#1667 | |
Drives: 16' WWB
and thanks man it's pretty exciting!!!... well I mean my wife isn't excited about all the money I spent on this, which is partially the fault of this thread - but I know once she drives it she'll be less pissed off at me.. hopefully. |
#1668 |
Drives: 13 White MT FR-S
anyone need some 1000cc DW injectors hit me up.
#1669 | |
At the track
Drives: '14 FRS - Former e92 M3
#ladydriven Nasa TT4 FRS // JRZ RS Pro // Karcepts Sway Bars // K24 Swap (in Progress) // AP Endurance BBK // Cobalt Friction brake pads // Safeplace Auto
#1670 | ||
Drives: Fr-s
#1671 |
Drives: 16' WWB
What front sway bars ya'll runnin without any clearance issues? I have a Hotchkis 25.4mm hollow sway bar and it definitely touches and causes vibrations against the transmission adapter.
#1672 |
Drives: None
I've got the Perrin 22mm in mine, fair bit of room there
#1673 |
Drives: Q5 + BRZ + M796
I have Eibach, and it seems to clear fine.
#1674 |
Drives: 16' WWB
As promised here is an acceleration video of my car with the new 4piston head and toda A3 cam setup. It picked up .3 seconds in the 20mph-60mph vs the stock head on E85 in a previous video I posted. This probably translates to 4 or 5 tenths faster in the quarter mile I suppose? Definitely nothing to shake a stick at that's for sure.
#1675 |
Drives: 2013 frs
Well that sucks, finally got my kit and am working on getting all together and that's the same sway bar I've got
#1676 |
Drives: 16' WWB
#1677 |
At the track
Ohh I didn't even think about swaybars being an issue... I bought another Karcepts one recently... hope it works. Guess I'll keep my Perrin 19mm one a little longer as a backup.
#1678 |
Hey fellas,
I've reached out to OS Giken, Competition Clutch, Clutch Masters, Exedy, Tilton, XClutch with inquiries about whether their twin clutches would work. Clutch Masters, for instance, makes a K24 to Subaru transmission adapter and flywheel that work with their twin discs, but this is for the EJs (see below). Several have gotten back to me with a "No" and some have asked for measurements and some said they could if I sent in my flywheel or provided accurate measurements. https://clutchmasters.com/i-30508045...-flywheel.html Does anyone know these dimensions who has their parts readily available? I have a spare transmission in my garage, so I could probably get the thickness of the adapter plate, the distances to the TOB and input shaft from the transmission, but I don't have the engine out to be able to measure the flywheel and engine side. If someone is feeling so kind then I would appreciate any measurements they could contribute. My goal is to get a twin disc that is organic, sprung and with a steel flywheel for the most steetable clutch setup possible, but I don't know if I will be able to get everything I want. I've read and watched videos that the Clutch Masters is nice because the spring tensioners on the plates make them not rattle, so it doesn't sound like a Ducati dry clutch.
#1679 |
Drives: Scion FR-S 10 Series
I hope OS Giken responds positively. They make some of the best clutches I have every used. And they only make noise when you push in the clutch because of the floating pressure plate. Also it would me I could buy their sequential transmission if I ever win the lottery.
#1680 | |
| Rigid Industries SR-Series Pro Light Bar on my BRZ | Stang70Fastback | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 12-29-2019 03:13 PM |
| Airlift from industries finest | J_Nasty | Member's Car Journals | 0 | 02-04-2017 01:59 PM |
| Carbox Industries - Introduction | CarBox | CANADIAN Sales | 5 | 04-22-2014 01:22 PM |
| 86 industries | Duthebarber | Northern California | 70 | 03-28-2014 04:10 PM |
| Another 86 Industries another bad experience | sikest | User/Vendor/Sponsor Reviews, Feedback, Comments | 3 | 03-13-2014 01:00 AM |
