Old 06-27-2012, 07:06 AM   #155
Hanzo
Hanzo's Avatar
Drives: Waiting for the ND Miata
Originally Posted by JP View Post
has anyone tried putting some water on the drive belt of a car that's making the noise to see if it changes/goes away? ...simple test that one.
A stethescope would easily pinpoint the source, from the video's here it sounds similar to tensioner idler noise I've heard on other subaru's and toyota's.
When I listen for the source of the sound it's definitely coming from the right side of the engine (when you still in front of the car) in the direct injection area.
Hanzo is offline   Reply With Quote
Old 06-27-2012, 07:08 AM   #156
Hanzo
Hanzo's Avatar
Originally Posted by Bonburner View Post
It's been confirmed by the lead engineers from both scion and subaru that this is abnormal.
Look for Whiteout-FRS's post - I don't remember where I saw it but its somewhere in the forums here
Edit: I found it, from 6/22
http://www.ft86club.com/forums/showt...t=8285&page=13
This is a different issue, this was about the dip in RPM during idle.
Old 06-27-2012, 10:10 AM   #157
Stu L Tissimus
Stu L Tissimus's Avatar
Drives: MT GB BRZ Limited
Yes. Please don't equate the idle issue to the chirping issue. I brought my car in for:
- Check engine light
- Idle issue
I did not bring it in for:
- The chirping issue, because I haven't heard it at all.
Edit: Stu L Tissimus admits that he never noticed the chirping, but I never noticed it either until I opened the hood with the engine on.
Admits? Am I being accused of something? :P
I mean, I've seen the Youtube videos of the chirping and theres is nothing remotely as noticeable in my car. I don't know, guys, but in my extremely uninformed opinion it is a separate issue.
Stu L Tissimus is offline   Reply With Quote
Old 06-27-2012, 11:17 AM   #158
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
- Idle issue
Haha, don't mind the wording too much.
I've seen my idle dipping but can't really hear the cricketing in the cabin really.
Open the trunk and I can hear it :/
Old 06-27-2012, 07:02 PM   #159
NRGBalanced
NRGBalanced's Avatar
Drives: '13 Subaru BRZ Limited WRB
I picked up a stethoscope some time ago when I was trying to diagnose a pulley bearing issue on another car, and I took it out to the BRZ. I hunted around that side of the car until I came upon this spot with the probe:
The chirp at this point finally came into the earpieces of the stethoscope and was matched with the low-frequency tapping I had heard while touching the probe to the other metal parts in that area.
It sounds like the chirp is the result of the insulation and metal components in the DI pump area acting like a high-pass filter, so that we only hear the highest pitch of the tapping.
I am not a skilled diagnostician, so take this with a grain of salt. Maybe someone with better ears will go poke around in this specific area.
NRGBalanced is offline   Reply With Quote
Old 06-27-2012, 07:45 PM   #160
taosracer
Frickin' Genius
taosracer's Avatar
Drives: GBS BRZ 6sp, 2002 ts wagon WRX swap
Originally Posted by Lil Abner View Post
Many of us will be waiting for this. However, please don't jump on here and say it's quiet after it gets installed. Try and get a few hundred miles on the new parts first.
No worries there. I am averaging 600 miles per week since the car was delivered 6/1 (2300 currently) I certainly won't be jumping to conclusions on this either. However, my car starting chirping on day one, with less than a hundred miles on it (noticed when showing it off to my neighbor, James Bond who thinks it looks like a Maserati...no, I don't make this stuff up )
I'll be scrutinizing the work and the results for certain.
Cullen
I hear on occasion, people say that they are bored...wrong answer....An engine can be bored, a person would more correctly state that they are boring.
taosracer is offline   Reply With Quote
Old 06-27-2012, 07:47 PM   #161
taosracer
Frickin' Genius
taosracer's Avatar
Did you listen to each of the pulleys, tensioner, water pump etc. ?
Cullen
Old 06-27-2012, 11:31 PM   #162
NRGBalanced
I checked what I could reach on the driver's side of the engine and didn't get any sounds out of it like the chirp or clack. Just the whir of bearings.
Old 06-28-2012, 07:33 PM   #163
taosracer
Frickin' Genius
taosracer's Avatar
Idler pulley installed today, drove home...
Complete FAIL
No change at all, still chirping away after it warmed. I'm feeling like an idiot because I had confidence in the tech's diagnoses.
Stupid cricket sound.....
Cullen
Old 06-28-2012, 07:37 PM   #164
Lil Abner
Drives: 2013 FR-S, 6MT, Ultramarine
Idler pulley alone? Or the tensioner too?
Lil Abner is offline   Reply With Quote
Old 06-28-2012, 07:48 PM   #165
taosracer
Frickin' Genius
taosracer's Avatar
The pulley between the AC and WP.
Cullen
Old 06-28-2012, 07:51 PM   #166
Lil Abner
Gotcha. I guess we can check that one off the list...
Old 06-28-2012, 08:04 PM   #167
taosracer
Frickin' Genius
taosracer's Avatar
Unfortunately yes ^^
I strongly suggest that we all contact our dealerships with the "concern" and request that a E-QMR is initiated (more on E-QMR in the link) This will get the ball rolling with Subaru (and maybe Scion) to get the annoyance remedied.
A brief read through: http://www.ft86club.com/forums/showt...458#post241458 should show that these types of issues need to be brought to the attention of the dealerships right away to get the ball rolling.
Show up with your complaint skills
Cullen
Old 06-28-2012, 08:12 PM   #168
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Someone had posted a while back on this saying the chirp/crickets are from the DI, and high pressure. I don't know anything about this, but I'm 99% sure that the chirp and the rev issues are completely seperate.
I'm also guessing since so many have the chirp that it's just an unwelcome side effect of an intended design, and not an issue that will lead to a critical failure of the car.
Hard shifting into first gear; normal? blalor Engine, Exhaust, Transmission 54 08-31-2017 09:57 PM
Idle issue? yayforaddison Issues | Warranty | Recalls / TSB 891 07-14-2016 10:42 AM
What function can it be used for, the idle button place yuli8466 Cosmetic Modification (Interior/Exterior/Lighting) 50 01-29-2013 03:17 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
Scion goes normal terrypm Other Vehicles & General Automotive Discussions 21 05-02-2012 10:16 AM
