| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#17655 |
Drives: 2013 WRB BRZ
Hotchkis front stabilizer bar.
Anyone else experience very little to no clearance between the endlink stud and the control arm when using an adjustable bar? My stud is juuuuust kissing the LCA. Not enough to make a noise, but just enough to make a slight mark. I'm not too worried about it, just wondered.
#17656 |
Live Free, Drive Hard
Drives: 13 BRZ, 19 WRX, 10 GMC, 20 RAV4
Took my BRZ in Monday for the dreaded WTY84 FA20 valve spring recall and picked it up today. Had the dealer install new spark plugs, V-belt, Clutch, pressure plate, flywheel and throw-out bearing just because. Got a 15% discount on parts and labor (1 hour) for the clutch job. Master Mechanic (Joe) kept me informed during the procedure. He did a great job and car runs great...so far - knock on wood! Thanks Joe @ North Park Dominion Subaru!!!
| The Following User Says Thank You to Extreme86 For This Useful Post: | DaBoBo21 (04-11-2019) |
#17657 |
Drives: 2013 BRZ Limited / 2024 G70 3.3T
Finally switched out the embarrassing wusshorns. Used the horn for like the third time ever a few days ago and thought "allright...don't need to hear that again"...
#17658 |
FINALLY removed my clutch pedal spring. It feels so much better now.
Also installed some new Hankook Ventus V12 Evo2 tires. Primacys were at the end of their life for sure.
13 BRZ Limited 6MT Lightning Red
#17659 | |
#17660 |
In the air it's really close, I can't get a great look at in on the ground, but it is leaving a bot of a witness mark so the link stud touches just a hair.
#17661 |
Drives: 2016 BRZ Limited
Checked my damper settings on my coilovers, and found they were all adjusted to something different... any idea what could have caused this? I originally had them at 7 clicks from full hard, as per Tein's recommendations, but upon checking, they were all over the place (Front - 5 & 2, Rears - 7 & 14). Maybe an oversight I made or something. For what it's worth, I have the subaru trunk liner which could have slid around against the damper knobs, so I cut notches out this morning.
#17662 |
The bar will normally touch when you raise the car up. You should turn the wheels to the side with the car on the ground and examine how close the bar really is.
#17664 |
Drives: 2019 BRZ with Performance Package
#17666 |
Drives: 2013 subaru brz limited
| The Following 2 Users Say Thank You to _keepkushin_ For This Useful Post: | AJ32162 (04-17-2019), Prodigalson (04-18-2019) |
#17667 |
Drives: 2017 BRZ w/PP
did my semi yearly interior clean. took everything out, threw out anything i didnt need, vacuumed everything, wiped everything down with armor all, sprayed off all the pollen, and rainxed all the windows and mirrors. also cleaned up the grease in some major parts under the hood, and replaced the cabin filter.
#17668 |
Drives: jrsc_brz
Put on brand new ts 10 wheels today, wish I new how to upload pics, it looks tit
| Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 01:40 PM |
| Got my new FR-S today. | Boosted2.0 | Scion FR-S / Toyota 86 GT86 General Forum | 51 | 06-03-2012 11:35 PM |
| Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 02:48 PM |
| Got my VIN today... | Enemies | BRZ First-Gen (2012+) — General Topics | 63 | 04-12-2012 11:19 PM |
| sat in a BRZ today | NESW20 | BRZ First-Gen (2012+) — General Topics | 8 | 03-31-2012 09:53 AM |
