#155 | |
Drives: Subaru BRZ
#156 |
Road Warrior
Drives: Toyota 86 Satin Pearl White
Some great info to share.
I drove from Durban on the coast to Johannesburg, 600km, which is 1753m above sea level, air very thin. I went to a supercharger specialist to resolve the leak issue, as we could not establish where the leak was coming from, after removing the back and sealing the L connectors. The mechanic used Carb Spray and smoke, which identified the leak coming from the two inlet pipe into the cooler lamina. Removed the kit and found the technician who installed pinched the boost O rings on the small aluminum pipe which seals the boost and the coolant. Major leak. We ran some logs and @Delicious Tuning tune a map for the altitude and sent through. Part of my visit was to attend a Toyota, Mazda charity Dyno day, which I was challenged to take the new Sprintex SC Delicious Tuned against the Vortech Visconti Tuned To ensure equal comparison we fitted exact mods, so both cars had Header, overpipe, full 3" performance pipe, AFE air filters. Being my first visit to Johannesburg the night before the event, I went to the same dyno the Vortech had previously run and did 2 pulls. I got 197hp and the Vortech had got 215hp, we plotted the graphs on top of each other and it looked as we have all seen where the Sprinted pulls from low down and the Vortech take over from 5500 rpm and get higher power top end. Next day I met up with the Vortech car, we filled our cars with 91OCT and put 2 cans of Torco octane booster, to further ensure both cars identically matched. We drove 20km to the event. Now this was an absolute eye opener for everyone present. I ran first, 4 gear 2000rpm to 7400 rpm 251hp 277Nm The Vortech ran direct after me 245hp 255Nm We did 3 pulls on each car which further showed a interesting statistic I got 245hp on my first run and got stronger each pull, with highest being run 3 The Vortech got highest on run1 and lost power each run after. The Sprintex Intercooled kit out performed the Vortech in every way To rub salt in the vorthech driver wounds, we did 0 to 100 off the line runs, 2 runs I beat the Vortech by a full cars length. I'm awaiting dyno graphs plotting both cars on the same graph. I want to say a huge thanks to Bill @Delicious Tuning for helping me sort out the leaks and sending updated tune at early hours of the morning. I look forward going back home and fine tuning the car on the coast. . Last edited by Ryan86; 11-30-2013 at 11:20 PM. |
#157 |
Grip>Slip
this can't be. i saw on the youtubes that the innovate is crap and vortech is king! how could the youtubes be wrong!?
#158 |
@Ryan86, I'm glad you figured it out and thanks for sharing, I'm having mine installed on Monday and will let the technician know to pay attention to the o-rings.
#159 | |
Road Warrior
I've watched all the videos and posts aswell, however, how many have had each car identically set up on the same dyno run straight after each other. This test could not have been more accurate. Ryan86 Believe or not ![]() Oh and I have not seen the test done comparing Intercooler vs Intercooler kit.... |
#160 | |
Road Warrior
Something else we did while I had the kit off. At the back of the charger on the right if you standing looking at the back of the charger is a small screw, this is for boost connection. I fitted an 4mm screw in with pipe about 30 cm long, so I can read boost on a dyno or even run into the car for a boost gauge. Sprintex pointed this out to me, as I could not read boost via the ECU due to using the stock map sensor which only goes to .1 bar 3 psi. Worth considering. Good luck with your install. |
#161 | |
Grip>Slip
#162 | |
Grip>Slip
#163 |
Road Warrior
#164 | |
Road Warrior
And do yourself a favour, take off your IAT and see what difference in performance you get. I removed and ran dyno got almost 10whp more gains. Now I have not got facts on the IAT, but my temps are lower without the IAT and car pulls stronger. Need to investigate this a bit more. I also have found the blue gates belt tighter than the belt supplied, got less drag, IMO. |
#165 | ||
Grip>Slip
#166 | |
Drives: UK GT86
.: Stealth 86 :.
#167 |
Drives: Flat grey Toyota 86
@Ryan86 Great numbers and congrats on beating the vortech.
Just curious, are you running any cooling mods? Oil cooler or upgraded rad |
#168 | |
Drives: 2013 SWP BRZ
| Innovate Motorsports Twin Screw Supercharger System, NOW SHIPPING! | Innovate Motorsports | Forced Induction | 577 | 10-15-2014 12:49 AM |
| Innovate Motorsports BRZ/FR-S/GT86 Supercharger System Available from Moto-East! | Xero-Limit | Forced Induction | 12 | 03-10-2014 08:56 PM |
| Innovate Motorsports FR-S/BRZ traction control state modifier module... | mines13 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 20 | 09-13-2013 01:06 PM |
| Innovate Motorsports Twin Screw Supercharger Kit for FR-S/BRZ | Innovate Motorsports | Forced Induction | 1987 | 03-13-2013 09:14 PM |
| FS: Innovate Motorsports OT-2 | pixel67 | Engine, Exhaust, Bolt-Ons | 0 | 01-05-2013 10:13 AM |
