#155 |
Twin Screw You
Drives: 2013 Supercharged Whiteout FR-S
Looking at the pictures it seems it might be possible to use the 210 intake casting and maybe have an "extension" machined that would put the throttle body in the correct location. That is just a rough idea though. Kind of hard to confirm without having everything here in front of me.
#156 |
Twin Screw You
Yes the blower fits on the manifold but the intake casting is different. If you look at the pictures on the first page you can see the differences.
#157 |
Twin Screw You
Because the blower is larger, it sits further back. Therefore the intake casting has to be longer to put the throttle body in the correct location for the intake tube to connect to. I wish I could park my car next to yours so I could find out what I could do with the 210 casting to make it work.
#158 |
Drives: 2017 Camaro 1SS
#159 |
Mad Sciontist
Drives: gt86
#160 |
Mad Sciontist
Drives: gt86
#161 | |
I just Drive.
Drives: in the womb still
If your aim is to order just a blower separately to save money I can see where you are going with this idea. The castings bolt spacing seems to be the same... However to try and make something your self to perhaps weld on to the casting you have would be pretty tough to do my friend. I am sure the company wont sell just the casting either. So If I were you I would have a plate milled and drilled to mount onto the blower and then...mandrel bend a tube...weld that to the plate...then weld on another plate to mount throttle body to. This is coming from a machinist.
-Waiting patiently for the right FT-86...
-92' Acura Legend 5spd coupe twin turbo project |
#162 | ||
Twin Screw You
Yeah I wasn't thinking about welding anything. I was talking about machining an extension or spacer of sorts to go between the 210 casting and throttle body. I made a post referring to it earlier but it could be easily missed with all the posts I made, lol.
#163 |
So elite I'm 1338
Drives: WRB Subaru BRZ
So... this 210+ kit. Any new information as to 1. Pricing 2. Release date 3. Specifications (CARB Exempt, Dyno #s on a base map, ETC)?
-Jack Burton |
#164 | |
Super 86
Drives: Red 86 GTS
2. Nope 3. The only change in the 210+ is the coating of the louvers increasing the continuous redline exactly how much of an increase is still unknown but the 69mm pulley is now below the continuous redline of the blower. I'm sure straight away people will put even smaller pulleys on as well.
230rwhp/184ftlb on 98RON/93AKI
Build thread Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can |
#165 |
Drives: UK GT86
Actually the 210+ has been on the price list for a while, whether that is still valid though....??
.: Stealth 86 :.
#166 | |
Super 86
Drives: Red 86 GTS
And even then that price is directly from sprintex in AUD, so no idea what it will be in USD as nothing is ever a direct conversion.
#167 |
Can you just order it from the vendors with the 210+ now ?
#168 |
Super 86
Drives: Red 86 GTS
If a vendor can get ahold of one then go for it. Sprintex have not started mass production of the unit yet so finding one will probably prove difficult.
| Abbey Motorsport Sprintex SC updated Dyno plots | Mark@Abbey m/s | Forced Induction | 49 | 02-15-2017 11:13 PM |
| Khorne's - AUDM Red 86 GTS Sprintex | Khorne | Member's Car Journals | 53 | 08-31-2014 09:44 AM |
| Sprintex or Vortech, which setup has more potential? | Turbowned | Forced Induction | 328 | 09-14-2013 11:09 AM |
| Abbey Motorpsort GT86 Sprintex installation | Mark@Abbey m/s | Forced Induction | 18 | 09-07-2013 04:11 AM |
| Sprintex Supercharger Sneak Peak!!! | invisage | Forced Induction | 52 | 03-03-2013 06:11 AM |
