#1751 |
^That ain't meaty.
The Following User Says Thank You to swarb For This Useful Post: | Clipdat (04-17-2016) |
#1752 |
Drives: Raven Black
Why do you think that?
I think they are meaty. Last edited by CBR600RR; 04-16-2016 at 12:24 AM. |
#1753 |
Hot Lava Lover
Drives: 2013 Scion FR-S- lava
I got those same wheels but in stainless. How lowered are you and you experience any rubbing? Just asking to see what tires I may get when mine wear out. The black looks good.
#1754 |
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Because 225. That's only 10mm wider than a stock GT86 here and stock width for a TRD86.
255 is the start of "meaty" really.
My fully loaded TRD86
http://www.ft86club.com/forums/showt...760#post582760 |
#1755 |
Grip>Drift
Drives: FRS
They are narrow. Hardly wider than stock. How is hardly wider than narrow ass stock meaty?
#1756 |
Drives: whiteout
![]() 17x9.5 40 all around w/ 255/40/17 rs3. 5mm spacer in the front(35 offset now.) no rub =D |
The Following User Says Thank You to toby714 For This Useful Post: | slow15frs (04-16-2016) |
#1757 |
the tuna, no crust.
Drives: 2014 Hachiroku of the year
he is probably just referring to the look of sidewall/rim-not actual width. but yeah 225 isn't exactly meaty.
On a another note, the b14 Bilstein coilover up front is extremely wide i learned today- due to the giant progressive springs. A 18x9.5 +40 with a 255 continental DW with -2.1 camber up front with stock tophats adjusted camber with bolts will rub on the spring it self, had to add a 5mm spacer and pull out some camber-now purchasing top hats for that application (going with the velox ones)-figured this could be useful info as that is one of the best coilovers for the money if you want to go with that and a meaty setup i'd suggest top hats to avoid headaches in fitment. |
The Following User Says Thank You to Jive Turkey For This Useful Post: | Clipdat (04-17-2016) |
#1758 | |
Drives: Raven Black
Ya I'm simply referring to the sidewall look. Not a stretched tire, a sidewall that is "plump" or "meaty" Sure they aren't much wider, but the contact patch is about a inch wider than the stock Primacy HPs. |
#1759 |
Drives: Raven Black
Plus, I'm just on an e85 tune. So keeping a size close to stock is important for putting power down properly. Any sizes bigger is overkill unless you are boosted.
#1760 | |
Yep, may be what you meant but in this case "meaty" means wide. Have a read of the original post - 255+ http://www.ft86club.com/forums/showp...00&postcount=1
The Following User Says Thank You to nzer For This Useful Post: | Clipdat (04-17-2016) |
#1761 | |
Grip>Drift
Drives: FRS
It's not about rear grip. It's about front grip. I'm on stock power but I still run 17x9 and 255s for cornering. Your setup still looks good! It's just not meaty.
The Following User Says Thank You to BlaineWasHere For This Useful Post: | Clipdat (04-17-2016) |
#1762 | |
Drives: Raven Black
#1763 |
poor man's evora
Drives: Turbod BRZ
18x9, 255/35/18
The Following User Says Thank You to malubawla For This Useful Post: | MisterSheep (04-21-2016) |
#1764 |
Drives: the white one
18x9 +30 255/35 RE71Rs pre alignment. rubbatub tub in the rear. Will get that fixed soon, hopefully
![]() Sent from my SM-G920V using Tapatalk
If you can't win a race, beat the person in front of you
Winter Tire Review Thread (Please contribute) | pastuch | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 344 | 03-13-2024 05:49 PM |
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 | ScionFR-S | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 97 | 09-09-2015 06:32 PM |
Meaty rubber on flush spoke rims? | red_comet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 06-14-2013 12:21 PM |
Official wheel/tire fitment thread needed | empower-auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-22-2012 01:40 AM |
The Wheel and Tire Fitting Thread | EvoFanatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 03-15-2012 03:05 PM |
