Old 06-14-2014, 08:17 PM   #155
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
Originally Posted by extrashaky View Post
If you press and hold the "Audio" button, a hidden menu appears that, as far as I know, is not in the manual for the nav unit.
I want to buy you a beer some day. As someone who takes long drives, many times in the middle of nowhere in the middle of the night, even the 'night' mode is super bright. Knowing I can turn that off makes me sooooo happy.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Superhatch is offline   Reply With Quote
Old 06-15-2014, 01:22 AM   #156
CO777DAL
CO777DAL's Avatar
Drives: 2014 Ultramarine Monogram FRS
Today I accidentally discovered that there's an easy way to override night mode (and day mode as well) on the BRZ's head unit. This might work on other head units as well, but since I don't have one to test, I don't know.
If you press and hold the "Audio" button, a hidden menu appears that, as far as I know, is not in the manual for the nav unit. If you're in day mode, a "Night" button appears at the top of the screen in that menu. If you're in night mode, that button says "Day" instead. Pressing that button toggles the night/day modes and causes it to ignore the headlights without having to adjust your display to full brightness.
So if you're driving with your headlights on in the rain during the day and want your display at daylight brightness, just press and hold the Audio button and push the "Day" button on the screen. I wish those idiots had put that in the manual instead of having me curse them for months for not including an intuitive way to override the automatic brightness settings.
Originally Posted by Jyn View Post
This didn't seem to work for me.. what head unit do you have? I've got a 2014 Monogram with the Bespoke and when I press and hold the Audio button, it just reads it as a press.
I tried it too and it doesn't work on the Monogram. Then I pushed Setup button and lo and behold the option is right there under display.
Screen shots.
When you hit setup Display is at the top
Options to "turn off" screen go to day/night and adjust brightness and contrast are all in one spot.
CO777DAL is offline   Reply With Quote
Old 06-15-2014, 08:22 AM   #157
CruiseZen
CruiseZen's Avatar
Drives: 2014 Ultramarine 6MT FR-S Monogram
Originally Posted by B$ View Post
Really? Where is the spot near the handle?
It's the button you use as the trunk handle. Press here and if the key fob is on you the trunk will pop open. No need to use a key or push a button.
Borla axleback exhaust * mud guards * Michelin Pilot Super Sport tires * Opti-Coat * BRZ trunk lid liner * Rexpeed Wide Mirrors (heated)
CruiseZen is offline   Reply With Quote
Old 06-15-2014, 10:24 AM   #158
extrashaky
Drives: 2014 BRZ Limited
On the BRZ there's a rubber button right between the tag lights, directly under the emblem. Here's a picture of it on my dirty car:
Unless the FR-S trunk is different, I think the "handle" he's talking about is the recessed area for the tag lights. Just press the rubber doofus and the trunk will pop without you ever having to touch your key fob.
On the other hand, I prefer to use my key fob, because the less I have to touch my dirty road-grimed trunk lid, the better.
Old 06-15-2014, 11:06 AM   #159
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
just went out to check my FRS about this feature.. dont have it
but i did find a place you can put your key into that i never notice before on the trunk
Old 06-16-2014, 05:42 AM   #160
Harvey
Drives: Celica 5th Gen, Tiburon 04, GT86
GT86 has this..... Just walk up with the SmartKey in your pocket and lift up the trunck...
Harvey is offline   Reply With Quote
Old 06-16-2014, 12:28 PM   #161
CokeSlap
Drives: 2014 Monogram FRS Whiteout
As does the monogram.
Sent from my SM-T217S using Tapatalk
Previous Ride
1992 Acura Integra GSR in Aztec Green Pearl
CokeSlap is offline   Reply With Quote
Old 06-16-2014, 12:58 PM   #162
LXXXV1
LXXXV1's Avatar
Drives: 2014 FR-S Monogram, Whiteout 6MT
Screen shots.
iirc the "day mode" option only shows up with the lights ON in my Monogram.
2007 Honda CBR600RR-Pearl White/Silver - Totaled
2014 Scion FR-S Monogram-Whiteout - #LXXXV1 (build)
φφκα
LXXXV1 is offline   Reply With Quote
Old 06-16-2014, 01:51 PM   #163
B$
86
Drives: Monogram Whiteout
Originally Posted by CruiseZen View Post
It's to the right of the trunk handle. Run your finger about an inch or so to the right of the trunk handle and you will feel a small raised area. Press here and if the key fob is on you the trunk will pop open.
I will have to check this out at lunch. Thanks!
B$ is offline   Reply With Quote
Old 06-16-2014, 05:55 PM   #164
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Screen shots.
From your pic I can see an option for screen off. I will have to check this out. It didn't make sense that when you hit power off and you are still driving that the screen stays on.
Chad86 is offline   Reply With Quote
Old 06-17-2014, 10:23 PM   #165
CO777DAL
CO777DAL's Avatar
I keep my lights set to auto and didn't notice it until you said that. When I pull out my garage my headlights are on and the screen is in night mode for about 30 seconds in bright sunlight and in night mood it is very hard to see. So there really is no reason to use it in daylight, but I did find a different setting in navigation.
This is in the daylight as you can tell. If you go into navigation settings, the screen is always set to automatic. You can see in the next photo you can set it to Day only or night only even in the day.
Old 06-18-2014, 10:40 AM   #166
djmm
djmm's Avatar
Drives: toyota
The middle of the steering wheel, where the logo is. If you press it, the car will make a loud beeping sound.
djmm is offline   Reply With Quote
Old 06-18-2014, 11:45 AM   #167
skasap
Drives: 2013 Dark Grey FRS
Where is this?
If the sound generator is making too much sound inside the cabin, they supplied a plug (from the outlet behind the glovebox) to stuff into the mouth of the sound generator tube where it comes through the firewall.
skasap is offline   Reply With Quote
Old 06-18-2014, 03:07 PM   #168
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
Pull the front of your passenger floor mat carpet back and you'll see a hole that it should plug right into. It's really hard to miss.
MokSpeed is offline   Reply With Quote
scion brz hidden features
Ideas for a hidden magnetic phone-mount. MmmDieselFumes Cosmetic Modification (Interior/Exterior/Lighting) 40 05-09-2016 01:14 PM
Bespoke A/V Hidden Option UbSaMrC Electronics | Audio | NAV | Infotainment 58 12-13-2015 11:14 PM
FS: Custom Stainless Lightweight Hidden Hitch that_guy Canada Classifieds 3 06-11-2014 07:13 PM
Hidden Rusting issue FRSHunter Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 04-07-2014 05:02 PM
DIY: access hidden menus on BRZ head unit robot DIY (Do-It-Yourself) Guides 0 10-22-2013 11:59 PM
