Old 07-03-2014, 01:33 PM   #1737
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
My original KW OTS tune suffered from what felt like significant parasitic loss from the supercharger, but honesty the subsequent tunes I received from KW (I believe there were 2 that I received after the original tune that required a different MAP sensor) were really smooth and were N/A-like even below 2500RPM.
mit_peid is offline   Reply With Quote
Old 07-03-2014, 03:08 PM   #1738
D-VO
Drives: Whiteout FR-S, Evo 8 RS
Originally Posted by glamcem View Post
we use 92 octane here and TP is 82%
What are you using as a logger? OP2 and BRZ edit show 86% and OFT shows 100% I think.
D-VO is offline   Reply With Quote
Old 07-03-2014, 03:24 PM   #1739
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
I have been using Ecutek cable, I can also try Torque app
glamcem is offline   Reply With Quote
Old 07-03-2014, 05:37 PM   #1740
zERoTu
Drives: 1st RBv2 10 Series FRS
so you don't have any tune on your car now or just the OTS map?
Whatever kraftwerks gave me
zERoTu is offline   Reply With Quote
Old 07-03-2014, 07:50 PM   #1741
KraftWerks
KraftWerks's Avatar
Drives: Kraftwerks BRZ
@zERoTu, clearly there is something wrong. Are you sure you don't have a boost leak somewhere? Does the car feel like it's even boosting? Check your email inbox.
KraftWerks is offline   Reply With Quote
Old 07-03-2014, 08:03 PM   #1742
zERoTu
I check all the lines. Nothing is loose. 1st gear and 2 gear pulls great. 3rd and 4th gear pull are taking forever for the rpms to climb.
Old 07-03-2014, 09:37 PM   #1743
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Up to what rpm's @ 1st and 2nd?
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Old 07-06-2014, 11:25 PM   #1744
Squishy
Drives: 2013 WRB BRZ
After three days of working on the car, I have the kit installed. I took my time but had multiple things to work around and install.
I installed my ROBISPEC radiator, hmm it had quite a few compromises in terms of fit, DAMN tight all around but it fits. I had to make a gasket for the oil sandwich as the bottom of it had a groove for what looked to be a gasket but none was there. I used a high temp gasket maker and had to buy 3' more oil line since the way I had to run lines to avoid the supercharger needed more.
Then I installed a Raceseng cam plate, changed my oil and radiator fluid.
Then I installed the supercharger which went pretty fast if I hadn't wasted so much time on the above radiator.
Now I have to deal with my last problem. Ecutek updated but seems to either have corrupted or lost my license file. I sent a note off to Delicious Tuning as I can do nothing until that gets sorted to even start the car to look for leaks and check the rotrex oil.
Second place is just the first place loser.
Dale Earnhardt
Squishy is offline   Reply With Quote
Old 07-07-2014, 12:52 AM   #1745
D-VO
Cool! Did you take any pics?
Old 07-07-2014, 01:31 AM   #1746
Squishy
Yes, Yes I did.
This is the final install minus bumper until I get to run it and check for boost leaks.
Dale Earnhardt
Old 07-07-2014, 01:42 AM   #1747
captain_jack
captain_jack's Avatar
Yes, Yes I did.
Where is the rotrex oil resovoir at?
Old 07-07-2014, 08:35 AM   #1748
Squishy
The location is back near the battery.
Dale Earnhardt
Old 07-07-2014, 08:47 AM   #1749
Squishy
Nevermind figured out the issue with the license - had to apply the license file. Man I do not really like this ecutek thing. Oh well just gotta get this done.
Dale Earnhardt
Old 07-07-2014, 09:22 AM   #1750
captain_jack
It gets easier, trust me I didn't get it when I first used it either.
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 10:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
