#155 | |
Alexandrino_Auto
Drives: series.Blue
For future users, no amount of tapping, striking, hammering, or bumping will move the insert out of the housing. The strut insert screws in and out of the housing. You do not need a pass through socket for this. Since the insert is threaded into the housing, the nut will come right off, and the insert will not move. Then, you need to heat the insert and the housing until it is so hot you can't touch the housing without gloves. You have to literally (note: proper use of this word) melt the Loctite. I use a heat gun and let it sit on high about 4" from the strut for at least 5 minutes. I set them up and walk away. Once the strut is damn good and hot, you can insert an Allen wrench and the insert will screw right out of the housing. Also, the Allen hole in the insert is very fragile, and super easy to strip. Take the proper sized Allen key and wrap a blue shop rag or paper towel and tap it into the Allen key hole. That will help with the clearances and allow you to put a bit more torque on the insert without stripping it. However, these should be installed with very little torque. Again, it is held in with Loctite, so you NEED heat to melt the Loctite in order to screw out the strut insert from the housing. If you have to put force on it, it's not hot enough. The Loctite will melt and it will screw right out. Loctite aside, they are screwed in just beyond hand tight.
The Shadetree Project: I turn wrenches
| The Following 2 Users Say Thank You to Hyper4mance2k For This Useful Post: | Racecomp Engineering (03-14-2016), strat61caster (03-14-2016) |
#156 |
Drives: 1993 Impreza w/ WRX Swap + FWD!
FWIW I just found out the bumpstops for the B14's are about 1.5" but are EXTREMELY hard. I'm having the shocks worked on now to repair my damage, and got the info.
Also, I'm going to be running Ground Control camber plates and trying out a little trick I figured out to increase the front suspension travel so stay tuned, might have to start a separate thread about it
#157 | |
Drives: 2015 FR-S
This would seem to be the last piece of the puzzle to pulling off a DIY revalve on a set of Bilsteins for our car. It would not be easy to compress the gas chamber while assembling the strut. One would have to somehow hold the separator piston deep inside the strut tube (maintaining the probably ~200psi*~1.5in^2 = ~300 lbs [rough estimate assuming 200psi gas pressure and 36mm piston diameter, no idea if true] of force on the separator piston), then simultaneously insert the valve piston + rod, fill with oil, and somehow install the strut tube rod guide/seal and bleed the oil at the same time. That sounds nearly impossible. Perhaps there's a way to inject the oil into the oil chamber under pressure after everything has been assembled, thereby forcing the separator piston down and compressing the gas chamber? While looking for an answer I also found these alternate options (ctrl+f "strut" and you'll see the pic, read the blurb above it too): http://farnorthracing.com/autocross_secrets18.html I don't like the inset schraeder valve option that much, especially if one wants to cut their bumpstops. Gun drilling the stud to install a valve would require a large stud, and thus also custom top mounts or at least new top mount bearings. Last thing: I seem to remember Shaikh from FatCat mentioning a special tool used to assemble struts, but I can't find that video anymore. Maybe there is some sort of injection tool or something? |
#158 |
Got my Bilsteins back from repair courtesy FRSport. They were revalved and bumpstops shortedned. Plus you can see my new camber plates. I'm going to try something unique with the camber plates too. Won't be installing these for a week or two though.
The valving should work even for stiffer springs if I choose to go with those later. Photo of the shock dyno: ![]() Pics: ![]()
| The Following 5 Users Say Thank You to Kostamojen For This Useful Post: | bholliday (03-29-2016), Hyper4mance2k (04-16-2016), Rameus (03-29-2016), Shankenstein (03-29-2016), zdr93523 (03-29-2016) |
#159 |
Drives: TOYOTA
Sweeeeet. I think I missed it earlier - what rates did you select? And you left the rears alone?
#160 |
Drives: Raven Toyota GT86
Damn they look beastly!
Toyota Corolla E12 Hatchback (2005) - GONE
Toyobaru GT86 ハチロク - CURRENT |
#161 |
Drives: 2015 FR-S
#162 | |
I have no idea whats going on with that chart actually LOL |
#163 | |
Drives: TOYOTA
What's your wheel/tire setup? Stock sways? |
#164 | |
Strano front sway with Whiteline endlinks Stock rear sway with Kartboy endlinks A stiffer front spring at 6" with helper springs would probably work best for most people. |
#165 |
Drives: 13' Toyota GT86
#166 | |
Drives: GBS BRZ
If you didn't see it earlier here you go:
#167 |
Frosty Carrot
Drives: The Atomic Carrot
For those keeping an eye on Bilstein upgradeable coilovers, the current catalog has all of the piston shafts/rods listed.
Non-adjustable: $35 Single-Adjustable: $285 Double-Adjustable: $421 By offering a non-adjustable setup, RCE is saving the customer $1200 on a set (in parts with no markup). I'm sure they (or GTWorx) could make a tricked-out setup if you'd like. Personally, a square spring setup won't dance (oversteer) eagerly enough for my needs (400/400 is 2.5 Hz front, 2.1 Hz rear)... but it will be forgiving and confidence-inspiring for those who enjoy spirited driving and autocross (STX). Power oversteer will still be a thing, but you can stay on the jagged edge with confidence (just like the Tarmac 2 coilovers won over Randy Pobst).
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX Wall of Shame - aFe Takeda, Wilwood, FA20Club |
| The Following User Says Thank You to Shankenstein For This Useful Post: | Calum (04-18-2016) |
#168 |
| **NEW**Bilstein B8 HD Struts and Shocks Released | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 118 | 09-12-2016 02:54 PM |
| Bilstein B6/B8 and B14 shocks setting | Mars2 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-26-2014 11:24 PM |
| Swift Spec R with Bilstein B8 shocks? | JMoore412 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 05-23-2014 02:52 PM |
| Bilstein shocks & struts | Fizz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 10-31-2013 03:56 AM |
| Bilstein Shocks | wahsaihin | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 05-23-2013 04:12 PM |
