Old 07-31-2018, 04:10 AM   #1765
tomm.brz
Drives: brz 2017 hksv2
You already paid him,how much.. More than 350 usd i guess? say him you pretend him to. Reduce PI because you don t want an opening timePI of 16ms, and to scale the maf bettwr because you see a correction of 10% and that obvious he didnt spend time to scale it
That to start with.. And then see how the logs are
Old 07-31-2018, 07:05 AM   #1766
steve99
Drives: FT86
Arrh missed the cl loop correction % yoah looks like rr10 closed loop
If
its deliceous they are probably using hybrid speed density and they manipulate a lot of pi\di its very difficult to diagnose thier logs unless you have accesx to tune tables and settings
Somthing weird going on with fuel system though
Old 07-31-2018, 08:44 AM   #1767
tomm.brz
Well with those values they could just tune. Normally with maf and reduce PI.. Logs look so stupud and they think every thing is normal......
Old 07-31-2018, 12:08 PM   #1768
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I don’t think they use maf calibrations as much as map. Sorry, my tuning knowledge is very limited, but that is what I have heard.
Old 07-31-2018, 02:06 PM   #1769
tomm.brz
If those are the results with their hybrid SD tuning... Oh god.
It looks like they could easily go away with normal maf tuning, they could get better results. And still the fact they underuse DI and overuse PI to the point that overpass 15ms of PI opening... Lets me think about their "work"
Good luck with them
Old 07-31-2018, 06:37 PM   #1770
steve99
Drives: FT86
Its possible he has some sort of fuel restriction ie partislly blocked filter or low fuel pressure from in tak pump, this low pressure is not monitored by ecu it only jas info about hogh pressurs fuel pump.
However i had a guy few monts ago with blocked fuel filter and it caused some very weird fuel issues as the ecu attempted to compensate for low fuel pressure
Old 07-31-2018, 08:29 PM   #1771
Irace86.2.0
At first I was asked if I had upgraded the fuel pump because he was concerned that I didn’t seal the pump well. I looked that up and it was a common problem with the O rings, but I hadn’t changed the pump, nor do I know what in the data gave him that impression.
Old 08-06-2018, 05:15 PM   #1772
Irace86.2.0
FWIW, via email I talked to Zach, and it is clear they have gone far to consider the potential negatives of overusing the DIs. I decided to get 700cc injectors n a fuel pump upgrade, and I will be inspecting my DIs for any signs of damage to the seals.
I’m curious about the Edelbrock kit and how they manage to use a 3.25” pulley (82.5mm) without issues, but then again, hasn’t there been issues with their CARB tune and doesn’t DT sell a dbox fix or something? Either way, while the car and tune feel good 80-90% of the time, there feels like there is an issue and the data shows there is an issue, even on the 95mm pulley, so hopefully I can figure it out when I upgrade each componet.
Old 08-18-2018, 06:01 PM   #1773
Irace86.2.0
Update: on the 700cc injectors and im running the 11-12psi pulley without issues. There is probably still DI seal issues but overall everything feels great. Just tip in below 3k the AFR is lean. Going to do a check on those eventually.
Old 08-18-2018, 08:22 PM   #1774
c8Face
c8Face's Avatar
Drives: 2016 BRZ
2nd gear pull OFT v4.02 Stage 2+
https://datazap.me/u/c8face/20180818...og=0&data=1-13
Running Chevron 92 Octane from WA state.
OFT v4.02 Stage 2+
Gruppe-S UEL (stock exhaust header back)
AVO Panel Filter
MFactory 4.67 FD
No idea what I'm looking at...any insight would be appreciated.
Thanks!
c8Face is offline   Reply With Quote
Old 08-18-2018, 09:15 PM   #1775
Irace86.2.0
OFT v4.02 Stage 2+
AVO Panel Filter
MFactory 4.67 FD
Thanks!
If you are asking why there is a boost reading it is probably reading boost/vacuum, and at WOT you should be at 0 and off throttle you dropped to 12 psi of vacuum.
Old 08-29-2018, 07:31 PM   #1776
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Data Logs! Post them here.
https://datazap.me/u/transport3r/way...g=0&data=1-2-8
https://datazap.me/u/transport3r/way...og=1&data=1-12
Running @Wayno Wayne roms 93 octane map at default maf scales.
Stock intake, drop-in filter, JDL UEL header/over/frontpipe.
logged with OFT so AFR numbers read 0.2 high.
Despite that I'm not sure if this is technically borderline too lean, it hits 12 (so 11.8 really) at some points. Depending on where I read about it it's either a problem or not.
In 4th gear (2nd link), there seems to be some knock, showing FLKC activity, but IAM never drops below 1 so I guess it's minor?
The car feels good, especially up top in 2nd and 3rd. When overlaying my old OTS 4.03 logs from last week in virtual dyno it makes more power past 6000RPM than before, but did lose a bit of mid-range, both of which corroborate my initial butt-dyno impressions. Running significantly leaner than on V4.03 as well (11.9 now vs 11.6).
Any suggestions? Thanks for looking!
Old 08-31-2018, 07:31 PM   #1777
tomm.brz
from my experience with 3 OFT, it s just the command afr that it s offset in the logs, so if the real afr hits 12... it's 12.
you should use the vgi maf scaling tool of kodename to scale the maf a bit better, there is a huge rich spot around 3500-4000 rpm and it would make your afr a bit richer after that, probably correcting a bit the flkc you are getting
but probably to eliminate a -1.5 flkc you also need to reduce a bit of ign timing after 6400 rpm
Old 08-31-2018, 09:36 PM   #1778
Yoshoobaroo
TRACKBREAD
Thanks so much!
Wayne's website claims it's both AFR numbers that get skewed, but I can log with my obd reader to compare and make sure.
I did notice the rich spot as well. I'll give the MAF scale tool a shot!
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 01:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 09:27 AM
