Old 04-11-2019, 08:15 AM   #17655
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
Hotchkis front stabilizer bar.
Anyone else experience very little to no clearance between the endlink stud and the control arm when using an adjustable bar? My stud is juuuuust kissing the LCA. Not enough to make a noise, but just enough to make a slight mark. I'm not too worried about it, just wondered.
BigTuna is offline   Reply With Quote
Old 04-11-2019, 04:43 PM   #17656
Extreme86
Live Free, Drive Hard
Extreme86's Avatar
Drives: 13 BRZ, 19 WRX, 10 GMC, 20 RAV4
Took my BRZ in Monday for the dreaded WTY84 FA20 valve spring recall and picked it up today. Had the dealer install new spark plugs, V-belt, Clutch, pressure plate, flywheel and throw-out bearing just because. Got a 15% discount on parts and labor (1 hour) for the clutch job. Master Mechanic (Joe) kept me informed during the procedure. He did a great job and car runs great...so far - knock on wood! Thanks Joe @ North Park Dominion Subaru!!!
Extreme86 is offline   Reply With Quote
The Following User Says Thank You to Extreme86 For This Useful Post:
DaBoBo21 (04-11-2019)
Old 04-11-2019, 09:26 PM   #17657
BRZyJ
BRZyJ's Avatar
Drives: 2013 BRZ Limited / 2024 G70 3.3T
Finally switched out the embarrassing wusshorns. Used the horn for like the third time ever a few days ago and thought "allright...don't need to hear that again"...
BRZyJ is offline   Reply With Quote
Old 04-11-2019, 09:54 PM   #17658
j3rf
j3rf's Avatar
FINALLY removed my clutch pedal spring. It feels so much better now.
Also installed some new Hankook Ventus V12 Evo2 tires. Primacys were at the end of their life for sure.
13 BRZ Limited 6MT Lightning Red
j3rf is offline   Reply With Quote
Old 04-11-2019, 11:44 PM   #17659
norcalpb
norcalpb's Avatar
With the car in the air? Or on the ground?
Old 04-12-2019, 09:22 AM   #17660
BigTuna
BigTuna's Avatar
In the air it's really close, I can't get a great look at in on the ground, but it is leaving a bot of a witness mark so the link stud touches just a hair.
Old 04-15-2019, 02:21 PM   #17661
ghst86
Drives: 2016 BRZ Limited
Checked my damper settings on my coilovers, and found they were all adjusted to something different... any idea what could have caused this? I originally had them at 7 clicks from full hard, as per Tein's recommendations, but upon checking, they were all over the place (Front - 5 & 2, Rears - 7 & 14). Maybe an oversight I made or something. For what it's worth, I have the subaru trunk liner which could have slid around against the damper knobs, so I cut notches out this morning.
ghst86 is offline   Reply With Quote
Old 04-15-2019, 04:13 PM   #17662
norcalpb
norcalpb's Avatar
The bar will normally touch when you raise the car up. You should turn the wheels to the side with the car on the ground and examine how close the bar really is.
Old 04-17-2019, 09:10 PM   #17663
_keepkushin_
Drives: 2013 subaru brz limited
Well my accessories belt snapped while driving on the freeway
_keepkushin_ is offline   Reply With Quote
Old 04-17-2019, 09:17 PM   #17664
AJ32162
Drives: 2019 BRZ with Performance Package
What were your total miles as shown on the odometer?
AJ32162 is offline   Reply With Quote
Old 04-17-2019, 09:39 PM   #17665
_keepkushin_
Im not sure maybe close to 80k
The Following User Says Thank You to _keepkushin_ For This Useful Post:
AJ32162 (04-17-2019)
Old 04-17-2019, 09:47 PM   #17666
_keepkushin_
80156
The Following 2 Users Say Thank You to _keepkushin_ For This Useful Post:
AJ32162 (04-17-2019), Prodigalson (04-18-2019)
Old 04-21-2019, 08:25 PM   #17667
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
did my semi yearly interior clean. took everything out, threw out anything i didnt need, vacuumed everything, wiped everything down with armor all, sprayed off all the pollen, and rainxed all the windows and mirrors. also cleaned up the grease in some major parts under the hood, and replaced the cabin filter.
Old 04-21-2019, 09:00 PM   #17668
HaXx
Drives: jrsc_brz
Put on brand new ts 10 wheels today, wish I new how to upload pics, it looks tit
HaXx is offline   Reply With Quote
