Old 03-30-2016, 02:30 PM   #155
James@HKSUSA
James@HKSUSA's Avatar
Originally Posted by sebastiansim View Post
Please let us know asap! I'm sure they're are a lot of 2015+ owners that are dying to get their hands on this kit that just want a install, flash and go system (myself included haha)
We most certainly will!
James@HKSUSA is offline   Reply With Quote
The Following User Says Thank You to James@HKSUSA For This Useful Post:
GTHachiRoku (04-21-2016)
Old 03-31-2016, 11:24 PM   #156
sebastiansim
Drives: 2015 Crystal Black Silica Brz MT
Sounds like a stupid question but would it be possible to install the kit at home and drive the car half an hour to my local ecutek tuner? Obviously without really putting my foot down. Would i run the risk of blowing my engine just driving those 30 minutes? Really trying to figure out this tuning thing before actually buying the kit.
sebastiansim is offline   Reply With Quote
Old 04-01-2016, 10:20 AM   #157
Andew727
Drives: Scion FR-S
probably wont start... id call a tow truck, it cant be much for a 30 minute tow. AAA or even toyo guard may tow it that far for you if your car came with it, or you are a AAA member.
Andew727 is offline   Reply With Quote
The Following 2 Users Say Thank You to Andew727 For This Useful Post:
CxG (04-04-2016), sebastiansim (04-01-2016)
Old 04-01-2016, 12:47 PM   #158
pitstops
Drives: SC RB FRS
yeah dont risk it, with the boost coming in at low rpm, your car will be knocking with too much timing from the stock tune. with the supercharger on you can however drive it in the parking lot without a tune.
pitstops is offline   Reply With Quote
Old 04-01-2016, 02:55 PM   #159
sebastiansim
Yea you're right. I have a stage 2 uel tune from my open flash tablet at the moment i should just wait. I might actually drive to the shop the day after I get the kit to grab a ecutek tune for it and tune it myself at home after the installation. Then get it dyno-ed another day just to make sure everything is running properly.
Old 04-04-2016, 04:14 AM   #160
asraam
Drives: Subaru BRZ
I used mine for a week after installation before the tune and had no problem (for city driving only but done like 70 miles like that). Just be prepared that some warning light will be on and definetely don not rev it and do not use full throttle...
asraam is offline   Reply With Quote
Old 04-04-2016, 03:47 PM   #161
CxG
Drives: Pearl White '13 ZN6
Don't do it, better not risk anything. Ask your tuner if they'll be able to get you a canned tune at least. Something that'll be get you to the shop where they can finish up
Sent from my D5803 using Tapatalk
CxG is offline   Reply With Quote
Old 04-18-2016, 05:35 PM   #162
xalsx
Drives: 2014 BRZ
What would the community recommend if there is no local tuner available?
xalsx is offline   Reply With Quote
Old 04-18-2016, 05:38 PM   #163
JadeBRZ
#ProjectBRZ
JadeBRZ's Avatar
Drives: SWP BRZ
get the flash editor with the kit. install it, run 91 tune, then mail them the FE for the 93 tune.
Fuck HKS
JadeBRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to JadeBRZ For This Useful Post:
CxG (04-18-2016), xalsx (04-19-2016)
Old 04-19-2016, 01:24 AM   #164
zeal86
zeal86's Avatar
Drives:
For those of you that have an aftermarket front beam brace (ex. Beatrush) and or performance radiator (Mishimoto) installed with your v3 supercharger... What kind of clearances were you able to achieve?
I managed to keep everything from contacting the AC condenser and beam brace... but it is REALLY close. My intercooler sits at a slight angle in towards the center of the bumper... is that normal when installing on an otherwise stock 86? I'm thinking it is due to how the intercooler meshes with the Beatrush front beam brace. I had to fab up some brackets... Fitment of the Mishimoto oil cooler is next... I'm going to try and angle it like the HKS intercooler.
__________________________________________
projekt zeal86 build
zeal.eightsix Facebook
Instagram | zeal.eightsix
zeal86 is offline   Reply With Quote
Old 04-20-2016, 12:27 AM   #165
zeal86
zeal86's Avatar
Drives:
I fabricated the following in order to fit my HKS v3 supercharger intercooler to my Beatrush front beam brace...
The flat bracket is in addition to the LH bracket that comes with the kit. It keeps the intercooler pushed away from the A/C condenser end tank. The other bracket secures the RH side of the intercooler to my Beatrush front beam brace using a 80mm M6 hex bolt, washers, 60mm spacer, and nut.
The clearance is minimal all around... nothing was touching when I temp installed it last night. Once I put it back together this week, I'll post pics and measurements of all the close calls.
The M6 x 80mm bolt, washers, spacer, and flanged nut secures my intercooler bracket to my Beatrush beam brace.
I was able to complete this bracket for the traction fluid cooler yesterday. I just have to paint the brackets gloss black and clear coat them.
painted and cleared...
Temp installed...
Drilled an M6 hole...
Ready to be mounted...
Installed...
Up next is the fitting the Mishimoto oil cooler...
The Following User Says Thank You to zeal86 For This Useful Post:
CxG (04-20-2016)
Old 04-21-2016, 12:24 AM   #166
zeal86
zeal86's Avatar
Drives:
I will probably run into issues mating the intercooler outlet to the pipe going to the throttle body because of the angle the intercooler sits at. The way I have it was basically the only way I could get it to fit without touching the surrounding parts. If I raise up the left side... the intercooler contacts the A/C condenser end tank. I'll make adjustments as I move forward in my install... I might have a custom front beam brace welded if the Beatrush doesn't work out.
Polished all the intercooler brackets..
Slanted intercooler and Traction fluid cooler installed. You could see how I pushed down my A/C condenser by slanting the brackets to create space up top.
Polished brackets ready to go...
Placed a spacer between the A/C condenser boss and bracket. I did this to create space... the A/C condenser now sits flush against my Mishimoto performance aluminum radiator.
Very little clearance here...
The Following 3 Users Say Thank You to zeal86 For This Useful Post:
CxG (04-21-2016), GTHachiRoku (04-21-2016), new2subaru (04-21-2016)
Old 04-21-2016, 03:23 AM   #167
Fricke
Drives: Toyota GT86
How much in general whp, could you expect from the V3 kitt, whit E85 and matching injectors + fuel pump
Fricke is offline   Reply With Quote
Old 04-21-2016, 11:31 AM   #168
GTHachiRoku
Big in Japan
GTHachiRoku's Avatar
Drives: turBRZ
I would say mid to high 300's depending on other parts/factors.
E85 is great for the extra power and lowered temps. The only thing that has me worried is fuel starvation on track. Many local members have had this issue once going flex fuel.
GTHachiRoku is offline   Reply With Quote
supercharger help... sosick Forced Induction 25 08-16-2013 12:02 AM
HKS GT Supercharger Evasive Motorsports Forced Induction 48 02-08-2013 07:21 PM
ETA on TRD Supercharger? frsinpa Forced Induction 18 01-11-2013 11:09 AM
supercharger? but by who? carbonBLUE Forced Induction 14 11-02-2012 11:10 PM
HKS GT Supercharger Kit BPAuto Forced Induction 18 10-27-2012 04:11 PM
