01-22-2015, 02:46 AM | #155 |
Lots of air flow there, must be FI
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
01-22-2015, 03:27 AM | #156 |
Senior Addict
Drives: 86 GT
01-22-2015, 03:27 AM | #157 | |
he has ecutec tuned speintex sc i would not be happy with iam of 0.85 and the levels of knock correction that must have occurred somewhere before that log to drop it to that assuming it was initially set to one. Last edited by steve99; 01-22-2015 at 03:40 AM. |
01-22-2015, 09:20 PM | #158 | |
Senior Addict
Drives: 86 GT
01-22-2015, 10:05 PM | #159 | |
@Kodename47 is in england and their fuel is similar to ours but even their 98 ron seems to be slightly superior to ours. |
01-23-2015, 11:43 PM | #160 |
Drives: 14 Ultramarine FR-S
Can someone check out my 2nd gear pull? Been doing a lot of reading lately...
Running STG 2 UEL 91 Octane http://datazap.me/u/phantobe/2nd-gea...ta=1-7-9-10-12 @steve99 maybeee Noticed my IAM below 1, sometimes as low as .56 Guess I'll try some different gas, only crappy 91 here in socal
2014 Ultramarine Scion FR-S 2000 Integra LS - SOLD Last edited by Phantobe; 01-23-2015 at 11:55 PM. |
01-24-2015, 01:49 AM | #161 | |
if that doesnt fix it pull 1 degree out of the base timing B map from 4500 rpm to 6000 rpm loads from 1 to 1.2 and about 0.7 degrees from 2000 to 4500 loads 0.7 to 1.2 Last edited by steve99; 01-24-2015 at 02:07 AM. |
01-24-2015, 02:10 PM | #162 | |
Is there a good thread for adjusting the maps, I wasn't hoping I wouldn't have to lol. But it looks like I'll be diving in.
2014 Ultramarine Scion FR-S 2000 Integra LS - SOLD |
01-24-2015, 04:30 PM | #163 |
links below like tune tweaks and knock correction should get you started but gass might fix it
01-24-2015, 07:13 PM | #164 | |
From than 2nd gear pull I saw a max FLKC of -1.64 in the 4.5k-6.0k RPM range. And a max of -0.3 FLKC in the 2.0k-4.5k RPM range. Wouldn't you want to pull half of the max timing to be conservative or just work your way down in intervals of 0.30 degrees? I'm unsure on how you know what loads to apply the timing. Still reading :P... vigorously. Edit: Ah...so we can also log engine load doh... that answers one of my questions! So much good info in the knock correction thread.
2014 Ultramarine Scion FR-S 2000 Integra LS - SOLD Last edited by Phantobe; 01-24-2015 at 08:24 PM. |
01-24-2015, 08:54 PM | #165 | |
usually your iam gets dropped by Knock Correction FBKC in the 1500 to 3500 area when you get on throttle under higher loads, these motors just knocky in that area on 91 fuel. your trying to run it lean as possible with as much advance as possible to get decient economy cruising in that area you also get a bit of knock on hot days when you sit idling the take off and intake air temps are high, not sure what temps are like there its 35C here |
01-25-2015, 03:33 PM | #166 | |
I was gonna run something like this... What do you think?
01-25-2015, 04:06 PM | #167 |
Drives: JAWS
@Phantobe
I can almost guarantee that won't be enough to keep your IAM up and eliminate knock. I'm in Socal, and I've tested different gas stations, found my local 91 Shell to be the most knock resistant. Here's the corrections I'm running compared to 2.06 stage 1 91 oct. map, my IAM stays between .98 and 1. Keep in mind I've done about 9 revisions to the timing and have been pulling timing in small increments trying to find the limits of our shitty 91 octane. Car feels smooth and fast despite pulling a couple degrees. |
The Following User Says Thank You to JB86'd For This Useful Post: | steve99 (01-25-2015) |
01-25-2015, 05:14 PM | #168 | |
Thanks for the screenshot! Do you think it'd be safe to pretty much try running your numbers to eliminate knock or just keep revising until I find the sweet spot? Running some the same gas as you & 2.06 tune. Only difference is I'm running STG2 because I have catless headers installed. Here's a 2nd gear pull after driving around a bit, looks a lot better than my previous logs. http://datazap.me/u/phantobe/2nd-gea...=0&data=1-4-14
2014 Ultramarine Scion FR-S 2000 Integra LS - SOLD Last edited by Phantobe; 01-25-2015 at 05:25 PM. |
Similar Threads | ||||
RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 01:15 AM |
Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 12:55 PM |
VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 09:21 AM |
Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 04:57 PM |
ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 09:27 AM |
