Old 03-11-2014, 05:19 PM   #155
jonathan9573
jonathan9573's Avatar
Drives: 2013 Asphalt Scion FR-S
Well here is the start. Mocking up the plug for the ABS.
Sent from my iPhone using Tapatalk 2
jonathan9573 is offline   Reply With Quote
Old 03-11-2014, 05:21 PM   #156
sklimo
Skirts came in today!! I'll snap some pics tonight and test fit
Old 03-11-2014, 05:41 PM   #157
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
Attachment 70219
Attachment 70221
did you just cut it with knive??? what do you do with the holes or empty space in the middle? how do you fill in the blank in there?
Old 03-11-2014, 06:35 PM   #158
jonathan9573
Cut it with an air saw. I'm in the process of building a mold for an ABS piece that will fill that space in. It will have to be filled a little but that's what you have to do to get ride of the plate.
Old 03-11-2014, 11:33 PM   #159
FRSHunter
Drives: Asphalt FRS
Saw this listed on eBay. It looks like it might be a better fitment than the Bayson for the foglights. That is if those images truly are fitment pictures.
Other TRD rep
FRSHunter is offline   Reply With Quote
Old 03-12-2014, 12:08 AM   #160
sirsol66
Drives: 2013 FRS- Hot Lava
Other TRD rep
That guy recently started posting a lot of stuff for sale on ebay, waiting for someone else to buy to see how the fit is. He also lists this TRD lip kit with a separate under splitter that I had never seen before which looks very interesting.
sirsol66 is offline   Reply With Quote
Old 03-12-2014, 09:30 AM   #161
STS-V
Which one?
STS-V is offline   Reply With Quote
Old 03-12-2014, 10:26 AM   #162
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
So the Bayson ones are ABS while this OEM Direct guys is Polyurethane.
What is better?
The research i've been seeing is that PU is better since it is more flexible, won't crack as easy, and generally has better fitment. What is everyones opinion here?
http://honda-tech.com/showthread.php?t=2129335
https://forum.lowyat.net/topic/984469
Here is a comparison chart:
http://www.sportcompactonly.com/body-kits-guide.htm
blackfireball5 is offline   Reply With Quote
Old 03-12-2014, 12:56 PM   #163
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
The oem is abs because it's more rigid. Since it's basically just sitting against the bumper it needs to be rigid to keep the fitment right. If you were to glue it to the bumper it wouldn't be an issue
Old 03-12-2014, 01:15 PM   #164
blackfireball5
So are you saying the way the kit mounts to the bumper, it would need to be ABS to have correct fitment? You think using the PU kit without gluing anything would not yield quality results?
Old 03-12-2014, 01:16 PM   #165
OURO3OROS
Drives: 2013 Asphalt FR-S
Other TRD rep
I see that the one is the picture in his listing has the weatherstrip (rubber maybe?) piping installed also. I didn't think the Replicas came with that. I know Bayson's spoiler doesn't.
OURO3OROS is offline   Reply With Quote
Old 03-12-2014, 01:48 PM   #166
spitfire481
Drives: 2JZ FRS
Bayson comes with everything for install, including the rubber gasket. I have front TRD, side skirt TRD, and sti rear spats from Bayson
Old 03-12-2014, 01:49 PM   #167
spitfire481
Drives: 2JZ FRS
I'm not sure, it depends on how it fits so it's a gamble until someone tries. For this kind of install I prefer something stiff like abs though
The Following User Says Thank You to spitfire481 For This Useful Post:
blackfireball5 (03-12-2014)
Old 03-13-2014, 10:50 AM   #168
STS-V
Attachment 70219
Attachment 70221
Hi Jonathan, I sent you a PM.
Bayson R lip kit review Cjymiller Cosmetic Modification (Interior/Exterior/Lighting) 59 07-06-2017 02:23 PM
Weather strip/Rubber seal for bodykits FRSHunter Cosmetic Modification (Interior/Exterior/Lighting) 4 03-08-2016 05:34 AM
Weatherstrips for bodykits FRSHunter Exterior Parts (Aero, Lighting, Etc.) 1 12-14-2013 10:15 PM
Who has Bayson R Lip kit? Cjymiller Northern California 21 09-29-2013 10:52 AM
Bodykits....Bodykits....Bodykits.... FT-86GOD AUSTRALIA 78 08-08-2012 10:44 AM
