Old 06-02-2023, 07:30 PM   #1681
Jdmjunkie
Drives: Scion FR-S 10 Series
They did. They want to know the thickness of the adapter plate.
I have an adapter plate that hasn't been installed yet. In case you need anything measured.
Jdmjunkie is offline   Reply With Quote
The Following User Says Thank You to Jdmjunkie For This Useful Post:
Irace86.2.0 (06-02-2023)
Old 06-02-2023, 08:55 PM   #1682
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
What I need are the measurements from the diagram for the engine and flywheel. I got everything from the transmission side, but anyone is free to check my measurements too; I'm sure they are not perfect.
The adapter plate is 24mm.
I entered the numbers below, but I need numbers from the flywheel. If someone has the flywheel not installed or on the engine, I need the distance from the block to the crank mounting surface, which is probably the shortest distance for clearance reasons, and then from the crank mounting surface to the surface of the flywheel where the clutch disc would make contact (not where the pressure plate makes contact).
Old 06-05-2023, 05:15 PM   #1683
Irace86.2.0
Originally Posted by Jdmjunkie View Post
I hope OS Giken responds positively. They make some of the best clutches I have every used. And they only make noise when you push in the clutch because of the floating pressure plate. Also it would me I could buy their sequential transmission if I ever win the lottery.
They emailed me back, but they need the thickness of the K20/24, FA20/24 and/or Kpower flywheel thickness, which is not something I have or can get anytime soon having to pull my transmission.
Old 06-05-2023, 10:46 PM   #1684
Jdmjunkie
I don't understand why they would not already have the information on both stock flywheels. They already make clutch kits for both.
Irace86.2.0 (06-06-2023)
Old 06-06-2023, 02:48 AM   #1685
Irace86.2.0
Seems like knowing the flywheel differences and the adapter plate thickness should be enough, right?
Old 06-06-2023, 12:41 PM   #1686
redlined600
redlined600's Avatar
Drives: Fr-s
I have the Kpower steel flywheel in the box and could measure, what exact measurement do you need?
The Following 2 Users Say Thank You to redlined600 For This Useful Post:
Irace86.2.0 (06-06-2023), Jdmjunkie (06-06-2023)
Old 06-07-2023, 12:02 AM   #1687
Irace86.2.0
They wanted a comparison in thickness, so I’m guessing something similar to what I did with the other measurements in the picture I posted. Specifically the distance from the mounting surface to the friction surface, but I suppose it would be good to know the distance from the mounting surface to both, the friction surface of the clutch disc and to the mounting surface of the pressure plate.
Old 06-07-2023, 11:03 PM   #1688
Jdmjunkie
Has anybody seen or used this for the swap? Would this solve any of the issues that a few people have had with the kpower water neck?
https://tractuff.com/products/tractu...ck-kit-stdhose
Old 06-08-2023, 12:47 PM   #1689
RedReplicant
Drives: None
From what I've seen KPower has revised the kit and the included neck now has an outlet on the driver side of the motor
RedReplicant is offline   Reply With Quote
Old 06-15-2023, 12:07 PM   #1690
redlined600
Drives: Fr-s
On the steel Kpower flywheel, I get 22.4-22.5mm from the mounting surface to the friction surface and 1.9mm from the friction surface to the pressure plate mounting surface.
The Following User Says Thank You to redlined600 For This Useful Post:
Irace86.2.0 (06-16-2023)
Old 06-28-2023, 11:23 PM   #1691
RedReplicant
Drives: None
Came across these CANChecked things today...
This thing is pretty sweet for anyone that is input (or output) starved
https://www.vadpro.com/products/canc...-bus-expansion
They also make a CAN hub with twice the ports for about what Haltech wants for theirs. FT86Club appears to block the word see-bee-dee, so replace the *** with those letters in the URL.
https://www.vadpro.com/products/canc...n-8-port-***08
The Following 3 Users Say Thank You to RedReplicant For This Useful Post:
captain awesome (07-12-2023), Irace86.2.0 (06-29-2023), ML (07-11-2023)
Old 07-01-2023, 08:36 PM   #1692
jes
jes's Avatar
Drives: FRS
Following
jes is offline   Reply With Quote
Old 07-11-2023, 11:42 AM   #1693
ML
ML's Avatar
Drives: 13 White MT FR-S
that is badass
Old 07-14-2023, 11:34 AM   #1694
redlined600
Drives: Fr-s
I wanted to get a second opinion as some of you guys went through this.
I took a spare driveshaft in to be shortened and it turns out the all the u-joints are notchy and they want to replace them all in addition to shortening, this all adds up $$$.
As a second option they said they could make it into a 1pc. I mentioned that it will see higher speeds and some of the issues others had with 1pc driveshafts but they didn't seem very concerned. This is a very reputable shop so I'm assuming they know what they are doing. I'm wondering if a steel 1pc would still exhibit that same issues some of you have seen with the AL 1pc?
* I spoke with them a second time reiterating my concerns and giving them speed estimations and they were adamant it wouldn't be an issue.
Rigid Industries SR-Series Pro Light Bar on my BRZ Stang70Fastback Cosmetic Modification (Interior/Exterior/Lighting) 3 12-29-2019 04:13 PM
Airlift from industries finest J_Nasty Member's Car Journals 0 02-04-2017 02:59 PM
Carbox Industries - Introduction CarBox CANADIAN Sales 5 04-22-2014 02:22 PM
86 industries Duthebarber Northern California 70 03-28-2014 05:10 PM
Another 86 Industries another bad experience sikest User/Vendor/Sponsor Reviews, Feedback, Comments 3 03-13-2014 02:00 AM
