#1695 |
Wears Pants
Drives: 14 FRS K24 swap - SOLD
Selling my K swap if anyone is looking for a turn key ready to rip machine. Located in NW Arkansas.
Facebook Ad |
#1696 |
Drives: Q5 + BRZ + M796
Bummer
#1697 |
Does anyone have a picture of the backside of the steel flywheel? I’m trying to see if there are welds like on my new one or if they changed the design. I can’t remember on my old one that is still installed.
#1698 |
Never mind. Found a picture online.
#1699 |
Drives: Fr-s
Anyone have height measurements of the fuel rail spacers? My motor didn't come with an intake and fuel rail and when I image search I get varying results.
Maybe let me ask a slightly different question, where do the injectors sit in the intake, do they just bottom out or are they raised within the seat? TIA
#1700 |
Drives: None
20mm od, 8.45mm id, 5.85mm tall
#1701 |
Drives: Fr-s
Alright boys, getting closer.
Did y'all locktite the flywheel, adapter and pressure plate bolts? Any chance you've found a cheaper source for the acc. belt?
#1702 | |
I can't remember where I bought my belt.
#1703 |
Drives: None
Belt depends on ac or not, crank pulley, and alternator pulley (if using an underdrive), what do you have?
I used red on flywheel bolts and blue on pressure plate / adapter
#1705 |
Drives: 16' WWB
Trigger Not Supported: Extra Tooth
Recently developed a rough idle - misfire with hunting idle... however car drives fine and seemingly has full power. When looking through the logs I noticed this error in the Diagnostics page and was wondering if anyone else has this error?
Trigger Not Supported: Extra Tooth Looking back at past logs it's been present since completing the swap last year... so not too sure what to make of it or if it has anything to do with my rough idle but figured I'd ask for insight.
#1706 |
Drives: None
Yeah, that is normal. Do you have a log with it happening?
Sorry, I meant to reply to you before. This (505K7) is what I am using with the same setup https://www.amazon.com/PowerDrive-50.../dp/B01AGPC16E
#1707 | |
Drives: 16' WWB
Here's a recent log file from an idle session today. Idle is rough, feels/sounds like slight misfire, tends to hunt around. https://drive.google.com/file/d/1J81...ew?usp=sharing |
#1708 |
Drives: None
Have you double checked to make sure you don't have a broken TB bolt yet
| Rigid Industries SR-Series Pro Light Bar on my BRZ | Stang70Fastback | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 12-29-2019 03:13 PM |
| Airlift from industries finest | J_Nasty | Member's Car Journals | 0 | 02-04-2017 01:59 PM |
| Carbox Industries - Introduction | CarBox | CANADIAN Sales | 5 | 04-22-2014 01:22 PM |
| 86 industries | Duthebarber | Northern California | 70 | 03-28-2014 04:10 PM |
| Another 86 Industries another bad experience | sikest | User/Vendor/Sponsor Reviews, Feedback, Comments | 3 | 03-13-2014 01:00 AM |
