Old 07-17-2023, 10:00 AM   #1695
captain awesome
Wears Pants
Drives: 14 FRS K24 swap - SOLD
Selling my K swap if anyone is looking for a turn key ready to rip machine. Located in NW Arkansas.
Facebook Ad
captain awesome is offline   Reply With Quote
Old 07-17-2023, 12:36 PM   #1696
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Bummer
Old 08-11-2023, 09:21 PM   #1697
Irace86.2.0
Does anyone have a picture of the backside of the steel flywheel? I’m trying to see if there are welds like on my new one or if they changed the design. I can’t remember on my old one that is still installed.
Old 08-12-2023, 01:52 PM   #1698
Irace86.2.0
Never mind. Found a picture online.
Old 08-14-2023, 04:59 PM   #1699
redlined600
redlined600's Avatar
Drives: Fr-s
Anyone have height measurements of the fuel rail spacers? My motor didn't come with an intake and fuel rail and when I image search I get varying results.
Maybe let me ask a slightly different question, where do the injectors sit in the intake, do they just bottom out or are they raised within the seat?
TIA
redlined600 is offline   Reply With Quote
Old 08-14-2023, 06:08 PM   #1700
RedReplicant
Drives: None
20mm od, 8.45mm id, 5.85mm tall
RedReplicant is offline   Reply With Quote
Old 08-26-2023, 12:13 PM   #1701
redlined600
Drives: Fr-s
Alright boys, getting closer.
Did y'all locktite the flywheel, adapter and pressure plate bolts?
Any chance you've found a cheaper source for the acc. belt?
Old 08-26-2023, 01:24 PM   #1702
Irace86.2.0
I did red locktite. I would do blue at the least.
I can't remember where I bought my belt.
Old 08-26-2023, 03:42 PM   #1703
RedReplicant
Drives: None
Belt depends on ac or not, crank pulley, and alternator pulley (if using an underdrive), what do you have?
I used red on flywheel bolts and blue on pressure plate / adapter
Old 08-26-2023, 04:32 PM   #1704
redlined600
Drives: Fr-s
No a/c, 5.67" dia. Super damper. Stock alt. Pulley.
Old 09-20-2023, 04:29 PM   #1705
funkjaw
Drives: 16' WWB
Trigger Not Supported: Extra Tooth
Recently developed a rough idle - misfire with hunting idle... however car drives fine and seemingly has full power. When looking through the logs I noticed this error in the Diagnostics page and was wondering if anyone else has this error?
Looking back at past logs it's been present since completing the swap last year... so not too sure what to make of it or if it has anything to do with my rough idle but figured I'd ask for insight.
funkjaw is offline   Reply With Quote
Old 09-20-2023, 04:50 PM   #1706
RedReplicant
Drives: None
Yeah, that is normal. Do you have a log with it happening?
Sorry, I meant to reply to you before. This (505K7) is what I am using with the same setup
https://www.amazon.com/PowerDrive-50.../dp/B01AGPC16E
Old 09-20-2023, 06:27 PM   #1707
funkjaw
Drives: 16' WWB
Thanks for confirming!
Here's a recent log file from an idle session today.
Idle is rough, feels/sounds like slight misfire, tends to hunt around.
https://drive.google.com/file/d/1J81...ew?usp=sharing
Old 09-20-2023, 07:07 PM   #1708
RedReplicant
Drives: None
Have you double checked to make sure you don't have a broken TB bolt yet
Rigid Industries SR-Series Pro Light Bar on my BRZ Stang70Fastback Cosmetic Modification (Interior/Exterior/Lighting) 3 12-29-2019 03:13 PM
Airlift from industries finest J_Nasty Member's Car Journals 0 02-04-2017 01:59 PM
Carbox Industries - Introduction CarBox CANADIAN Sales 5 04-22-2014 01:22 PM
86 industries Duthebarber Northern California 70 03-28-2014 04:10 PM
Another 86 Industries another bad experience sikest User/Vendor/Sponsor Reviews, Feedback, Comments 3 03-13-2014 01:00 AM
