Old 09-01-2018, 05:57 PM   #1779
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by Yoshoobaroo View Post
Thanks so much!
Wayne's website claims it's both AFR numbers that get skewed, but I can log with my obd reader to compare and make sure.
I did notice the rich spot as well. I'll give the MAF scale tool a shot!
It's possible that he claimed that the O2 sensor scale made it read off, not that the OFT reading was incorrect. You would get the same readings on other devices due to this.
.: Stealth 86 :.
Kodename 47 DJ:
Old 09-01-2018, 07:09 PM   #1780
tomm.brz
Drives: brz 2017 hksv2
actually Wayne really says on his website that OFT logs incorrectly also the actual afr.. but that s wronf, actual afr is logged good with OFT, just the target afr is offset
Old 09-07-2018, 01:47 PM   #1781
Adamf220
Drives: 2013 frs
Can I have someone take a look at my datalog, Im using a revworks catless header, nameless midpipe, Injen catback, and a Injen intake. Im using a OFT with the stage 2+ catless tune. Just want to make sure everything looks ok dont really know what im looking at. 3rd gear pull
https://datazap.me/u/adamf220/log-15...ta=1-9&solo=13
Adamf220 is offline   Reply With Quote
Old 10-07-2018, 03:17 AM   #1782
Mr_Eyo
Drives: 2017 Toyota 86
Got a log here with 3 3rd gear pulls after attempting to scale my MAF. Would appreciate a review. Thanks.
https://datazap.me/u/protoformx/log-....18&tmax=15.01
Mr_Eyo is offline   Reply With Quote
Old 10-07-2018, 04:19 AM   #1783
tomm.brz
you have OFT right? you actually want the "afr" to be 0.2 lower than "command afr" because oft ha some kind of strange offset to the command afr, it s always logged 0.2 leaner than the misured afr
also check your ignition timing, you are having -4 flkc, that s definitely knocking hard, also log the Advance multiplier
Old 10-07-2018, 06:45 AM   #1784
Mr_Eyo
Thanks. I'm stuck on Kodename47's instructions for filtering the logs in vgi's tool. Not sure what the filter criteria are: AND the 3 together? Also, what is the limit criteria for the IAM drop?
Old 10-07-2018, 07:08 AM   #1785
tomm.brz
sorry i m not following you in what you are talking about
afr and maf scaling seem good, but i would make all richer up from 3v of maf voltage of 1%
anyway the AM drop is difficult to understand, i think from what i read in ecutek's pdfs, am drop when flkc collects an amount of ign retard (for example in your log -4.8 at 5600rpm that btw is VERY bad and you should fix it asap in your base timing B table) that is more or equal than the half of the value in the Knock corr A table on the same engine speed/load cell
i think you could have definitely an AM drop on that log but you didn t log the Adv multiplier value
remove Wideband afr from the logs, that doesnt work, and add Adv multiplier
Old 10-07-2018, 11:55 PM   #1786
Mr_Eyo
Thanks @tomm.brz.
3 new logs:
https://datazap.me/u/protoformx/log-...og=0&data=1-12
https://datazap.me/u/protoformx/log-...1&data=1-11-12
https://datazap.me/u/protoformx/log-...2&data=1-11-12
-I enriched the MAF scale above 3V by 1.5%.
-I updated the base timing B table per your directions.
A couple observations of my own:
1. The knock above 4k is greatly reduced but not completely eliminated.
2. I see some knock at low RPMs (<3k). How much timing should I pull for this and the bit of knocking above?
3. IAM did not dip below 1 during the knocking.
4. AFR is not that much below commanded AFR in OL mode. Should I enrich the MAF cal a little more?
Old 10-08-2018, 03:39 AM   #1787
tomm.brz
what tune are you using? which header?
am DID drop, on log wot1, you can see am went to 0.88
maybe enrich the maf just a liiiittle bit up from 3.54v
Old 10-08-2018, 04:18 AM   #1788
Mr_Eyo
OTS Stg 1 91 octane, stock exhaust system.
I set the initial IAM to 0.88 because I saw it was always 1 in previous logs after settling. As soon as I saw it go to 1 I did the pull and it didn't go down.
Old 10-15-2018, 05:09 PM   #1789
craneom
Grease Monkey
Long time reader, first time poster. I have been slowly working on my '13 BRZ and am really delving into self-tuning. I have been running the OFT v4.03 Stage 2+ tune paired with Gruppe-S catless UEL headers and an Invidia R400 exhaust and stock intake. I tweaked the idle up a hair to 800 rpm and adjusted the injector ratio to DI only at idle to help with idle hunting. Other than that, I added the throttle tip-in settings, fans and set the ignition advance to 1. After extensive mileage, the car is running quite rich with consistently high negative LTFT, shown in these logs; https://datazap.me/u/craneom/r104-hi...6-7-9-10-12-14 Since then, I have rescaled my MAF with VGI's tool and removed the throttle tip-in settings and the car feels better than it did before, but is now running a little on the lean side with positive LTFTs and slight knock up top. https://datazap.me/u/craneom/r105-fi...6-7-9-10-12-14 IIRC, the target AFR for WOT is about 11.9 in the upper range. How lean is too lean?
craneom is offline   Reply With Quote
Old 10-22-2018, 11:43 PM   #1790
Mr_Eyo
Got some low RPM/light throttle knock earlier tonight. Any idea what's going on here?
https://datazap.me/u/protoformx/log-...om=12405-12470
Old 10-29-2018, 03:51 AM   #1791
halujeddo
Drives: Subaru BRZ
This is belongs to a friend of mine.
Car is MY17, K00G, EU spec manual BRZ.
Mods:
Tomei UEL catless header
Tomei op
Perrin silicone intake hose
Panel filter
OFT 4.03 stg2+ tune
RON95 fuel (only option in this country)
Oil catch can
Too much negative FLKC and too much negative LTFT.
Bad gas mainly causes FLKC but is that much normal just because of ron95?
What causes that much negative LTFT?
Do you think is there any problem beside bad fuel?
https://datazap.me/u/halujeddo/log-1...0&data=1-10-12
halujeddo is offline   Reply With Quote
Old 10-29-2018, 04:20 AM   #1792
tomm.brz
v4 k00g sucks bad, and the tune makes no sense
copy v4 b01c tables to your k00g tune and try again
timing could be too high cause also of the fuel you get in ur country, so lower a bit base timing B and check maf svaling
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 01:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 09:27 AM
