Old 01-22-2015, 02:46 AM   #155
phrosty
Originally Posted by Fizz View Post
Would appreciate some feedback on my latest log.
Lots of air flow there, must be FI
phrosty is offline   Reply With Quote
Old 01-22-2015, 03:27 AM   #156
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Yea sprintex 👍
Fizz is offline   Reply With Quote
Old 01-22-2015, 03:27 AM   #157
steve99
Drives: FT86
Would appreciate some feedback on my latest log. Added a catless UEL header since the last update: http://datazap.me/u/fizz/del69ofhlog...&data=5&solo=6
Would an AFR reading of 11.7 at 7000rpm WOT be considered acceptable/safe?
By the way, does adding a free flowing exhaust system generally make the car run richer or leaner?
best bloke to ask would be @Kodename47
he has ecutec tuned speintex sc
i would not be happy with iam of 0.85 and the levels of knock correction that must have occurred somewhere before that log to drop it to that assuming it was initially set to one.
The Following 2 Users Say Thank You to steve99 For This Useful Post:
Fizz (01-22-2015), phrosty (01-22-2015)
Old 01-22-2015, 09:20 PM   #158
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Yes the IAM started at 1 and perhaps may have dropped due to the hot weather recently. I haven't been pushing the car since the last flash (Delicious tune) because I'm still not quite happy with the low-mid range driveability on this tune. Starting off from dead stop the car bogs a little which leads to slight jerkyness around 2000-2500 rpm. Then around 3500rpm there's a noticeable flat spot where the car just feels out of puff for a couple of second. Waiting for Bill to send me further updates based on this log I sent him. Problem is datalogs can't relay how the tune "feels" when driving so it's kinda difficult to explain the issues i mentioned above.
Old 01-22-2015, 10:05 PM   #159
steve99
Drives: FT86
I think its hard for the american tuners to realise how rubbish our fuel is compared to theirs, even their 91 USA fuel is superior to our 98 Ron fuel.
@Kodename47 is in england and their fuel is similar to ours but even their 98 ron seems to be slightly superior to ours.
Old 01-23-2015, 11:43 PM   #160
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
Can someone check out my 2nd gear pull? Been doing a lot of reading lately...
Running STG 2 UEL 91 Octane
http://datazap.me/u/phantobe/2nd-gea...ta=1-7-9-10-12
@steve99 maybeee
Noticed my IAM below 1, sometimes as low as .56
Guess I'll try some different gas, only crappy 91 here in socal
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 01-24-2015, 01:49 AM   #161
steve99
Drives: FT86
@steve99 maybeee
ask @solidONE or some other cali guys they can probably put you onto the best gass
if that doesnt fix it
pull 1 degree out of the base timing B map from 4500 rpm to 6000 rpm loads from 1 to 1.2
and about 0.7 degrees from 2000 to 4500 loads 0.7 to 1.2
Old 01-24-2015, 02:10 PM   #162
Phantobe
Phantobe's Avatar
Just filled up with a tank of shell 91 I'll see how that runs...
Is there a good thread for adjusting the maps, I wasn't hoping I wouldn't have to lol. But it looks like I'll be diving in.
Old 01-24-2015, 04:30 PM   #163
steve99
Drives: FT86
links below like tune tweaks and knock correction should get you started but gass might fix it
Old 01-24-2015, 07:13 PM   #164
Phantobe
Phantobe's Avatar
How do you know how much to timing to pull & at what loads?
From than 2nd gear pull I saw a max FLKC of -1.64 in the 4.5k-6.0k RPM range. And a max of -0.3 FLKC in the 2.0k-4.5k RPM range.
Wouldn't you want to pull half of the max timing to be conservative or just work your way down in intervals of 0.30 degrees? I'm unsure on how you know what loads to apply the timing.
Still reading :P... vigorously.
Edit: Ah...so we can also log engine load doh... that answers one of my questions! So much good info in the knock correction thread.
Old 01-24-2015, 08:54 PM   #165
steve99
Drives: FT86
As your IAM was less than 1 already the ecu has already backed off timing a bit, and you were still getting a bit of knock correction. so when the iam returns to one it might need a bit more.
usually your iam gets dropped by Knock Correction FBKC in the 1500 to 3500 area when you get on throttle under higher loads, these motors just knocky in that area on 91 fuel.
your trying to run it lean as possible with as much advance as possible to get decient economy cruising in that area
you also get a bit of knock on hot days when you sit idling the take off and intake air temps are high, not sure what temps are like there its 35C here
Old 01-25-2015, 03:33 PM   #166
Phantobe
Phantobe's Avatar
I was gonna run something like this...
What do you think?
Old 01-25-2015, 04:06 PM   #167
JB86'd
JB86'd's Avatar
Drives: JAWS
@Phantobe
I can almost guarantee that won't be enough to keep your IAM up and eliminate knock. I'm in Socal, and I've tested different gas stations, found my local 91 Shell to be the most knock resistant.
Here's the corrections I'm running compared to 2.06 stage 1 91 oct. map, my IAM stays between .98 and 1. Keep in mind I've done about 9 revisions to the timing and have been pulling timing in small increments trying to find the limits of our shitty 91 octane. Car feels smooth and fast despite pulling a couple degrees.
JB86'd is offline   Reply With Quote
The Following User Says Thank You to JB86'd For This Useful Post:
steve99 (01-25-2015)
Old 01-25-2015, 05:14 PM   #168
Phantobe
Phantobe's Avatar
Originally Posted by JB86'd View Post
@Phantobe
Attachment 101260
Yikes! Looks like I'm in for a ride lol. I just flashed over to my revised tune I'm currently running shell as well (v-power). But my IAM hasn't dropped below 1 yet, I'm assuming this is because the ECU is still learning. In a few days I imagine I'll see it drop.
Thanks for the screenshot! Do you think it'd be safe to pretty much try running your numbers to eliminate knock or just keep revising until I find the sweet spot? Running some the same gas as you & 2.06 tune. Only difference is I'm running STG2 because I have catless headers installed.
Here's a 2nd gear pull after driving around a bit, looks a lot better than my previous logs.
http://datazap.me/u/phantobe/2nd-gea...=0&data=1-4-14
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 01:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 09:27 AM
