#155 | |
Drives: 2013 SWP BRZ
Honestly the drain only allows so much room for you to angle it, but It seems to be enough. 20 degrees is not that much. You can see the angle of mine kind of in this picture. Just take a look at how straight up your setup is and you will see the difference.
| The Following User Says Thank You to xxscaxx For This Useful Post: | yomny (06-22-2015) |
#156 | |
Drives: 2013 FRS Whiteout
That looks just right.. so hot coming out the rear outlet, one closest to block and the cool water coming in the front. wish I would have gone with the water cooled BB, just seems like they'll last longer lol. Thanks for the correction I did mean JDL's design on the manifold lol. '
What the hell am I saying.. man I think this oil leak has got my head all warped lol. I see the manifold design doesn't' have the slightest thing to do with you being able to clock the center hosing lol. Quote:
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
#157 | |
yeah knew what you meant, just wanted to clarify in case someone else came by and read it. Yep thats the way they are routed. The side close to the block I ran to the coolant port right under the TB (where the front coolant hose off the TB runs to), and the hotside I ran to the back coolant hard line pipe on the driver side rear of the motor (where the side coolant hose off the TB ran to).
#158 |
Drives: 2015 BRZ
Those of you that have this kit...did you have to grab anything extra? I want to make sure once my kit gets here I have everything before I tear my car apart.
#159 | |
Drives: Subaru BRZ Series.Blue
#160 | |
Lol.. just grab some hi temp thread sealant.. some Loctite for bolts you don't want backing out. You'll also need a new gasket for the manifold/head as JDL provides the one for the turbo and the downpipe to overpipe..Aside from that, all you need is in the kit. Also confirm with them you have plenty of vacuum hose for the bov, they threw some in there for me but I don't know if its something they do all the time. Let me know what you have or if you think you may need something else and i'll confirm. Let me look over, I think I mentioned in the OP what found myself needing. Also a little diagram I got from the guys at JDL telling me what I needed to apply sealant to. Check out post #11, first page. Just got of the phone with the Ronnie from JDL.. the guy heard I had an issue and immediately called me to offer some drain line gaskets. With service like this, I wouldn't think twice about ordering from these guys.
#161 | |
#162 | |
![]() For my case, after talking to Ronnie today they suggest applying some loctite in the flange bolts to avoid them backing out, could be what happened to me who knows. Also I was able to find one of them oil drain gaskets locally so I'll be installing it tonight. Couldn't hurt to try as I don't want the car even thinking about leaking, just till I receive the flange I ordered.
| The Following User Says Thank You to yomny For This Useful Post: | Rybot (06-22-2015) |
#163 |
Drives: 2015 BRZ
Oooh mine is shipping today!
#164 |
Congrats, you may have it by this weekend.
#165 | |
Hopefully @JDLAutoDesign can chime in on when the oil cooler kit will appear on their site! Also, @yomny, do you have the UEL manifold? If so, did you run into issues installing the shorter side? Last edited by Rybot; 06-22-2015 at 09:01 PM. |
#166 | |
Drives: 13 FRS
Very soon ![]()
#167 |
#168 | |
No I have EL, but knowing these guys.. it'll probably be a good fit. Just get it in evenly.. you cant really get one side in then the other because the studs will interfere.. I placed the gaskets on the studs/engine and raised the manifold straight up.. PS-installed the new gasket I picked up yesterday.. lets see.
| RS*R Sports-i coilovers - install & review | ultra | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 50 | 07-27-2022 06:29 PM |
| Powerhouse Amuse Single Exit Exhaust + R1000 FP Review | BrianJC | Engine, Exhaust, Transmission | 26 | 06-06-2016 10:09 PM |
| My OEM Audio Plus 400 Install and Review | Yruyur | Electronics | Audio | NAV | Infotainment | 156 | 03-01-2016 05:53 PM |
| TRD Sharkfin Install and review | Tye300 | Cosmetic Modification (Interior/Exterior/Lighting) | 27 | 07-19-2014 07:21 PM |
| REVIEW: Berk Technology Single Exit Track Pipe w/ Tip | NYC BRZ | Engine, Exhaust, Transmission | 11 | 12-29-2012 08:22 PM |
