Old 06-28-2015, 05:02 PM   #1751
SIM10
SIM10's Avatar
Drives: 2014 WRB BRZ Limited
Originally Posted by JB86'd View Post
I think you should wait a bit, you may see that code pop up on the stock tune eventually, sometimes they'll take lots of miles to pop up or after pushing the car hard.
Yeah, I've got a road trip soon for work. It will give me a chance to log some miles under high speed conditions. I just hope she doesn't go into limp mode hundreds of miles from home.
Current Mods: Perrin Performance 2.5" Stainless Cat back Exhaust, STI Red Start button, STI Gurney Flap, F1 Fourth Brake light Kit, APR CF Splitter, Side Skirts, Rear Diffuser, Hotchkis Strut tower Brace, TWM Performance Short Throw Shifter & M1 Abrahams Stainless knob, PowerHouse Racing intake, Shrader Performance Rear Seat Delete, Helix Smoked side markers, Diode Dynamics LED Fogs, Interior, Tail as Turn & DRL Always On
SIM10 is offline   Reply With Quote
Old 06-28-2015, 05:45 PM   #1752
D_Thissen
D_Thissen's Avatar
How long does it take the ECU to learn a new tune? Also when I plug in (or unplug) my OFT when the car is running I occasionally get an ABS and TC light. Suggestions??
Old 06-28-2015, 06:11 PM   #1753
JB86'd
JB86'd's Avatar
Drives: JAWS
To fully learn fuel trims..at least 50 miles from my experience. Easy driving helps it learn quickest.
Plug in your OFT before turning the key at all..problem solved.
Old 06-30-2015, 08:18 PM   #1754
Nardi330
Nardi330's Avatar
Drives: 86
anyone had their IAM (Adv Multipler) flashing on their OFT? i haven't plugged my OFT in for a while and decided to plug it in to have a look. my IAM is now flashing at 1 constantly. Anyone know how I should fix this? should I run software updates?
thanks
Nardi330 is offline   Reply With Quote
Old 06-30-2015, 08:48 PM   #1755
steve99
thanks
Their was some updates to functionallity
make sure you load latesest OFM 1.20 i think and latest template file. and let oft update.
Their are also tuning alerts make sure their are none set.
Old 06-30-2015, 10:13 PM   #1756
Nardi330
Nardi330's Avatar
Drives: 86
Thanks Steve.
i have updated OFM (its now v1.21), template and let OFT update.
lets see if this fixes it.
the logging was fine otherwise. only IAM was flashing.
Old 07-03-2015, 07:37 PM   #1757
MAX
Drives: WRB Subaru BRZ Limited MT
So I got my OFT today and flashed a stage 1 tune... Car feels WAY better. I'm super happy, and kicking myself for not odering one sooner...
BUT... I previously has a buddy that worked at Toyota disable my seat belt chime via techstream... however the OFT reflash seems to have re-enabled the beeping that drives me nuts... can I diable the chime with romraider??? or is it seperate? and if it's seperate... why did the flash affect it???
MAX is offline   Reply With Quote
Old 07-03-2015, 08:27 PM   #1758
steve99
OFT flashes Engine Control module ECU only and stuff like seat belts chime is likely in BCM body control module.
When ECU is reflashed other control units may be reset, its unusual that that chime has been reset, however you will need to use techstream to disable it again.
or get one of these and do it yourself
http://www.ebay.com/bhp/techstream
Old 07-03-2015, 10:42 PM   #1759
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
or just unplug the seat belt chime wire from the seat. I sit in my car with the key on and door open all the time, and the beeping was driving me crazy. No jumpers or resistors necessary, just unplug it and it thinks the belt is always in use.
The Following User Says Thank You to Target70 For This Useful Post:
MAX (07-04-2015)
Old 07-04-2015, 12:43 AM   #1760
MAX
This... sound like an excelent soultion... since I don't want to use a techstream cable EVERY TIME i flash it... do you by chance have a pic of said cable? or a discription of where to find the connector?
Old 07-04-2015, 01:02 AM   #1761
Target70
Target70's Avatar
let me go get a picture, it is in the front of the seat behind a cloth/fabric cover.
the fabric cover only has a small plastic clip that goes around a metal bar under the seat (circled in red), just adjust the seat as high as it goes, and reach under the seat behind the flap and pull down on the open side of the clip to spread it far enough to pull it off the metal bar (doesn't need much pressure). Then unclip the small white connector, and tuck it up out of the way (yellow circles).
Disclaimer: if you need the chime to remind you to your belt, you might not want to do this. I take no responsibility for you getting thrown out of your car because you forgot to buckle up.
The Following 3 Users Say Thank You to Target70 For This Useful Post:
Andrew025 (07-04-2015), D_Thissen (07-04-2015), MAX (07-04-2015)
Old 07-04-2015, 01:28 AM   #1762
MAX
That's awesome. thanks... An no I won't forget my seatbelt, I wear it all the time by habit... but I always start my car as soon as i get in... then put my seatbelt on after im settled and ready to go... but those initial beeps when i haven't moved an inch or plan to yet bother the hell out of me...
Old 07-04-2015, 01:33 AM   #1763
D_Thissen
D_Thissen's Avatar
This won't affect the airbags will it?
Old 07-04-2015, 01:36 AM   #1764
Target70
Target70's Avatar
no prob, and the disclaimer isn't aimed at you or anyone in particular, it's just a CYA world now-a-days. I do exactly the same thing, I like to start the car up and let it run for a few seconds before I drive off, and I find it a good time to buckle up and get situated. Plus if I am not buckled in I don't really feel "secure" I blame it on my old 240sx with a worn out seat and no real bolsters to hold me in place, so my seat belt was the only thing keeping me from sliding across the seat on hard corners, now it's routine. I was planning on using a jumper or something once I read that you had to pay the dealership to use the techstream to mod it, but once I unhooked it I found I didn't need to do anything else. Too bad I still have to double tap the button to unlock both doors.
shouldn't. As you are driving the car the drivers airbag should always be active. I think the seat sensor is the yellow plug in the picture.
The Following 2 Users Say Thank You to Target70 For This Useful Post:
#lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest
Tablet on the dash ! TRD_86 Electronics | Audio | NAV | Infotainment 23 05-16-2015 04:48 AM
Tablet Install ThugNasty Electronics | Audio | NAV | Infotainment 4 04-13-2013 04:15 PM
Blutooth OBD II and a 9.7 tablet.. Scooby South Electronics | Audio | NAV | Infotainment 10 12-16-2012 09:11 PM
7.0 Tablet w/ Torque App Thatruth2001 Northwest 26 11-21-2012 12:53 PM
