/gals?
Old 07-20-2014, 11:55 PM   #1797
captain_jack
captain_jack's Avatar
Originally Posted by Jcl View Post
Attachment 85641
That what they sent you or are you getting tuning done by someone else? If they sent it with the kit and they are providing you with a tune then I'd assume it's the right map sensor.
The Following User Says Thank You to captain_jack For This Useful Post:
Jcl (07-21-2014)
Old 07-21-2014, 12:02 AM   #1798
SPCorBUST
SPCorBUST's Avatar
Should be okay. I have the red 4 bar version of that.
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
The Following User Says Thank You to SPCorBUST For This Useful Post:
Jcl (07-21-2014)
Old 07-21-2014, 12:46 AM   #1799
Jcl
Drives: 2014 BRZ
Just making sure, it is the one they sent. Just heard in the earlier stages that people were getting the wrong ones so just checking before install.
Freeman (07-21-2014)
Old 07-21-2014, 12:46 AM   #1800
Taino-BRZ
Taino-BRZ's Avatar
Drives: Subaru BRZ-SWP
Put some 265s, Mickey Thompsons on the back for some drag racing and now I'm getting a p0500 code, and the car goes into limp mode, and traction control light, power steering, hand brake, abs, cel, lights came on. After 4k car goes into limp mode. Anyone knows how to fix that? Maybe the weight on the back compared to the front is causing this. After I erase the code cars goes back to normal then drive 10 miles and Christmas lights again on my dash.
Taino-BRZ is offline   Reply With Quote
Old 07-21-2014, 12:51 AM   #1801
Freeman
Freeman's Avatar
Speed sensor code. Someone more knowledgeable than me might be able to help troubleshoot.
For some reason I'm thinking tpms?
The Following User Says Thank You to Freeman For This Useful Post:
Taino-BRZ (07-21-2014)
Old 07-21-2014, 12:52 AM   #1802
SPCorBUST
SPCorBUST's Avatar
Does it go back to normal if you switch back to your previous setup? I know I Christmas tree a bit on the dyno rollers since the front wheels aren't moving, but it goes back to normal once it drives for a bit
Old 07-21-2014, 12:54 AM   #1803
Taino-BRZ
Taino-BRZ's Avatar
Haven't try that, but happened right after putting the fatties, I'm going to switch tomorrow and try to replicate the problem.
Old 07-21-2014, 12:56 AM   #1804
Freeman
Freeman's Avatar
The new tires.... are they on the same wheels as the previous tires?
Old 07-21-2014, 12:56 AM   #1805
Taino-BRZ
Taino-BRZ's Avatar
Yes on 9.5 wheels
Old 07-21-2014, 12:57 AM   #1806
Freeman
Freeman's Avatar
Dang, thought it was going to be an easy fix!
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 10:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
