Old 07-24-2014, 02:52 PM   #1793
Racecomp Engineering
Originally Posted by FRS Johnny View Post
What are the pros and cons of toe in the back? I remember reading about it, but don't remember much.
It'll help stabilize the rear and keep the car easy to drive fast mostly.
- Andy
Old 07-24-2014, 02:53 PM   #1794
husker741
Originally Posted by jvincent View Post
It might poke a little.
I'm running 18x8.5 +48 with 225/40/18 tires and it looks pretty flush to me. I've got pics in the wheel directory.
What camber are you at front and rear?
husker741 is offline   Reply With Quote
Old 07-24-2014, 03:02 PM   #1795
jvincent
jvincent's Avatar
-1.5* in the front and -1* in the rear. Stock springs and shocks.
There is a ton of clearance in the rear but I only have a few mm of clearance to the spring perch in the front.
Old 07-24-2014, 04:18 PM   #1796
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
I've always eyed -2.0 F and -1.5 to -1.7 R with ~0.1 R toe in.
I'm running Tarmac 0s (so, same rate F/R). I was considering getting a front sway only, one with a mild increase in stiffness, like a 20mm solid bar. Would it help keep the front outside tire planted or should I just keep the stock sways?
Originally Posted by Shoebox View Post
For that price anyone could get a c6z and have money for a simple heads cam package and make a bunch more power and have a superior handling car. This seems overpriced to say the least. "Have it your way" is basically offering someone a massive dildo to shove up their ass BUT they have the option of choosing the method in which it is inserted....
unsurety is offline   Reply With Quote
Old 07-24-2014, 04:34 PM   #1797
gramicci101
Off Topic
- Andy
I've seen people say they run a hair of toe-in on the rear and about a hair and a half of toe-out on the front. What is the purpose of toe-out on the front?
I'm trying to make sure I know what all the parts do, so when I tell the alignment guy specific requirements I know what I'm talking about.
Old 07-25-2014, 01:47 PM   #1798
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
I've a strano bar and I think it needs a bit of aligning (it only bangs on the passenger side)
what's the best way to do this, loosen the clip bolt accessable from below the car (that holds the bushing in place), then loosen the "collars" and just use hand force to move it around?
I remember just trying to clamp it down while it was on the bench was hard... I wonder if it's something I'd be able to do while on my back
Old 07-25-2014, 02:04 PM   #1799
I wouldn't use a stiffer front bar to keep the outside front tire planted. It will help keep the rear planted though. What kind of improvement are you looking for?
- Andy
Old 07-25-2014, 02:13 PM   #1800
Toe-out in the front will make the car eager to turn-in. This can sometimes make the car feel darty or wander on the highway at the extreme.
- Andy
Old 07-25-2014, 02:55 PM   #1801
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
- Andy
Truth be told, I'm not quite sure. I just want to budget for mods. I've seen people upgrade the front bar only, or even take out the rear sway for autox.
I'm sure stock sways on T0s will be fine. I probably need to do more driving. I've only done a couple of autox and taken it to canyon roads. The car went wide in autox, but that's probably due to my driving.
Old 07-25-2014, 03:13 PM   #1802
Gotcha. IMO don't worry about the bars just yet. Get some more seat time and feel the car out a little more.
- Andy
Old 07-25-2014, 03:25 PM   #1803
gramicci101
Off Topic
- Andy
So,
-1.5-2.5 front camber based on the limits of my camber bolt, 0 front toe, OEM caster.
-1.7-ish rear camber based on the natural camber from lowering springs (yellow ones), -1/32 toe on each side for a total of -1/16.
And this will produce a car that is responsive and fun, but still settled and well-mannered on long highway road trips? And not follow grooves in the road?
Sorry for asking so many minor questions, I just want to make sure I've got it down.
Old 07-26-2014, 09:42 AM   #1804
So,
Yup! Rear camber might end up being a little higher but that's OKAY.
- Andy
Old 07-26-2014, 10:00 AM   #1805
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
- Andy
So,
I have the Tarmac springs, which have the same drop as the yellows and I'm at ~-2* rear camber from the drop.
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline   Reply With Quote
Old 07-27-2014, 03:41 PM   #1806
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
What are the "staples" for making the car handle even better, bracing included. For Fox body Mustangs it was sub frame connectors, front strut tower brace and better springs.
What's this car's secret to "slot car" handling?
Bobblehead is offline   Reply With Quote
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
